Question about Frigidaire PLD4555RFC Dishwasher
I waould like to know the amperage on the Frigidaire pld4555rfc I want to wire it in a new house. 15 or 20 AMP
    President:
  • 1,214 Answers
Check the NEC and your local ordinances, but I believe a 20 amp circuit is over kill.
Installation instructions indicate either.
Posted on Jan 28, 2009
How many amp it pulls, what size breaker I should use.
the amperage is on the model plate attached to the item
most plug items run a 10 amp circuit breaker for 110 -240 volts as that is the max. amperage allowed for the house wiring and outlet socket
Feb 02, 2016 | Heating & Cooling
I have a PLD4555RFC dish washer and I'm getting the err display it will runn thru a whole cycle and right before the end it gives the err message is this solvedby doing the same sequence
Hello Ken R, thanks for the post!
I understand that your Frigidaire dishwasher, PLD455RFC, is going through the whole cycle and then will provide you an ER code. The code ER on a Frigidaire dishwasher stands for a membrane switch failure. Generally that means that the main control board has detected a stuck key or a key pressed in for more than a minute. I see you have already attempted to reset your appliance and you are still receiving an ER code. Some possibilities that could be causing this problem are a wiring issue or main control board. These intricate parts do require precision and patience, therefore when replacing the exchange of electrical components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. I hope this is helpful. -Matt
Jul 29, 2014 | Frigidaire PLD4555RFC Dishwasher
I want to know what amperage it is to install the right circuit breaker
Dont burn your house down just to get your vacuum to work circuit breakers protect the wire in your house 14gauge wire needs15 amp breaker 12 gauge wire need 20 amp breaker
Feb 27, 2011 | Vacuums
1 question can Cutler Hammer breakers have the amperage feed through the breakers. To the breaker box and from the box grid to the load. Does it matter which way the amperage is fed through the breaker?...
There seem to be several questions mingled in with those 2 questions.
1) Amps can go either way
2) Breakers trip when heat exceeds certain level. Heat is caused by amps.
3) You want to add a subpanel in garage.
I do not know the code in your area for installing a subpanel.
Your plan will work by connecting 6 gauge wire to main breaker, and new 60 amp breaker will protect wires between main box and subpanel.
Remember, wires going into main breaker cannot be turned off without pulling meter.
Some areas require license to pull meter.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
4) To work around license and meter-pull, simply replace a 240V breaker in main panel with your new 60 amp breaker.
Then move breakers around to match new set-up.
New subpanel can accommodate two new 240V breakers and one new 120 Breaker
http://waterheatertimer.org/How-to-install-a-subpanel.html
5) 6 gauge wire is correct for 60 amp breaker.
6) I'm not sure what you mean by the box rails?
7) Do you need more amperage on main service?
This means adding a larger service panel with 150 Watt or 200 Watt main breaker.
Some areas require service upgrade when remodeling or adding circuits.
8) How to figure total amp draw at your house.
Add up total watts being used.
For example you have 1/2 Hp motor
754 watts per Hp
1/2 Hp = 377Watts
Volts x Amps = Watts
Amps = Watts divided by Volts.
377 Watts divided by 240Volts = 1.57 amps (plus a bit more amperage when motor starts)
40 watt light bulb divided by 120Volts = .33 amps
Double oven has label located inside door that shows upper and lower wattage.
Dishwasher, dryer, big screen TV, satellite receiver all have labels that show wattage.
Water heater has label that shows wattage of each element.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment for more help
Feb 18, 2011 | Cutler Hammer 100 Amp Main Breaker...
The button is locked and it wont unlock the air dry setting, so i cant wash my load
Try resetting the breaker, If that does not work you would either have a control board problem or the control panel toucpad itself. Here is a link for a breakdown of the unit, and Part ordering info:
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Dishwasher-Parts/Model-PLD4555RFC3/1428/0130000/R0809006/00001?blt=06&prst=&shdMod=
Sorry I did not have the part at my store myself to help:
http://stores.ebay.com/Discount-Appliance-Parts
Sep 16, 2010 | Frigidaire PLD4555RFC Dishwasher
I need to flip my circuit breaker on my dishwasher to make it work
you may have to many large appliances on the same circuit. you might try to
see how many appliances are on that circuit. if it is so try turning off other appliances and just run the dishwasher to see how it runs. if this works you
may need to increase the amperage on the breaker or split the electrical
circuit. if its on its on breaker try increasing the breaker amperage. good luck!
Jul 23, 2010 | Frigidaire PLD4555RFC Dishwasher
I have a 220v 100 amp circuit breaker that feeds a sub-panel. The sub-panel has 3 circuits: a)60 amp Heater (unit 1 in house) b)60 amp A/C (unit 2 in house) c) 40 amp for pool equipment. The 100 amp...
your a/c uses the blower motor from the heater to distribute air check for loose wire connections that will raise amperage and also make sure you have the right size wire to each unit 40 amp should have 8 awg(copper) wire and 60 shouldbe 6 awg i think if the wire is to small=heat= higher amperage
Jul 14, 2009 | Heating & Cooling
Brand New overflows PLD4555RFC3
If this is new construction or a new disposal, check the hose that drains from the dishwasher to the disposal - the installer may have forgotten to remove the plug when they connected the hose.
Jun 24, 2009 | Frigidaire PLD4555RFC Dishwasher
PLD4555RFC Frigidaire Professional
Visit this page. http://www.frigidaire.com/manuals.aspxEnter your model number and you'll be able to download both the installation guide and the manual.K
Jun 08, 2009 | Frigidaire PLD4555RFC Dishwasher
PLD4555RFC: Low Rinse Agent Light Will Not Go Out
I've disconnected the sensor in the dispenser for my new Frigidaire dishwasher. The setup is too unreliable in my opinion and is a potential source of headaches. I had the same problem. I studied the design and it's too easy for the floating magnet sensor in the rinse aid reservoir to stick thereby not actuating what is called a reed switch to toggle the control card LO ckt light. Mine has the electronic control front panel.
Jan 07, 2008 | Frigidaire PLD4555RFC Dishwasher
Frigidaire PLD4555RFC Dishwasher Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
