Question about General Filters 1042-LH Humidifier
Moisture i have pelle windows im getting moisture between windows i have generalair fresh indoor model 1042lh with m3 humidistat were do set it
    Problem Solver:
  • 8 Answers
This may not be a humidity problem but a condensation problem. to cold outside too warm inside. humidifiers are tricky because they are to be set according to outside temperature, what you can do is try turning your dial up or down, let it be for a couple of days then try again until you get to a comfortable humidity level.
Posted on Feb 04, 2009
My carrier humidifier has a hose which drains into the laundry sink and a lot of water is coming out. Should this happen in winter? I thought water should only come out in the summer?
The humidifier should run in winter, however if the windows are fogged up it means the humidistat is set too high. Try lowerimg the setting on tue humidistat.
Jan 03, 2013 | Carrier SBP Humidifier
Water and motor always run on Aprilaire 760, even when furnace is off.
Hope this solves your problem, look for the humidistat, it should be located on cold air return duct near furnace, make sure it is not set in the on position, if it is, then this is why it is staying on, please set humidistat any where from 20 to 35%, never over 40%. If the humidistat is set properly and is still running, you may have a electrical problem, humidifier circuit should only receive power(24 volts) when the indoor blower motor of furnace receives power, also if you have galvanized plumbing in your home, you may have a piece of rust or lime deposit in the humidifier solenoid valve preventing it from closing, turn water off to humidifier and disconnect water supply line entering solenoid valve inspect & clean protector screen. Good luck.
Mar 03, 2010 | Aprilaire 700 Humidifier
I have a genral aire 1042lh and am not getting any water to the filter. I have changed the solinoide out and restarted my unit but still no water flow yet there is ample water flow from the line when...
you must not be getting 24 volts at the solenoid, check your transformer to see that its supplying 24 volts and follow the power, also try turning up the humidistat.
Feb 06, 2010 | Humidifiers
Have a Honeywell House Humidifer - Control Malfunction?
get a humidity gauge from radio shack for about 20 bucks. thats the only way to tell. or pay a service compant tocome out for probaby a 100 bucks to tell you what the humidity level is in your home. id get the $20 one a the shack
Dec 02, 2009 | Honeywell Power Humidifier: Furnace...
My 1042 L General humidifier is not putting moisture in the air eventhough water is getting to the filter
General 1042-L not putting moisture in the air. Water valve is open and getting to the filter. The unit is clean.
Dec 01, 2009 | General Filters 1042-LH Humidifier
Air/no moisture
the reason why you might not see the moisture coming out cause it's a cool mist humidifier. to test your humidity in your house you might want to get a humidistat which will letyou know if your getting the humidity in your room or not. now if it's a warm mist you will see it but it's a coolmist so you won't see moisture coming out.
Jul 16, 2009 | Hunter 33201 Humidifier
Low or no humidity.
i have an aprilaire model 550 im getting no water to the filter but i am getting water to the solenoid
May 11, 2009 | Aprilaire 550 Humidifier
Continous water flow on a 1042lh humidifer
theholts220 - Sounds like they needed to install a bit larger transformer . You can also buy a A 50 Sensing relay that attaches to the wires for your motor and when you turn on the furnace it will allow the power to go to the humidistat. Very strange though they do not use a lot of power. Check and make sure the wires are not pinched or touching metal somewhere.
TLuzzo - The humidistat seems to be working when you turn it down. The wires for the solenoid should be hooked up to your furnace circuit board. The instruction manual will tell you where. If you dont have a spot on your circut board the A 50 sensing reley is they way to go. They are inexpensive
Jan 24, 2009 | General Filters 1042-LH Humidifier
Can't find out what model my humidifier is?
got to be a tag with model number. humidistat usually has setting on it with temperatures. Try 40 to start. get condensation inside windows? lower a litltle.
Jan 15, 2009 | Kenmore Humidifiers
General Filters 1042-LH Humidifier Logo
220 people viewed this question
Top General Filters Humidifiers Experts
Paul Carew
jdthefixer
Steve
Are you a General Filters Humidifier Expert? Answer questions, earn points and help others
