How do i get my mouse to work on my Laptop?? - Computers & Internet
  • 2,229 Answers
Well, what type of mouse are you trying to use? A USB mouse should work once it's plugged in. A wireless mouse should do the same on most modern systems with an extra step:
You will have to push the "connect" button on the bottom of the mouse.
Posted on Jan 29, 2009
My mouse doesn't work on my laptop
for some mouses, there is an installation cd and you should install before you connect your mouse in usb slot.
If there is no installation CD then the wire connecting mouse to usb must have been ruptured
May 01, 2012 | Sigma Mouse
After not using my laptop for several months (it was plugged in however) my USB mouse will not work now when I boot up my Toshiba Satellite laptop.
Here are some trouble shooting steps you can try relatively easily....
If the mouse connects via a USB cable, try connecting it on another USB port while the laptop is on.
If it is an optical mouse, check to see if the LED(s) underneath are lit. Change ports until LED lights.
If you have another computer also with a USB mouse and it is working, try a mouse exchange. If the non-working mouse also does not work on the other computer and the mouse from the other computer works on your Toshiba Satellite laptop, the problem is likely with the non-working mouse.
Finally, If the non-working mouse is a wireless one, its battery may be dead. Try a new battery in it.
Feb 14, 2011 | Computers & Internet
My mouse just stopped working so I disconnected it from my laptop. Now when I try to connect it the computer is not finding the hardware. What should I do?
Probably the mouse is already defective. To confirm though, try using the mouse in another PC, if it works, try connecting it again to your laptop. If it works then fine, if still not, try using another port if this is a USB mouse. If still your mouse will not work, try using a known good mouse in your laptop, this should work and in this case just buy a new mouse. If however a known good mouse will still not work on your laptop, then another possibility is the USB ports are disabled. You can enable this by entering the unit BIOS setup which is normally done during power-on before the unit boots up in the OS.
Jan 12, 2011 | Computers & Internet
I purchased a HP laptop, Windows 7. I installed
You have to install the software that came with the wireless mouse. I have several, and some will and others won't work without the software. That is 90% what it is.
May 17, 2010 | Logitech Cordless Mouse
My laptops mouse is not working
IF you are referring to the external mouse attched to your laptop
then please check the same mouse with some other systm to verify if
the issue is with the mouse or with the laptop.
if the mouse is working fine with other system, then you need to
contact the service provider of your laptop.
Otherwise you have to buy a new mouse.
If you are referring to the touch pad of your laptop not functioning
properly, then please check the touch pad settings through control panel.
otherwise please shut down the laptop.
Take out the baterry out & wait for atleast 1-2 minutes.
Reinsert the Battery in the laptop & reboot the laptop.
Check if the mouse is working fine or not.
If the problem with the laptop still persist, please contact your
laptop service provider for further support.
Hope this will help you in resolving the issue.
Cheers!!!
Vivek
Dec 26, 2009 | Computers & Internet
I use cordless mouse with desktop computer.Can I use same mouse with my laptop? Charles.
yes you can use your mouse with laptop to.
For that you need usb wireless or bluetooth dongle for connect wireless mouse to laptop.
Then install cordless mouse driver in laptop then it works fine.
Let me know if you need further assistance.
Thanks.
Nov 04, 2009 | Logitech Cordless Mouse
I have a laptop n its a dell inspiron 2200 n the mouse on the laptop doesn't work how can i fix that
if the mouse on the built in to the laptop doesnt work, try getting a usb mouse that will plug into your laptop
Jul 23, 2009 | Dell U0636 Mouse
IBM Optical Scroll Mouse doesn't work (Device Driver Problem)
connect your mouse. then restart your laptop do not remove mouse while restarting laptop. if not work after restart there is a problem in your mouse IC.
Jun 02, 2009 | IBM Optical Travel Mouse 2224P0480
My laptop mouse wont work
do you mean the mouse integrated in the laptop or an external USB mouse?
If it is the integrated mouse, try to get an USB mouse, plug it and wait until your laptop recognize it, assuming you are working in Windows XP right clic on My Computer, clic on Properties --> Hardware --> Device Manager , double clic on Mice and other pointing devices, once here, look for the mouse of your laptop (do not mis identify it with the external mouse that you just plugged) right clic on it and clic on uninstall.
Restart your laptop, once in windows again it will recognize the mouse as a new device and will install the drivers again.
Feb 24, 2009 | Acer Aspire 5920-6727 Notebook
KVM switch mouse trouble
Does a mouse work if plugged directly into the laptop? Sometimes you have to change a laptop in the BIOS to allow a PS2 mouse in addition or instead of the touchpad. It may not be recognizing the KVM as a mouse. Try plugging the mouse right into the laptop and see if that works.
Mar 24, 2007 | Belkin F1DK102P 2-port KVM Switch
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
