Question about GE Microwave Ovens
Intermittant loud "pop" when starting my microwave
Every once in awhile, when I push the start button on my microwave, it makes a loud pop, or snap sound. It sounds like an electrical short. It's loud enough to get the attention of everyone in the room (my poor nanny usually cries). This will occur once about every 20 to 30 times I use the microwave. This is the only symptom. I never smell any smoke, never see any external flashes or smoke, and the food always cooks normally.
  • Anonymous Mar 14, 2014
    Loud popping sound when microwave is started
  • GE Master
  • 19,396 Answers
Clean well the inside of the oven, if you keep having the problem and the inside is clean, then the magnetron is starting to go.
Posted on Jan 28, 2009
Microwave made loud pop when started
It does sound like it may be arcing causing snapping sounds, if bare metal is exposed it will arc and eventually cause the maghetron to fail. It is possible the magnetron is breaking down, but for safety issues it should be checked.
Mar 04, 2012 | Sharp R-1871 Convection Microwave Oven
My microwave made a loud "pop"and now hums loudly
Since the microwave is humming, that tells me that the diode is bad and needs to be replaced.
Feb 04, 2011 | Whirlpool MH3184XP Microwave Oven
Saw sparks and heard a pop noise when we hit ''start'' on microwave
We just had the same problem - spark, loud noise, and then dead. At first I replaced the ceramic fuse and the same thing happened immediately. A local appliance store tested the transformer and found it was "bad." I purchased a used transformer from the store for about $35. I installed both of these myself with little effort.
Sep 08, 2009 | Dacor DMO24SS Microwave Oven
Kenmore microwave loud popping noise when start
That sounds like maybe a high voltage wire or component is running too close to the chassis or one of the components connected to it.
Gruesome as it sounds, sometimes a pest can get inside the works and can move wires around or be killed, then its carcass can conduct electricity and cause arcing.
It may instead be a failing high voltage diode.
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number (66562619200) at the Sears parts site.
Here are some links you or someone you know can use (in order given) for test help, but
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
http://www.gallawa.com/microtech/xformer.html
Jun 14, 2009 | Whirlpool MH7130XE Microwave Oven
Dacor DMT2420s when started makes a loud buzzing sound
The fan could have an obstuction. I have heard of tech sheets getting into the fan and causing a vibration and vibrating sound.
May 12, 2009 | Dacor DMT2420SS Microwave Oven
LOUD SNAP SOUND THEN MICROWAVE WONT HEAT
my microwave oven is a model lg lmv1630bb is making a loud snapping soud
May 07, 2009 | Microwave Ovens
Short in start button
NO . What will happen is that the contacts on the momentary start switch will wear to the point of no longer making contact at which time the button will no longer work.
Dec 27, 2008 | Microwave Ovens
Kenmore micowave oven over range
Usually this is due to your diodes going bad. I recommend replaceing the magnatron at the same time though.
Nov 08, 2008 | Kenmore 62622 Microwave Oven
Microwave made loud popping noise
The magnetron is bad. Probably cost about $50 or $60 for the part. Not too easy to replace, but it can be done.
Dec 13, 2007 | Whirlpool MH7130XE Microwave Oven
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
639 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
