Question about Sony XM-1002HX Car Audio Amplifier
Sony amp pops, when you turn on the car. how do i fix it
  • tommylk Jan 29, 2009
    i did it and stil pops . i tryer a new head unit and it is now fixed. thank you 4 your help tom
    President:
  • 1,990 Answers
Run an Extra Ground or ReRoute Your Main Ground Straight to the Battery and it should Stop this Popping. Please Rate my Response, I need all the Help That I can Get! Thanks!
Posted on Jan 28, 2009
When installed, amp gets power but produces no sound
If you have a small mom and pop shop in your area. I would have them check it out. You might have gotten lucky.
Mar 28, 2014 | Sony Exm-502 Mosfet 2 Channel Stereo...
Sony KDS-R60XBR1 No picture
Sounds like your light engine might have broken. Its around a $400 fix and I noticed Tri-State is having a sell on there about 341 its easy to replace it here is the link
http://www.tristatemodule.com/casearch.aspx?SearchTerm=kds-r60xbr1&asug=&view=grid&lang=en
May 14, 2013 | Sony KDS-R60XBR1 60" Projection HDTV
Sony XM-1600GSD have low amps on middel fues and wont work
You are in over your head with this. There is only one fuse on the outside and it is the main power fuse. When you hook something like this amp to a power source for conversion from 110 there is a ripple current. The more the Sony pulls out of the converter, the higher the ripple current came be. That ripple can cause failure of other parts in the amplifier. Since you heard a pop sound. It is apparent that the components in the amplifier have failed. You are going to have to disassemble it and look for damage. Then you need to find that parts that are blown and then you need to be able to solder and replace them.
Nov 12, 2017 | Sony XM-1600GSD Car Audio Amplifier
" " lens pops in & out twice & the screen says access then screen says turn power off and on again. Sony Cybershot dsc w55
this problum is related with optic zoom lenz assy its not work propally so thats why screen shows access problum pleae go to your nearst sony service centre & fix the problum or repair optic zoom assy
Feb 05, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Amp turns on fine hooked up to factory cd player when u turn volume up red light pops on on amp
it means there not enough power going to the amp.or the power wire inside the amp has melted resalting in a bad conection
Dec 29, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony amp 1000w
Check the wiring of the speakers (both inside the box and between the box and the amp). It sounds like one speaker is wired incorrectly at one connection point.
Sep 09, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod amp not working (deck cought on fire)
Hi there, please check the wiring. If there are some loose contacts the above mentioned symptoms are possibble. Best regards, Arpi If you need more info please advice.
Jun 15, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Car Audio & Video Logo
128 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
