Question about Roper RAS6233KQ Top Load Washer
My motor wont kick on at all
If I move the drum around or tip it up to expose the bottom and mess with it, it will wok for a load but the the motor quites. It sounds totally fine when it does work, the motor sounds like it is in good condition.
  • 198 Answers
Check the lid switch, probably needs replacing.
Posted on Feb 19, 2009
Problem with the 2003 GMC Envoy Blower motor resistor location
Need to take off the plastic kick guard off just below the glove box. Then you can look under the glovebox and you'll see the blower motor and the blower resistor module on the bottom of it. For even better access, open the glove box, and flip it upside down which will expose the connector for the resistor module that needs to be unhooked.
To move the glove box upside down, feel around in the openings just to the left of the glove box. You'll feel a hook like (spring loaded) metal piece that you can push back, that will allow the glove box to fall freely down.
Jan 11, 2011 | 2003 GMC Envoy
How do you replace the blower resistor
Jan 10, 2011 | 2003 Chevrolet TrailBlazer
Where is the blower motor resistor location
Dec 17, 2010 | 2006 Chevrolet Trailblazer
Location of blower motor resistor need to finf location and replacement
Dec 17, 2010 | 2003 GMC Envoy
Where do I find the blower motor control madule on my 2003 trailblazer
Dec 15, 2010 | 2003 Chevrolet TrailBlazer
Makes clunking noise when changing modes--does not spin dry
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Amana 3.2 cu. ft. Top-Load Washer
Want to replace motor brushes...any tips on this
I need to also, so please post what you learn. I found several examples for other WMs on YouTube (search brushes carbon washing machine) Note, I was able to get my Bosch Axxis WFL 2060 spin working again with the following quick carbon dust cleaning trick:
1) Unplug WM and tip up to a 45 degree angle and then safely stabilize so you can safely access motor from bottom. No need to take off back or disconnect motor.
2) Using a small tool like a 1/4 allen wrench or medium screwdriver start tapping repeatedly (for 2 mins) on the brush holders, and back metal clips that connect to the brushes, your just moving the dust around really.
3) Next using an alcohol damp cloth clean the motor commutator - on this motor it is easily exposed on one of the sides 90 degrees away from, and in line with brush holders. Hold cloth on commutator and turn motor, this will also make it clear if commutator is damaged. You cloth should be pretty dirt after 2-3 rotations.
Repeat 2 and 3 above a few more times cleaning up all the carbon dust off the commutator and around the brushes.
After that tip down and test again. A more thorough cleaning could be done by removing brushes and cleaning em - but this will buy you a few weeks/months of operation.
Sep 28, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Drum wont spin cant find belt inside machine
The belt is normally around the drum,motor, and idler arm pulley.
If you remove the front of the machine it will normally expose the drum and you will see the belt around the drum...if the belt is not around the drum then it could indicate that you have a broken belt.
Sep 27, 2009 | Kenmore Dryers
How do I replace the belt
you need to remove the drum.route new belt with ribs on motor pulley.and backside of belt on sping loades idler pulley
Sep 24, 2009 | Dryers
Dryer will not start
I had the same problem and this is how I fixed it ,,, i did a comfortor ,very heavy when wet .....next day i tried to do a new load ...when I turned start button all i got was a hum... I removed screws just inside door at top of lip this releases top of dryer,,,, exposing drum i rotated drum clockwise to check condition of belt ....looked good ....mine is 7 yrs old ...to soon to be motor problem ....so while turning drum i held start button on and finally motor kicked in and this solved my problem...you might be able to accomplish this without taking of panel ..though you wont be able to see belt ....by turning the drum from inside dryer while someone else turns on start button
Oct 25, 2008 | GE Profile Prodigy DPSR513GA Dryer
Roper RAS6233KQ Top Load Washer Logo
21 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
