When booting up receive error code 0163. Attempts to boot into windows and halts.
SOURCE: Error Boot "Chasis Intruded fatal Error System Halted"
Well it seems like that the cmos battery is down. You need to do the following
Change the CMOS battery,
Enter into bios and change the date and time properly,
Save and exit bios.
Now you should be able start your computer in windows.
SOURCE: my system can not booting error message is chasis intruded fetel
KINDLY QUOTE THE EXACT ERROR MESSAGE YOU ARE GETTING. Start tapping the del / f2 key immediately after you turn on the system
SOURCE: Fails to boot, fans and lights on, no bios or anything
My recommendations would be to remove all connections to the board.
Remove the CMOS battery.
Remove the CPU fan and CPU.
Look at the top of the CPU, if you have a crust over the top of the CPU, you will need to remove it to a clean surface.
Next, your CPU fan should be a 3 wire connection on the motherboard, within two inchs of the CPU holder.
After cleaning the CPU, re-inseart and apply a heat sink lub for good heat transfer.
Re-install CPU fan and plug in to board connection.
Re-install your CMOS battery and power up unit.
With the CMOS battery removed, the time and date will need to be reset.
Also, in the BIOS for that board, you should be able to see temps. and rpm readings. ??
Hope the CPU has not taken a dump on you.!
Before you plug in the drives and other devices, check temps. rpm and voltages.
Have fun, hope this has helped you.
SOURCE: Chassis intrusion messagen
This means that either the case of the desktop is open or it is not closed properly. I don't know what kind of case you use so I can't be more specific. Try to close the case (open and close again) or check for an open side. If you are sure that the case is closed and still the alarm exists, there is a way to bypass that kind of alarm, but youhave to edit the bios settings.
In case of a problem or clarification or if you want to bypass the alarm from the bios, don't hesitate to post me a reply.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Computer is booting from a non-bootable source
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette
or CD is in the computer, unless you are attempting to boot from a diskette.
Note: This error has also been known to occur when a
memory stick is in a card reader and the computer is attempting to boot from it.
If you have any card reader or flash reader make sure that no memory
stick is inside the computer. Additionally disconnect all USB drives, cameras,
ipods, iphones, etc. from the computer.
If you are attempting to boot
from a floppy diskette and are receiving this error message it is
likely that the diskette does not have all the necessary files
or is corrupt.
If you are attempting to install
Windows XP or Windows 2000 and are receiving this error message as the
computer is booting verify that your computer BIOS
has the proper boot settings. For example, if you are attempting to run
the install from the CD-ROM make sure the CD-ROM is the first boot
device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note:
If you are not receiving the above message and your BIOS boot options
are set properly it's also possible that your CD-ROM drive may not be
booting from the CD-ROM properly. Verify the jumpers are set properly on
the CD-ROM drive.
Computer hard disk drive is not properly setup in BIOS
Verify that your computer hard disk drive is properly setup in the
CMOS setup. Improper settings can cause this
error.
Corrupt NTLDR
or NTDETECT.COM file
