Getting paper jam message but there is no papaer in the printer. I just turned it on after having been off for some months because I needed to by more ink. Now that I turn it on it says papaer jam, but there is no paper in the printer!!!
SOURCE: EPSON STYLUS PHOTO RX425
hi if all the lights are flashing and if you have tried turning printer off and unplugging it from power supply and still you are getting the same error lights then chances are thats a hardware issue already.
call epson support so that they can assist you regarding the warranty status of your printer. Thanks for using Fixya!!
SOURCE: Epson Stylus CX8400 Paper Jam Error
I have the same exact problem of paper half torn removed but I can not see the other half anywhere. The printer has hardly worked for at the most six pages and now showing paper jam error. How do I fix it?
SOURCE: Message Paper Jam MP E
The sensor at the back of the printer is either stuk or out of position open the back of the printer and see if there is a little black lever sticking out if so check it for movement if it sticks yuo have to remove the back paper guide and reseat the lever in its correct position
SOURCE: When turning on my Picture
I own a PictureMate Epson personal photo lab. It has been sitting on my desk for over 1 year with the message Error:Paper is jammed in the printer. Remove the jammed paper, then press (OK). I have done this, many times, I have talked to a "solution Person" and unfortunately they have told me it can't be fixed. I am just warning anyone else, not to buy this product. I have printed less than 100 pictures and it now doesn't work anymore. Just DON'T BUY THIS EPSON PRODUCT
SOURCE: cannot get rid of error msg
Hello there
There may still be some thing there jamming it so try this.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
