Initial setup no sound from my end - Audio Players & Recorders
    Problem Solver:
  • 16 Answers
When setting up receivers or amplifiers,
Following will help to determin or correct the Problem.
1) Do not plug any sources into the unit but power cord. Then wait for 0~5 second while an ear on top of the unit. See whether the clicking Sound can be heard. ** This will tell whether the actual unit has problem or not in Power Supply or in Power Amp Circuit. If it clicks, then The Amp/Receiver is partially OK. In other word, the problem may be something else. If No Clicking Sound, then Definitely there is Problem. Meaning The unit must be serviced by Professionals. ***NOTE: This applies to Modern Receivers or Amplifiers (I would say, the units manufactured after 1980.). Vintage Units may not Apply.
2) Make Sure Speaker Selector Switch for "A" is on.
3) If Above is met (if Clicks), By visual inspection, See if the Tape Switch (Source Select) or Tape Monitor Switch is on or not (Usually Tape 1 or 2 indicator lights). This switch mu be off!! or set to tuner.
4) Many of the receivers or Amplifiers has a Loop called "Main In/Pre Out" at the back of the unit. There must be horse shoes type pins in them. Otherwise it will not Sound. (Some units has a On/Off Switch near by those jacks and have to be on position).
5) Some Units has so called "External Processor Loop" similar to #4 above and the Switch is on the Face fanel usually. (Must be Off Position)
After the Steps #1~#5, if Everthing is Corrected, then the tuner should Sound (Unless there is proble with tuner).
Now Plug in one Source at a time.
****NOTE: When plug in Tape Deck, Make sure to plug in properly. Out of Tape Deck to Play of Receiver, In of Tape Deck to REC of Receiver. Otherwise (if Reversed), the Sound will be muted or No Sound Will Occure.
Posted on Jan 29, 2009
I have no transmitter signal from my wwc model ws1600IT 915mhz TX22IT even after changing Batteries in accordance with instruction of setup, tried this several time, this unit previously worked ok.
Be sure to remove all batteries at both ends then reinstall/install batteries at transmitter end, wait for it to initialize and begin sending data then reinstall/install batteries at the receiving end. You should see temperature displayed.
Oct 25, 2016 | Measuring Tools & Sensors
No sound.
Read the manual. The radio may have been set to some defaults, although the time was not correct. When you started setting the time, it is possible that you should have run through the whole setup. For example some radios have different ranges for the FM bands: there is a Japanese band that starts at 76 MHZ, and ends at 108 MHz; there is the standard FM band from 88 MHz to 108 MHz; and a school band (I can't remember its range).
For AM the gap between neighboring positions may be set at 9 kHz or 10 kHz depending on the location (region or continent).
I suggest you get the manual and see if there is an initial setup procedure, then follow it.
Dec 27, 2013 | Sangean WR-2 AM/FM Radio
Setup password
Did anyone ever find the password for this?
Dec 13, 2013 | Equinox Optimum L4150 Payment Terminal
My MD 421 suddenly has no high end. Sounds muffled and distorts when I yell into it.
Check the cable. It maybe damaged. Check your phantom power. If your going to yell into the mic...Turn the input gain down to avoid initial distortion. Not sure of your recording setup, but everything in the chain input to output is key.
You can probably assume the mic to be damaged if these things dont check out.
I have a MD 421.
Mar 31, 2011 | Sennheiser MD421-II Professional...
I HAVE A SONY BRAVIA MODEL KDL-40W4100 WHICH IS SUPPOSED TO HAVE tvgos but my tvgos does not work at all, no channel listings, nothing
Be sure to complete the INITIAL SETUP to use this service.
If you have an user manual you may check it out for help to complete the INITIAL SETUP. Or else, you can have the correct page of INITIAL SETUP here:
http://www.retrevo.com/pdf/23566bh638/21/Setting+Up+the+Channel+List+–+Initial+Setup#q=Sony+KDL-40W4100
This link refers you to the page 16 of the user manual of your model. Please check page 17 also to complete the INITIAL SETUP. To go to this link, just copy-paste it in your address bar.
Jul 09, 2010 | Televison & Video
How can i restore factory setting in motorola v3i without sim card
Master Reset
Reset all options except unlock code, security code, and lifetime timer:
Go into Settings > Initial Setup > Master Reset
Master Clear
Caution:
Master clear erases all information you have entered (including phonebook and datebook entries) and content you have downloaded (including photos and sounds) stored in your phone’s memory. After you erase the information, you can’t recover it. Clear all settings and entries you made except SIM card information, erase downloaded pictures and sound files, and
reset all options except unlock code, security code, and lifetime timer:
Go into Settings > Initial Setup > Master Clear
Jan 09, 2009 | Motorola Mobility RAZR V3i Cellular Phone
E:91:01
No Problem! Press MENU end go to setup, choose initialize to initialize the cam and put all the configs! finish! your problem is over.
Sorry for my english because i'm from Brazil ^^
Mar 06, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
75 people viewed this question
 Grubhead
Grubhead
