Question about Brother LS-2125 Mechanical Sewing Machine
Bobbin holder keeps catchin thread
I have got a brother LS-2125 - the bobbin holder (not the case) (the bit that turns it) keeps catching the thread and wont sew any more as it keeps catching.urgent please help!!!!
  • ayveeweeks Jan 30, 2009
    thank you that was really helpful i rethreaded the machine and noticed i had the tread twisted around the needle and therefore it was getting caught in the back.
    Thanks!
    New Friend:
  • 186 Answers
Try re-threading, make sure the presser lifer is up so the tension discs are open and the thread will go into them. It sounds like you may have missed either the upper tension discs or the take up lever.
A drop of oil on the hook wouldn't hurt if you haven't oiled in awhile.
good luck!
Posted on Jan 29, 2009
Threading the bobbin
hi Sharon.
not sure if this will help you out because its saying its for the, ls 2125i.. but try this step by step link.
How to Thread Brother Ls 2125i Sewing Machine
or this youtube video link.
How To Thread Bobbin on Brother LS 2125 Sewing Machine
this link might be the best one for you to watch.when you go to this one scroll down the page a bit and you will see where you can watch the video,
How to Thread bobbin on the Brother LS 2125 sewing machine
Nov 25, 2017 | Brother Sewing Machines
Thread keeps coming out of the bobbin holder while sewing
it could be the way the bobbin is wound
try turning the bobbin the opposite way in the bobbin case
try a different bobbin that one could be warped
there could be something wrong with the bobbin case itself
or even the hook and the hook race may need to be checked
to see if there is something wrong with them.
Nov 19, 2012 | Brother LS-2125 Mechanical Sewing Machine
I have a brother LS-2125 and the thread from the bobbin is not catching and is not being pulled through.PLEASE HELP! i need it for an assignment! :)
Here are some things that may fix the problem:
1. First, replace the needle
2. Next, remove the thread and completely rethread the machine
3. Remove the bobbin, clean any lint or thread from around the bobbin, and replace it.
Try sewing again on scrap fabric.
I hope this helps.
Apr 01, 2011 | Brother LS-2125 Mechanical Sewing Machine
Sews good on top but balls up on bottom.
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out.
Mar 14, 2011 | Brother LS-2125 Mechanical Sewing Machine
I have a LS-2125 brother machine, and when I sew the thread from the bottom catches and breaks. I have taken the bobbin casing apart and cleaned and oiled it, changed bobbins, tried to adjust the...
make sure that it is threaded right, and that you do not have your needle inserted backwards, flat side should face rear of machine, read your manual carefully. If you do not have one, go to www.brother-usa.com and you download one for free.
Sep 07, 2010 | Brother LS-2125 Mechanical Sewing Machine
Lower thread keeps jamming even though bobbin case is clean and tension on thread has been adjusted.
Here are some things to try.
* Re-thread your machine
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
Also, before you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope one of these solutions help.
Sep 15, 2009 | Brother LS-2125 Mechanical Sewing Machine
Bobbin case on brother sewing machine
Well, from the picture I see that your bobbin is a front load as opposed to a top load.. if you tilt the front panel down, you will see where the bobbin and casing goes. Put the bobbin in the casing with the thread pulling from the right hand side of the casing making sure the thread in guided into the small **** on the top edge of the casing.. On the back of the casing the will be a small tab. Pull that away from the casing and enter the casing in to the opening for the bobbin. It should snap into place when you release the little tab.
May 28, 2009 | Brother LS-2125 Mechanical Sewing Machine
NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
May 27, 2009 | Brother LS-2125 Mechanical Sewing Machine
Lower Bobbin not threading
the thread will not catch the bobbin and the feeder will not turn
May 17, 2009 | Brother LS-2125 Mechanical Sewing Machine
I cannot get the needle to catch the bobbin thread
sounds like your keeping the upper thread too tight when you drop your needle down to catch the bobbin or the bobbin thread that you left hang out is too short, let me know if it works amy
Jul 25, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
236 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
