Question about Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher
No water is entering the Exxcel auto option dishwasher
The machine clicks when turned on, but no water is entering.  Read that it may be down to the float switch, but cannot locate this.  How do I find the float switch?
    Novelist:
  • 166 Answers
Hello there,
If there's no water entering your dishwasher, check these:
1. Water-inlet valve
2. Float switch
Water-inlet valve
The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch
The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
thanks for using FixYa
Posted on Feb 11, 2009
My bosch exxcel dishwasher is saying to check the water how do i do that
There is a water inlet valve (lower front service panel) and solenoid located. Check to make sure that there is no blockage, if the main or other tubing entering or exiting this valve is kinked, the machine will display the check water light. There is also a float switch on the inside of the dishmachine, if it is stuck, the light will go off also. Ensure that water is flowing into the machine, and there are no kinks in any of the hoses. If there arent, look into the float. If it is under warranty, do not attempt to do any of this yourself, call for bosch support first.
Aug 18, 2012 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
No water comes into my Bosch dishwasher when I turn it on.
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Mar 31, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch exxcel auto option - Have not run it for a couple of months. Turnit on al all it does is pump out
The usual reason for this is that water hes leaked into the bottom of your dishwasher under the washing compartment. This has caused the float to rise and trip the switch which activates the Aqua-Stop / anti-flood protection system. This also closes the solenoid (water control valve) to stop water entering this dishwasher. You may already have had a small leak before you stopped using it.
The only way to check this is to remove the washer from under the counter (disconnect power and water supply first) and tilt it backwards about 15-20 degrees. Water should run on to the floor from under the washer so I suggest putting some old towels down first. Once the water has been drained from under the washer, you can use it again, but it's not advisable if you have a leak and this really needs to be investigated.
If there is no water from under the washer, you may have a faulty float switch or possibly a faulty control module.
Hope this helps.
Regards,
BElectric
Nov 23, 2010 | Bosch Dishwashers
Not enough water entering machine
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Jun 21, 2010 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Sgs43a52gb Water is not filling the machine
heatman101
May 17, 2010 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Bosch Exxcel Auto option
There should be a float switch inside the dishwasher sometimes these get hung up on the full position which in turn keeps the solenoid from allowing the water to come on. remove the bottom rack and check to see if this is the case. Dislodging the float should fix the problem. If not listen to see if the solonoid Clicks when you turn the cycle to fill position if not it could be either solonoid or the timer. if you hear click and still no water check strainer in water line could be clogged or water is turned off some where.
Oct 19, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch Exxcel Auto Option/Detergent tablet does not dissolve?
It seem that your DW drain it's water by syphon action. Check if the drain hose is properly installed as a U shape; otherwise the DW can drain itself at any time, leaving the soap undissolved .
Nov 16, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher Logo
673 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
