Question about Microwave Ovens
Sanyo Em258TS upon opening the door it get stuck. Its one of those push would I repair something like that...
  • 1 more comment
  • Hils
    Hils Jan 29, 2009
    No its more of a Push release push release untill it finally opens on you. if thats clearer for you. Would you believe it that is the only problem I have with it.
  • Hils
    Hils Feb 14, 2009
    When I opened the panel door the latch is missing the spring. but hopefully the part I order will resolve my problem thanks again...
  • William Miller
    William Miller May 11, 2010
    You mean the door is sticking as you try to open it?
    Or is the door open button sticking as you push it in?
  • Microwave Ovens Master
  • 9,098 Answers
Chances are the rear surface of the door open button and/or the front surface of the door open lever have worn away due to use, or there may be a misalignment of the door latches.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Posted on Jan 30, 2009
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ... > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
Microwave doesn't recognize open door.
Most of that is handled by the door switches. You may have one sticking. Look for a stuck down plunger on the top of the switch or any browning around the plastic insulators over the terminals. You can also see some melted plastic where the terminal comes out of the switch to tell you it is bad. If you find that, remember to repair or replace the wires to the switch or it will just happen again.
Sep 29, 2017 | Whirlpool GMH6185xvs Microwave Hood...
I'm unable to open the microwave door on model Sanyo EM-S8586W as it appears the spring is broken. How do I remove the cover so I can replace the spring please?
make this steps and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Oct 26, 2013 | Sanyo Microwave Ovens
Proline 850 Watts Microwave Oven Door release does not open the door. Model 3535T May1993 Made in Korea. There's no resistance when I try to open the microwave door by pressing the door release push. As...
This has actually happened to other people? When this happened to me I was shocked, I've never in all my years have ever dealt with something like this. I had tried to fix it for a good two weeks. I had to break down and call in some <a href="">door systems in Chicago</a>, to help out. I hate fixing doors. I have the worst luck with them.
Mar 29, 2011 | Microwave Ovens
Broken door opener button
sounds like the door latch hook is broken you will have to seek a repair man for this
Feb 12, 2010 | Whirlpool GT4185SK Microwave Oven
MIcrowave runs with the door open also
your door switch is mis-adjusted,furthermore the other safety switch on the door should have blown the power fuse in the unit,because by design for safety it produces a short circuit if door opens under operation,so if door was taken off and replaced it was not adjusted properly
Aug 15, 2009 | Sanyo EM-P790 Microwave Oven
Won't whut off when open door
The microwave running with the door open can be dangerous.
It's most likely the switch in the door stuck in the closed position. Or it has failed/broken in the closed position.
Sometimes the switch is just a button sticking out of the cabinet where the door pushes on it when closed -- sometimes the door latch pushes on a switch inside the latch receiver in the cabinet.
If cleaning around that switch doesn't solve the problem, you should take it to a repair shop.
Apr 28, 2009 | Microwave Ovens
Sharp Microwave model R-1850A door won't open
Hi ,there are two posibility to repair . 1. by ordering parts to the web site of sharp .
2. You may check from shop same type of part bring sample or in the appliances center near you.
Jan 14, 2008 | Sharp R-1850A Convection/Microwave Oven
Door is jammed
It's likely that the door open lever is broken. It is located behind the control panel, right behind and in contact with the door open button. With power unplugged, you or a friend can remove the screws in the outer wrapper, then lieft up and back to remove it. You can see then the door open button / lever area and you should be able to figure out where to push with a dull knife to pop the door open. Then you can see about getting replacement parts. If your unit has a model tag, it may have company contact information, or you can contact the place you got it (phone is best) to see if you can get parts at all. This info may or may not be correct: "Cascade's head office is located on Auckland's North Harbour" 15 Ra Ora Drive East Tamaki Auckland PO BOX 58960 Greenmount Auckland (09) 2739136 Fax: (09) 2739137 Good luck.
May 02, 2007 | Sanyo EM-G2585W Microwave Oven
Microwave runs when door open
This is probably a a bad door switch or door switch mount. Chances are only the fan and light are running when you open it, but better safe than sorry. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure but not the only one. I have a text file called "doorsw.txt" which helps in diagnosing and repairing door switch problems, and a file called "safety.txt" which is of vital importance. You can find these files by searching at (not Google) for this: microwave display safety.txt If you still have a problem, please write back with more detail. Be safe!
Nov 20, 2006 | Sanyo EM-P790 Microwave Oven
Microwave Ovens Logo
48 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
