Fan/Engine noise. I bought a used tv, and it was fine in the store, but when we got it home and plugged it up, it started making this loud noise like a fan turning and it is annoying. Does anyone know what this is? The tv is worth some money and it has a great picture, please let me know if I can get this repaired?
    President:
  • 1,214 Answers
Dig down inside and find where the noise is coming from. Just don't stick you hands inside while the TV is on.
Posted on Jan 28, 2009
My zenith 56" home theater tv I bought has been having a horrible humming noise forever, but I bought it used and thought it was just because it was old. Now the tv makes a very loud humming noise and...
Check and replace all the main filter capacitors at its main power supply regulator section [SMPS] circuit.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 10, 2014 | Televison & Video
Engine making loud sound when attempting to start.
Diesel or Petrol?
Any warning lights on on the dash?
Oil pump working ok?
Check your timing belt?
Dec 04, 2012 | Cars & Trucks
My hln5065w started making a loud noise like a fan noise upon startup recently. The color is fine (I've read the color wheel w/loud noise problems). It has been doing this for the past week, previously...
The loud noises came from the tv with a colors wheel design in it have to be replaced every few years,because the spinning of the colors wheel disc are spinning in very high speed in RPM to have it colors for the tv to operate correctly,the humming,loud motors noises and eventually the effect of the tv colors.The colors wheel disc are worn out and spinning hitting it axes motor,the colors wheel must be replaced to solved this problems.
Jul 21, 2011 | Samsung HLN5065W 50" Rear Projection...
HI, my coolermaster laptop cooler, the U2 with 2 optional fans have been acting loud. only one fan has been acting up. it makes loud noises while the other one is silent. like a grating noise kind of. cant...
Sounds like the fan is going out. I would take it back to the store and swap it for a new one. Alternatively, if you decide to keep it you can try to put a drop of 3-in1 oil in the center of the fan to prolong and/or fix the noisy fan.
May 26, 2011 | Cooler Master NotePal U2 Notebook Cooler ...
Just brought home a fedders aep09d2b*b portable air conditioner. bought it used. it worked well there but when I plugged it in at home it is making a lot of fan noise - more noise the higher the fan...
If it was running fine before and you moved it and it's making noise, it sounds like something fell against the fan blades. The reason it sounds worse when you turn it up is that the fan is running fast. Grab a flashlight and check to see what might have fallen.
May 12, 2010 | Fedders A6P09D2B Portable Dual Hose Room...
Loud noise coming from Lamp area
The fans in these generaly do not go bad, the part nubmer for the lamp cooling fan is 265943. But my guess is that the color wheel is starting to go out of you light engine. I am not sure if these are still avalable but the part nubmer for it would be 267888. Worst case you could send your engine in for repair engine nubmer should be 265864 or order a repacement try this site. GOOD LUCK http://www.moduslinkptstvboards.com/Default.aspx
Aug 13, 2009 | RCA HD50LPW165 50" Rear Projection HDTV
Sony 42" Grand Wega makes noise constantly when running
That is correct, it would be fan noise and fan will be replaced.
Let me know exact model number to help you in finding fan in parts stores.
Feb 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Model HSS25IFMCCC GE Refrig motor/fan making loud noise
UN THAW YOUR REFRIGERATOR FOR 8 HOURS IF IT STOPS GREAT IF NOT.REPLACE YOUR FAN/IT IS LOCATED BEHIND THE TOP PANEL OF YOUR FREEZER.UN PLUG YOUR FRIDGE FIRST.BUY THE PART AT A APPLIANCE PARTS STORE,AND YOU CAN DO IT IT IS A EASY REPAIR.
Jan 16, 2009 | Hotpoint HSS25GFP Side by Side...
Loud noise from tv
if this is a very annoying screeching or sqeualing type sound, it is, in my experience, the "color wheel" which is located inside the lite engine. this is a replaceable component whick costs about $110....i've done this repair many times with no problem....
Oct 30, 2007 | RCA D44LPW134 44" HDTV
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
