Question about Panasonic Televison & Video
Panasonic hdtv has a blue hue to it
I've done what the manual says with the remote menu, but I cannot move the blue bar to the +. Is it worth fixing (2001 - 55") and how much might the repair be. Thanks for any help you can give me.
    Sergeant:
  • 233 Answers
Well, it sounds like your convergence amplifers have died...
If you get it repaired, it is typically around a 300.00 repair.
or you can do it yourself if you have any repair or electronics knowledge - knowing how to solder is a big plus too. If you want to try it yourself, let me nkow, I will post instructions!
Posted on Jan 29, 2009
My Panasonic PT-61LCX65 has a broken screen...is it worth fixing? and can it be fixed?
No, don't waste time or money on a rear projection screen TV. Obsolete and expensive to move and repair. Move on to an LCD flat screen (with LED backlighting).
Jul 31, 2014 | Panasonic PT-61LCX65 61" Rear Projection...
Fix convergence tv cost
Typically the repair calls for Replacing (2) STK-392-110 convergence IC's and usually 1 or 2 maybe more, baby blue 2.2 ohm resistors
then you have to manually align the 3 colors (red,green,blue)
with the remote in the menu or in the service menu!!!!
Nov 15, 2013 | Panasonic PT-56DLX25 56" HDTV
Space bar was blue but is now green ..there's a green hue when pc is on
use warranty to replace problem with electronic expensive to fix then monitor
Aug 06, 2012 | LG Flatron L1810B 18.1" LCD Monitor
Double image on television with blue hue
<SPAN id=ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution>Projection <A href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target=_blank><FONT color=#0033cc>TV</FONT></A> sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look <A href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target=_blank><FONT color=#0033cc>3D</FONT></A>, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. <BR><BR>This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem. <BR><BR><B>Common Symptoms include....</B><BR><UL class=h_mi><LI class=h_mi>Screen looks 3D <LI class=h_mi>Colors don't line up <LI class=h_mi>One or more colors can't be adjusted when using the convergence menu. <LI class=h_mi>Screen is bowed or warped. <LI class=h_mi>TV shuts off after powering on. Power light will blink. TV may also make a chirping noise. </LI></UL>Here are some <A href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target=_blank><FONT color=#0033cc>photos</FONT></A> of convergence problems.<BR><BR><IMG class=h_mi src="/uploads/images/42D3683.jpg"><BR><BR><IMG class=h_mi src="/uploads/images/7859B01.jpg"><BR><BR><IMG class=h_mi src="/uploads/images/E87380C.jpg"><BR><B>Here is a quick tes</B><B>t....</B><BR><BR>Using your original remote go-to the settings menu then goto the convergence section.<BR><BR>Try to adjust the red and then the blue convergence.<BR><BR>You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight. <BR><BR>If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem. <BR><BR>Note: If you TV has as flash <A href="http://www.fixya.com/#" target=_blank><FONT color=#0033cc>focus</FONT></A> or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix<BR><BR><B><IMG class=h_mi src="/uploads/images/69189A5.png">CONVERGENCE SOLUTION<BR><BR></B>You can see some more examples and find a fix using this link on Fixya <A href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull" target=_blank><FONT color=#0033cc>http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull</FONT></A></SPAN>
Aug 28, 2010 | Hitachi 53UDX10B 53" Rear Projection...
"touch focus error" appears when the test is completed. There is a double effect showing on the pictures and the words. What can be done to fix this?
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 14, 2010 | Toshiba 65HDX82 65" Rear Projection...
First the red hue seemed off now picture is overlapping, but when i go to a static screen the middle looked concaved. picture tube going out?
  • Screen looks 3D
Aug 13, 2010 | Philips 60PP9363 60" Rear Projection...
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
Apex GB43HD10 Convergence
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 10, 2009 | Apex Digital GB43HD09 43" Rear Projection...
Panasonic projection tv
  • Screen looks 3D
Sep 08, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Panasonic hdtv pt-56wx42
  • Screen looks 3D
Dec 01, 2007 | Panasonic PT-56WX42 56 in. Rear Projection...
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
