Question about Crafts & Hobbies
How to glue fornner to metal floor? with contact glue? epoxy?
  • 547 Answers
First put in sub floor of wood then glue with contact cement screw in sub floor
Posted on Feb 11, 2009
My mom has a Volkswagen and the celing liner in the rear is falling what could i do thats cheap?
Velcro strips attached to the inside of the metal on the roof and on the liner is where the other piece is attached. You need to make sure that you have a very good glue that can take the heat from summer sun on the car. A high quality contact cement would be good if you can avoid the solvent in the glue melting the plastic on the Velcro. If not you may be able to use epoxy.
Apr 23, 2018 | Volkswagen Cars & Trucks
Epoxy paint on garage floor
You test moisture presence with plastic sheeting and tape. Tape a 1 foot square of plastic sheeting to the floor after you dry it out with a blow dryer. Check back in a couple of days. If its wet, you have a seepage issue.
Mar 18, 2015 | Super Glue Epoxy
Rear view mirrior fell off.....how to you put it back?
Auto parts stores sell "Rear view mirror adhesive" - special glue for mirrors. TIP: Follow instructions to the T or you'll be doing it over.
Mar 15, 2011 | 2000 Hyundai Accent
How do I remove dried epoxy glue from two pieces of metal without damaging the metal??
Most epoxies will soften and crumble when heated. This is the easiest way of loosening epoxied threads etc.
Nov 08, 2010 | Sunforce 44444 12volt 400watt Wind...
I have some stress cracks in the body where the legs attach. What epoxy would I use to repair and strengthen the area that is cracked
There is no epoxy strong enough for that. If it is metal, and has lost it's strength, it needs to be welded or replaced, Is it aluminum? You could get it heli-arced, but I don't think the casting will take the heat. I have tried every epoxy know to man, there are some great ones out there, but if the metal wouldn't hold up, no glue is going to. And what are the legs you are referring to?
Jun 10, 2010 | Garden
Name of the yellow glue
It could be epoxy resin glue or if the glue it is slight elastic it could be hot glue which is applied with a hot glue gun.
Dec 24, 2009 | Boston Acoustics BA735 Computer Speakers
Hi,I have just laid a solid oak floor,160mm x 21mm planks,the floor was quite uneven but was told by floor salesman that this is no problem,the adhesive will make good,however although the new floor is...
Well never listen to salesmen. Once you walk out the door they don't care. The problem with foam is I doubt any of them firm up enough to keep the floor from moving. If you've never worked with expanding foam, I think it would be rather hard to inject into small holes and would be very messy. I'm wondering if injecting an epoxy filler woulnd't be easier and dry much harder. Next time try regular body putty for automobiles. It's relatively inexpensive, dries very fast, adheres very nice to wood and is easy to sand and level.
Dec 06, 2009 | Tools & Hardware - Others
How do u seperate the metal plate from the rearview mirror
use a special pad if you can get one or a new mirror ,do not glue it with epoxy type glues because the sun will expand it and then the windscreen will crack ,trust me ,got the teashirt here
Nov 22, 2009 | 2002 Kia Optima
Metal posts to fused glass earrings
Use a 2 part epoxy. It's more work but it will work and will last forever. If you get it in a dual syringe dispenser it's not a whole lot of work to use as you just squeeze a small amount on a sheet of paper, mix it with a popsicle stick or something else disposable, then apply and wait for it to cure.
Sep 13, 2009 | 3M 5/8 x 8 - Low-Melt Adhesive Clear
Crafts & Hobbies Logo
118 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
