Question about Transcend (589307) Media
Been asked a 1000 times but don't see fix yet
Ativa 4g flash drive write protected how to fix--no switch on it
    Novelist:
  • 121 Answers
Blackhawk92,
No switch but you can see tghe files you want to add to or modify correct? You can copy them to your PC's hard drive and right click over the whole folder or folders and change the properties (uncheck the Read Only radio button) and apply ot to the whole folder or files you wish to modify. You can do this right on the flash drive as well but it is better to have a copy as a backup in case things go wrong which they sometimes do. After it is all done you can erase the drive the same way uncheck the read only status then delete the Hope that ends the contents. Hope that ends the quest for a solution.
randy320sgi
Posted on Jan 29, 2009
How to fix a write protect usb flash drive
make and model? usualy has a switch or jumper if it has write protect
How To Fix Write Protection Errors On USB Stick
Jun 03, 2015 | Electronics - Others
I have an Ativa MD 460 shredder, it is misaligned with paper. Can you help?
ativa md460 misaligned Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your ativa md460 misaligned question. Get free help, tips ... I have an Ativa MD 460c paper shredder that reads misalignment. What do I do?
Just purchased ativa MD 460C and it will not work. misaligned
www.fixya.com/support/t9496803-just_purchased_ativa_md_460c
Jun 16, 2011 - Look for a curve in the lip on the back of the shredder and align it with the ... I have an Ativa MD 460c paper shredder that reads misalignment.
Ativa MD460 paper shredder: misalignment light is on - Fixya
www.fixya.com/.../t7580117-ativa_md460_paper_shredder_misalignme...
Jan 1, 2011 - I have a Ativa MD 1000 that I just bought. It ran for a few minutes the first time I used it an then stopped. I turned it off and unplugged it in case it had ...
Office Depot Ativa DQ60M Shredder Misaligned - Questions ...
www.fixya.com > ... > Office Depot Ativa DQ60M Shredder
just purchased ativa MD 460C and it will not work. misaligned is highlighted. can u help... I have an Ativa MD 460c paper shredder that reads misalignment.
Jun 07, 2011 | Office Depot Office Equipment & Supplies
How do I switch off the write protection on my DataTraveler 4G flash drive
Can you supply the model number of you Kingston Data Traveler flash drive.
I will watch for your reply.
Brian
Jan 27, 2011 | EXP Computer EXP Data Traveler 336E Modem
I have a 4G Verbatim flash disk. I can't format it or use it because it keeps on saying "disk it write protected." I have tried using regedit and also tried formating using disk management but it all...
Hello
There is a physical switch along the edge of the card which allows the card to be protected. If the switch is set to lock or protected then nothing you do in software will matter.
Take a good look at the label it should have a marking next to the switch. Once you change the switch position it should start working normally again.
Hope this helps FixYa,
Crankstart
Feb 25, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
Cannot format diskrive because it is write protected
first open control panel then open computer management and than disk management than right click on pendrive option and format it
Jan 10, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have an Ativa 512mb flash drive and I have WinXP as my OS when I put in my flash drive XP prompted me to chose an action to have my computer do when I put my drive in again and I accidentally chose the...
  • Windows Vista - Go to Start -> Control Panel -> AutoPlay (while in Control Panel's Classic View). Find "Mixed Content" and select "Ask me every time" or "Take no action".
  • Windows XP - I cannot find anything for XP. However, if you go to Control Panel -> Folder Options (In Classic View), and click the "File Types" tab, and then select "Drive", you can double click that, and set the default one to be "find", or maybe delete the current one.
Hope this helps,
-Rolltape
Save, and it should work fine!
Nov 27, 2008 | Computers & Internet
My pny 4g is write protected what can i do to fix it?
format it and try to run this application..here's the link,
http://www.apacer.com/en/support/downloads/AH320_Utility_LFormat.zip
it worked for me,so i hope it will also work for you..
Ms.Waqui
Aug 07, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
How to use usb flash drive
connect it on usb hub then scan it with anti virus, sometimes your flash disk will just pop out on your computer then it will play automatically. or or or if u want to save on your usb, just choose the file you want then save it to mycomputer-then E/your flash drive.
hope you understand. :)
Mar 27, 2008 | Computers & Internet
Transcend (589307) Media Logo
102 people viewed this question
Top Transcend Electronics - Others Experts
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
