Question about SanDisk Electronics - Others
SanDisk Cruzer stuck in USB drive
I cannot remove the 128MB SanDisk Cruzer Mini from the USB port on my Samsung 50" DLP HDTV (HL-S5086W). I've used it many times to view pictures but now it is impossible to remove.
    Novelist:
  • 121 Answers
Wayne_mcc,
So it is physically stuck in the port? If it has been in there for a long time it may have been bumped or jarred so it has lodged in , slight bend or angle would verify that that is the case. It is not rusted or that there is corrosion causing it to stick. Those drives are inexpensive and unless you have some pretty imprtant photos on it I wouldn't worry about gripping it with some small pliers and extracting it straight back, it may crush the mini but you will get it out. The TV is worth more than the cruzer so keep in mind the port can be replaced. You can get an adapter wtih a cable extension that allows you to plug in different USB devices or card readers that way it's "remote" from the TV itself that would make it easy to pop it out and change to something else.
randy320sgi
Posted on Jan 29, 2009
HL-S5086W turns itself off
if your tv is dlp. the blub is probably the cause. i have a r5087 and had same problem. replaced blub and set works fine
Nov 16, 2013 | Samsung HL-S5086W 50" HDTV
Dlp chip for samsung
buy a light engine as the chip alone is over 200 or replace the set.
May 13, 2012 | Samsung HL-S5086W 50" HDTV
Samsung HL-S5086W 50-Inch DLP HDTV keeps turning off for no reason
After turning off do the LEDs on the front panel blink on and off?
If so, you may have an issue with the lamp. Probably needs replaced or repaired.
Dec 26, 2011 | Samsung HL-S5086W 50" HDTV
I have a 50" samsung
Check the Fans make sure they are not dirty ,if they are clean them,Fan2 error means something is wrong with Fan2#
Nov 02, 2010 | Samsung HL-S5086W 50" HDTV
Air filter location for samsung dlp hl-s5086w
More or less make sure there is no dirt or dust Blocking Air way CK Fans and Lamp housing blow out all dust and dirt.
Sep 30, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Display is to high on dlp set
the entire light engine assembly is not positioned in far enough. did you replace the color wheel yourself ?. if not call the tv repairman back to reposition
Apr 12, 2009 | Samsung HL-S5086W 50" HDTV
We have a Samsung HL-S5086W 50-Inch DLP HDTV. Works fine one min. come home few hours later no one has touched it... and now the sound doesnt work. Any ideas to what the problem might be?
sound demodulator board, is a common fault with this model.
remove plug in board and send it to samsung for exchange.
cost is around 223 australian dollars.
other than that you could opt to run the sound via an external sound system.
Jul 08, 2008 | Samsung Televison & Video
Electronics - Others Logo
232 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
