Question about Kenwood KGC-9044 11-Band Car Equalizer
(How To?) installing kenwood KGC 9044
Hi Folks, I've got a KDC PSW9521 with 3 pre outs 1 for front, 2nd rear, 3rd non-fading and I'm running 3 amps. So I've just got a KGC 9044 Equaliser, Second hand with no Instruction manual so I'm not 100% sure of how to connect up the Phono leads from one to the other and amps etc, So help me out Please A.S.A.P Cheers Rich "soon to be BLAST'N"
  • Anonymous Apr 15, 2008
    back connection
  • 65 Answers
You'll have to use your choice of either the front outputs or rear outputs to plug into the eq. Most equalizers I've ever seen only accept 2 channels of input, then give anything from 2 to 6 channels of output, depending on the eq.
Posted on Sep 17, 2007
6ya staff
SOURCE:
Need a stereo wiring diagram
Hiya,
Here's the wiring connections for the Kenwood KDC-3025.
Black: Car chassis (-) ground wire
Yellow: Battery (+) wire (must connect to retain memory settings)
Red: Ignition/Accessory wire
White (w/black stripe): Front Left speaker (-)
White: Front Left speaker (+)
Gray (w/black): Front Right speaker (-)
Gray: Front Right speaker (+)
Green (w/black): Rear Left speaker (-)
Green: Rear Left speaker (+)
Purple (w/black): Rear Right speaker (-)
Purple: Rear Right speaker (+)
Blue (w/white): Power Control wire (used with ext. amp only). Do not expose this wire, if no amp is used.
Blue: Antenna Control wire
Brown: Telephone Mute wire (used with handsfree carkits).
Hope this helps,
Cheers,
Scott
Feb 01, 2013 | Kenwood Sirius KDC-3025 CD Player
Im looking for a kenwood kgc 9044 wiring harness. will a standard 16 pin cd player harness work?
any regular kenwood 14 pin harness will work use the yellow for your battery wire the black is still ground and the blue&white striped remote wire is your switched power just hooked one up today sounds Amazing!!! for it's age!
Feb 10, 2011 | Kenwood KGC-9044 11-Band Car Equalizer
I have a stereo kdc-x869 but i dont know which of the rca outputs is sub,front,or rear. where can i get that info?can you provide me that info?
looking at the back of radeo u have 2 sets of rca jacks.to left u have 1 long & 1 short.long one is non fading.short one is front.to the right u have long one aux in &the short one is rear.hope this heips u.
Aug 30, 2010 | Kenwood eXcelon KDC-X869 CD Player
How to Fade individual speakers on the Kenwood
Hi.
Use the audio control settings. Here an extract from manual:
Here the full manual:KDC-4020 KDC-3020 KDC-2020 KDC-1020 KDC-1020S.
Regards.
Ginko.
Jun 07, 2010 | Kenwood KDC-2025 CD Player
I have 1 center channel pre-out on back of my kenwood receiver. how do i hook it to the inputs on onkyo m-282 amp and then to center channel speaker?
Unfortunately can't connect it that way. The pre out is only meant to go directly into an amplifier that has all of the same inputs (front/rear, center and surround), not a standard receiver. (Pre amp to amp only, not pre amp to receiver) If your Onkyo doesn't have all the same inputs as your Kenwood preamp has outputs you will just use your standard left/right outputs from the Kenwood to your Onkyo input (CD, Tape, Phono,DVD etc) then use the outputs (front/rear, center and surround) from your Onkyo receiver and connect directly to your speakers..
Jan 01, 2010 | Onkyo M-282 2-Channel Amplifier
Alpine eq 3331 install
USE THE FOR CH RUN ALL THE SPEAKER THE MEANS TWO RCA ONE FOR FRONT AND ONE FOR REAR INTO THE AMP AND NON-FADE REAR-FOR YOUR SUB --POWER FOR EQ--[POWER 'REMOTE AND GROUND]
Mar 26, 2009 | Alpine ERE-G180 11-Band Car Equalizer
Best settings on a 13 band eq for rock and r&b
THAT IS BASE ON HOW YOUR SYSTEM IS SET UP MY FRIEND ADJUSTING ALL THOSE SETTING WONT GIVE YOU MORE BASS
Feb 11, 2009 | Kenwood KGC-9044 11-Band Car Equalizer
INSTALLING A CD RECEIVER IN MY CAR
Some decks only give one pair of pre outs. Most 4 channel amps can use just a 2 channel input and feed the other 2 channels by the flip of an input selection switch. I recomend a 4 channel amp if you want to power front and rear speakers and be able to set the gains to blend properly, or you can run all 4 speakers at a 2 ohm stereo on 2 channels and run a sub on the remaining r channels. It just depends on how you want the setup to be nd to how much control you want. Let me know.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 22, 2009 | Kenwood KDC-215S CD Player
HELP installing kenwood KGC 9044
You will only use the front pre outs from the deck to plug into the only available input on the EQ. You will loose fading and subwoofer controls from the deck which is the main problem when using an eq. Then go from the eq to each of the 3 corresponding amplifiers (front, rear, sub). You will then use the eq as your control for ading front to back and sub control. Im sure by now you have it figured out anyway but if you need help, let me know. Be sure to leave good feedback so and get paid!!!!$$$
Jul 25, 2007 | Kenwood KGC-9044 11-Band Car Equalizer
Kenwood KGC-9044 11-Band Car Equalizer Logo
363 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
