Question about Whirlpool GR773LXSS - Stainless Steel Electric Kitchen Range
REPLACE CRACKED GLASS COOK TOP
MY DAUGHTER BROKE THE COOK TOP ON HER NEW WHIRLPOOL GOLD ELECTRIC RANGE M#GR478LXTB. IS IT A SIMPLE PROCESS TO REPLACE THIS PART OR DOES IT REQUIRE AN ENGINEER?
  • 5,911 Answers
First of all, if the cook-top broke as a result of a manufacturer defect, the repairs should be covered under the manufacturer's warranty. In this case, the repairs would be done at no cost to you. If, however, the glass top was broken as a result of the consumer, the repair will not be covered (even if it is still under warranty). If this is the case, it does not require an engineer to replace a glass cook-top. It can be time consuming, though. If you are somewhat savvy with fixing things, it can be accomplished by the average do-it-yourselfer. The following link explains how to replace most glass cooktops:
http://www.fixya.com/support/r391448-replacing_glass_cook_top
The tedious part of replacing the cook-top is carefully removing and handling each burner element. These are usually ceramic and are very fragile. You must be handled with care. If there is no common disconnect, you also will be required to unplug each burner assembly one at a time and label the wires. A digital camera can come in very handy for this as well. The easiest way to do this is to remove the old shattered cook-top, first and lay it side by side with the new one. Remove and install one burner element at a time.
If you wish to pursue this and require additional assistance, please let me know before you rate the solution. I hope this helps you.
Posted on Jan 29, 2009
Cracked glass top what is the price of a new one?
Sears.com has the glass top for $353.58. That is for the part only, They charge around 129.00 to 159.00 to replace it for you. Part + Labor +tax. Hope that helps
Sep 02, 2011 | Whirlpool GR465LXLS Electric Kitchen Range
CRACKED GLASS GE - JB968
1 Unplug cooktop or disconnect power.
2. Remove the cooktop from its mounting
location, (see “Installation Instructions” in
Section 2). Position the cooktop so that
you can access the bracket screws below
the cooktop glass
3. Remove the fourteen flat-head screws
from the front, rear, and side ceramic glass
brackets.
4. Remove the two small side brackets from
the cooktop base.
5. Lift and remove the ceramic glass from the
Oct 13, 2008 | GE Profile JB968 Electric Kitchen Range
Cracked glass on cook top. Can it be replaced without buying the heating elements?
Sorry to hear about the trouble, yes the glass and frame can be ordered separate from the elements. If you can send me the complete model number from the tag on the side rail visible with the lower drawer open I can get you the part number and approx cost.
Apr 25, 2010 | Whirlpool RF378 Electric Kitchen Range
I broke ceramic top glass ...how much thank you
We are a Jeen-Air factory authroized parts supplier. What color is your cook-top?
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct part out to you asap.
Thanks, Ella
Jan 31, 2010 | Jenn-Air SCE30600 Slide-In Electric...
How do I replace a Whirlpool RF362LXTT cook top?
Read through the link provided and let me know if you have any questions. This is not a difficult repair, but can be tedious. I hope you find this information helpful.
NOTE: There should be a wiring diagram included with the range that you can also use for reference. It will either be located on the back of the range, or inside the control panel.
Aug 16, 2009 | Whirlpool Accubake RF362LXTT Electric...
I broke the glasstop of my stove. Can I replace
http://www.partselect.com/Maytag-Stove-Parts.htm
just typ in your model number, and find the part you want on the diagram. you can purchase it through them, too.
Jul 31, 2009 | Maytag MER6772 Gemini Electric Kitchen...
My smooth cook top is cracked, can I still use the burners?
using a cracked cooktop is highly dangerous. i have seen these cooktops shatter because of people using them with a crack. One shattered so bad that the glass was found all over the kitchen and the ajoining living room.
Please dont use it, for your safety, repair or replaced the unit
Apr 12, 2009 | Whirlpool Accubake RF362LXTT Electric...
Broken glass top on my Maytag Schott Clean (upper
u have to replace the whole top and its about 400 to 500 dollars just for the part cheaper to buy new
Mar 20, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Gemini electric oven; glass top cracked
yes its not too difficult check your owners manuel as most ceramic cook tops are under extended warrenties from 5-10 years
Feb 11, 2009 | Maytag MGR6772BDS Gemini Gas Kitchen Range
I Have a Whirlpool Gold Glass top Range. The Most Recent error code reading from left to right is E2 F3.
Hello welcome
Error code E2 means to
Check door/latch switch
and
Replace door switch if defective
Thank you Huum
Please leave a rating before you leave
Dec 07, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool GR773LXSS - Stainless Steel Electric Kitchen Range Logo
850 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
