Question about Hitachi 55HDT51 55 in. HD-Ready Plasma Television
My TV has little green dots all over the picture.
The picture also looks like a photo negative in low light scenes in movies/TV shows on both digital cable & BluRay discs & DVD's.
  • david_roadki Jan 28, 2009
    The previous solution attempts to explain a possible cause but no solution.
  • david_roadki Jan 29, 2009
    My Hitachi 55" plasm HDTV has flickering little greet specks all over the picture and during low level light scenes in shows & movies look metallic( as in a photo negative).
    The picture looks great in bright scenes like TV news or sports games.
  • 505 Answers
You have the problem called "diffusion" errors, or some call it non-erasing pixels, etc.. You may be able to adjust the voltages to fix the issue. The 2 main voltages are VS and VA. The value they should be is listed on the back of the plasma panel. If one is off, then it could be the cause. Some manufacturers recommend turning up or down vs or va by 10% to fix this type of issue. Unfortunately, it can also be caused by many board in the tv.. power supply (where vs and va are generated) plus also the y and z drive boards, buffer boards, etc. If they are across the whole screen, suspect the power board and Y board most likely. I can talk you through all the adjustments but you will need a dc voltmeter capable of handling 250v. Let me know your skill level and we can fix this together.
Posted on Jan 29, 2009
  • 15,935 Answers
This is going to be either a voltage adjustment or a faulty control board and/or Y sustain board.
You need to have a qualified technician check the voltages on these boards to determine if they need to be adjusted or else (if the voltages are fine) these boards will need to be replaced.
    Genius:
  • 2,920 Answers
Your green tube is trying to go out...will make the pic look black and white before too long
Posted on Jan 28, 2009
    Sergeant:
    Novelist:
  • 326 Answers
That is called diffusion. that can be adjusted out in most cases by adjusting the y sustain pcb but can also be the main pcb, the logic pcb and panel itself but not likely
I have a vizio Vt470m....the picture has always been perfect. All of a sudden when picture shows scenes with very little light (dark scenes like at night, space, low light) the black color almost look
Either the TCON board or the LCD panel has failed. Start by replacing the TCON board. If the problem persists, the panel is bad and the cost to replace it would be too high.
Mar 22, 2014 | Vizio Televison & Video
Hello, why does my plasma tv have thousands of red and green flashing dots all over the dark parts of screen after it has been on for roughly half an hour? if i turn tv off for a while then turn back on...
I had a similar problem but mine was just red specks that showed up in dark scenes. I opened up my plasma and found the adjustment pots that are labeled Vsc, Vy. I then marked the factory default with a sharpie first. Then I lowered the Vy a little and my red specks disappeared. Now my tv looks awsome again like it was new.
May 10, 2010 | Samsung DLP HL-P5663W 56" TV
I keep geting avery fuzzy pic
this is a low resolution camera, so its results may appear fuzzy, escesially if viewed on a higher resolution display/device.
try this: set the camera on a stationary surface and take a picture of a static scene, taking care not to move the camera at all while it captures the image. if this looks better than the photos in question then the issue is camera motion ( or available light or motion in the scene) while taking pictures. if it is similar to others then probably the low resolution is not sufficient for your expectations/needs.
Dec 24, 2009 | Sakar 24280/24282 Digital Camera
Downloading video clip to computer from canon powershot A60
To keep the video and images, transferr images to the computer:
  1. If you have a Compact Flash media card connected to your machine, plug the card in the reader and follow the instructions of the software program to transfer to your favourite photo software.
Another method is connecting your camera to the computer using the supplied USB cable:
  1. Install the camera software on the CD following the guides that came with the camera.
  2. Connect the camera to the computer using the USB cable connecting to the camera in the Digital Terminal under the Terminal Cover on the right of the computer (looking at the lens).
  3. Transfer using your favourite photo software, or the software installed from the CD.
Next question, yes, you can get regular pictures from this, use the dial to select one of the modes to shoot photos. This information can be found in your manual too...
  • Auto - use this setting almost all the time. All settings, including flash will be automatically decided for you.
  • P - Program mode, ISO and shutter speed will be selected, all other settings you can override if you wish to set them.
  • Tv - Shutter priority, requires you to indicate how fast the lens iris will open. The Apperature (size of the iris) will be decided by the camera. all other settings you can override if you wish to set them.
  • Av - Apperature priority, requires you to indicate the size of the lens iris. The Apperature (size of the iris) will be decided by the camera. all other settings you can override if you wish to set them.
  • M - Manual priority, requires you to set both the Shutter (iris speed), and shutter (iris size). All other settings you can override if you wish to set them.
The other dial settings are:
  • Portrait - automatic settings for still family/portrait photos
  • Landscape - automatic settings for landscape mountain or outside scenes
  • Night - automatic settings for low-light conditions
  • Sports - automatic settings for high-speed events (sports, plays, movement)
  • Slow speed - for making things look blurry like they are in action. Advanced setting.
  • Stitch - allows you to take multiple pictures of a wide scene and later stitch them together in to a panoramic scene
  • Movie - create movies (AVI)
Nov 26, 2007 | Canon PowerShot A60 Digital Camera
The best situation to use each of the shooting modes
The shooting modes are described as follows: AUTO (Factory default setting) Auto mode is used for regular photography. The camera automatically makes the settings for natural color balance. Other functions, such as the flash mode and metering, can be adjusted manually. Portrait Portrait mode is suitable for taking a portrait-style picture of a person. The camera automatically sets the optimal shooting conditions. Night scene Night scene mode is suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both your subject and the night background. SCENE Scene mode enables you to select one of the following scene shooting modes available in the menu. Landscape + Scene shooting Landscape + Scene shooting is suitable for taking pictures of landscapes and other outdoor scenes. This mode produces clear, sharp pictures with excellent detail, making it ideal for shooting natural scenery. Landscape + Portrait shooting Landscape + Portrait shooting is suitable for taking photos of both your subject and the background. The picture is taken with the background as well as the subject in the foreground in focus. The camera automatically sets the optimal shooting settings QuickTime Movie Quicktime Movie mode lets you record movies. The focus and zoom are locked. If the distance to the subject changes, the focus may be compromised. Landscape Landscape mode is suitable for taking pictures of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Self-portrait Self-portrait mode enables you to take a picture of yourself while holding the camera. Point the lens towards yourself, and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is fixed in the wide position and cannot be changed. My Mode Enables you to make settings manually and register them in the mode dial's mode so you can call up your own shooting mode whenever you want. Program shooting (P) Program shooting allows you to shoot using an aperture and shutter speed that the camera sets. You can set the flash, white balance, or other functions manually. Aperture priority shooting (A) Aperture priority shooting allows you to set the aperture manually. The camera sets the shutter speed automatically. By decreasing the aperture value (F-number), the camera will focus within a smaller range, producing a picture with a blurred background. Increasing the value will let the camera focus over a wider range in the forward and backward directions, resulting in a picture in which
Sep 04, 2005 | Olympus Camedia C-60 Zoom Digital Camera
Best situation to use each of the shooting modes
Program Auto (Factory default setting) Program Auto mode is used for regular photography. The camera automatically makes the settings for natural color balance. Other functions, such as the flash mode and metering, can be adjusted manually. Portrait Portrait mode is suitable for taking a portrait-style picture of a person. The camera automatically sets the optimal shooting conditions. Landscape + Portrait Landscape + Portrait mode is suitable for taking photos which include both your subject and the landscape. The camera automatically sets the optimal shooting conditions. Landscape Landscape mode is suitable for taking pictures of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Night scene Night scene mode is suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both your subject and the night background. Indoor Indoor mode enables you to take pictures while indoors by allowing the flash to reach farther away. Beach & Snow Beach & Snow mode enables you to take pictures of scenery containing white sand or snow. Cuisine Cuisine mode enables you to take pictures of food by increasing the saturation, sharpness and contrast settings to take sharp, vivid pictures of the subject. Self-portrait Self-portrait mode enables you to take a picture of yourself while holding the camera. Point the lens towards yourself, and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is fixed in the wide position and cannot be changed. QuickTime Movie QuickTime Movie mode lets you record movies with sound. The focus and zoom are locked. If the distance to the subject changes, the focus may be compromised.
Sep 01, 2005 | Olympus Stylus 410 / ? 410 Digital Camera
Shooting modes
The shooting modes are as follows: PROGRAM (P)/AUTO Modes. Used for general photography. The camera automatically makes the settings for natural color balance. In PROGRAM AUTO (P) the brightness (exposure compensation) can be adjusted. Portrait. Suitable for taking a portrait-style photo of a person. The camera automatically sets the optimal shooting settings to produce natural skin tones. Landscape + Portrait. Suitable for taking photos of both your subject and the landscape. This setting allows both the foreground subject and background landscape to be in focus. Landscape. Suitable for taking photos of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting settings to produce vivid blues and greens. Night and Portrait. Suitable for taking photos of your subject in the evening or at night. Since the shutter speed is slow, it is advised that you use a tripod to support the camera in this mode to help avoid blur from camera shake. Night Scene. Suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting settings. If you use the flash, you can take pictures of both foreground subjects and the background. It is advised that you use a tripod to support the camera in this mode to help avoid blur from camera shake. Sports. Suitable for capturing fast moving action without blurring. Even a fast moving object will appear to be stationary. Self Portrait. Enables you to take a picture of yourself while holding the camera. Point the lens toward yourself and the focus will be locked on you. The camera automatically sets the optimal shooting settings. The zoom is fixed in the wide position and cannot be changed. Movie Mode. Enables you to take a QuickTime movie.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Shooting modes
The shooting modes are as follows: Program(P)/Auto. Modes Used for general photography. The camera automatically makes the settings for natural color balance. In PROGRAM (P) the brightness (exposure compensation) can be adjusted. In AUTO mode you cannot use exposure compensation or panorama features. Portrait. Suitable for taking a portrait-style photo of a person. The camera automatically sets the optimal shooting settings. Landscape + Portrait. Suitable for taking photos of both your subject and the landscape. This setting allows both the foreground subject and background landscape to be in focus. The camera automatically sets the optimal shooting settings. Landscape. Suitable for taking photos of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting settings. Night Scene. Suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting settings. If you use the flash, you can take pictures of both foreground subjects and the background. It is advised that you use a tripod to support the camera in this mode to help avoid blur from camera shake. Sports. Suitable for capturing fast moving action without blurring. Even a fast moving object will appear to be stationary. Beach and Snow. Suitable for taking photos at the beach or on snow covered mountains; situations where there would be very bright conditions where the sun reflects off of sand or snow. Self Portrait. Enables you to take a picture of yourself while holding the camera. Point the lens toward yourself and the focus will be locked on you. The camera automatically sets the optimal shooting settings. The zoom is fixed in the wide position and cannot be changed. Movie. The movie mode enables you to take a QuickTime movie for either viewing on the LCD or on your computer. The movie will record as long as the shutter button is depressed and or until there is no storage space left on the memory in use. No sound is recorded.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Shooting modes
The Shooting modes are as follows: PROGRAM (P)/AUTO Modes Used for general photography. The camera automatically makes the settings for natural color balance. In PROGRAM (P) the brightness (exposure compensation) can be adjusted. In AUTO mode you cannot use exposure compensation or panorama features. Portrait Suitable for taking a portrait-style shot of a person. The camera automatically sets the optimal shooting conditions. Landscape + Portrait Suitable for taking photos of both your subject and the landscape This setting allows for both the foreground subject and background landscape to be in focus. The camera automatically sets the optimal shooting conditions. Landscape Suitable for taking photos of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Night scene Suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both the subject and the background. Sports Suitable for capturing fast moving action without blurring. Even a fast moving object will appear to be stationary. Beach and Snow Suitable for taking photos at the beach or on snow covered mountains; situations where there would be vey bright conditions where the sun reflects off of sand or snow. Self Portrait Enables you to take a picture of yourself while holding the camera. Point the lens towards yourself and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is fixed in the Wide position and cannot be changed. Movie The movie mode enables you to take a Quicktime movie for either viewing on the LCD or on your computer. The movie will record as long as the shutter button is depressed and or until there is no storage space left on the memory in use. No sound is recorded.
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Shooting modes
The shooting modes are described as follows: PROGRAM AUTO (Factory default setting) Program Auto mode is used for regular photography. The camera automatically makes the settings for natural color balance. Other functions, such as the flash mode and metering, can be adjusted manually. Portrait Portrait mode is suitable for taking a portrait-style picture of a person. The camera automatically sets the optimal shooting conditions. Landscape Landscape mode is suitable for taking pictures of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Night scene Night scene mode is suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both your subject and the night background. Self-portrait Self-portrait mode enables you to take a picture of yourself while holding the camera. Point the lens towards yourself, and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is fixed in the wide position and cannot be changed. QuickTime Movie QuickTime Movie mode lets you record movies. The focus and zoom are locked. If the distance to the subject changes, the focus may be compromised.
Aug 31, 2005 | Olympus Camedia D-395 Digital Camera
Hitachi 55HDT51 55 in. HD-Ready Plasma Television Logo
992 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
