Motorola RAZR V3 Cellular Phone
Problem for Motorola RAZR V3
Phone dies quickly after charging
By Bob123 on Jul 25, 2007
Can i find out why my phone dies out after i fully charge the Battery?
Same Problem
Feb 28, 2009
-   I have the same problem with my Motorola Razr. Its not the battery. I bought a new battery and it did the same thing so I took the battery back and they gave me another one and it did the same thing. Its a Motorola thing. I have had problems with every Motorola I have had. They just make junk phones. I think I am going to try an LG next time. My friends all have had good luck with them. -   Sdkooll
Dec 03, 2007
-   I have the same problem. A brand new battery and charger the battery charged over night lasts only 1 day. I had a cell tech look at it and he said it had old software so he updated it. Now the battery lasts 2 days with little or no use. The phone is 5 months old, when new it lasted 4-5 days easy with lite use. The problem is the phone thinks the battery is low, but it's not. When the phone was new and the battery was low I'd plug it in and the battery symbol would show 1 red bar flashing. Now I use it for an hour after the phone starts beeping and the battery symbol shows red and says low battery (to make sure it's ran down). But when I plug in the charger in the battery symbol shows 2 bars green? This tells me that the phone thinks the battery has over half charge left? I sent it away to have it serviced by Motorola, they sent it back with a new screen and supposed new software? It still won't hold a charge for more than 2 days and it starts beeping! I know what the problem is, but I guess Motorola doesn't now how to fix it!-   Slim25
Nov 21, 2007
-   My Razr dies very quickly after charging...even when it's turned off. It may last one day on with little to no use and possibly a day and a half turned off. I've changed battery and charger to no avail. Nancy
-   furkidhome
Best Solution
posted on Jul 25, 2007
Helpful)
zeusfaber
Rank: Guru
Rating: 87%, 344 votes
It would be helpful to know just how quickly the battery is going flat, and I'm assuming there's no history of the phone having been damaged, but...
Try swapping the battery for one from a friend's phone. If that cures the problem, you need to buy a new battery (they don't last forever).
Otherwise, try charging the battery fully in a friend's phone using their charger, then see how long it lasts. If this lasts much longer, the problem is that the phone/charger combination isn't charging the battery properly. Mix and match chargers and handsets (mark which are yours before you start, or you will get mixed up) to identify where the problem lies.
If the battery isn't old and tired, and the phone is charging it properly, then the problem must be that the phone is drawing excessive current.
This could be because you've got it set up to do some power-hungry thing (backlight continuously on, playing MP3s or FM, promiscuously Bluetoothing or IR communicating, etc). Shut down all the functions you don't actually need at the time and see if that makes any different.
Once you've eliminated all those, you're left with the liklihood that the phone has a fault which is making it draw excess current. Not good news, but at least you've eliminated all the other possibilities.
A.
Comments:
Jul 25, 2007
- Addon to paragraph 3 line 2: "..how long it lasts in your phone".
Jul 27, 2007
- "about an hour" doesn't sound much like the "power-hungry application".
Sounding more like "old and tired battery" (which isn't a tragedy) or "defective phone or charger" (a bigger problem).
A.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jul 31, 2007
Somewhat Helpful)
astridkas
Rank: Apprentice
Rating: 70%, 2 votes
What is supposed to be the expected battery life of this phone? How often does one need to get a new battery? I've had a similar problem. It keeps going down to low battery usually after 20 min. of talking or a couple of hours sitting. Then I go to charge it and the battery shows as charge complete in about 20min.
When it starts to think it's low again It will keep beeping that it has a low battery, which is so annoying. It used to go out a few hours after that, but now it doesn't go out for almost a day, and I have to keep hearing that beeping if I want to let the battery die down completely before recharging.
Anyway, what I'm thinking is, if you have a problem similar to this, maybe it's not actually the battery, but software or firmware in the phone. Because for me it seems that it just keeps saying that the battery is low even when it is not, unless it's plugged into the charger. And how annoying indeed- it would be nice if you could turn the low battery audio alert off.
Was this helpful?
Yes
No
Solution #3
posted on Jun 26, 2009
Not Rated)
wescoty
Rank: Apprentice
Rating: 0%, 0 votes
i have the same thing as the rest of you my v3 will not last a day and i have put two new batteries in it what next??
Was this helpful?
Yes
No
Solution #4
posted on Jul 26, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Battery takes about an hour before dies out
Popular Solutions for Motorola RAZR V3 Cellular
Questions and Unsolved Problems for Motorola RAZR V3 Cellular
Do you recommend Motorola RAZR V3?
Answer
Answer
my v3 razor says bootloader o7.00 sw version battery ok, ok to program, connect usb data cable.. why... (More)
Answer
I can't get the keyboard back light to turn off when the phone is closed. Battery life isn't very... (More)
Answer
i want to download pictures from my motorola v3 to my pc. where can i find the application/... (More)
Answer
problem of code of motorola i455 an encender
Answer
I have a min storage card from a previous phone. I cant get it to work with my razor it fits but my... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Cellular Phone Experts
Top Cell Phone Repairmen
CPR
(800) 818-8800
We offer hight quality OEM such as travel charges,...
CPR
(918) 955-1100
The Cellular Phone Repair Center opened in March...
cellularphonerepaircenter
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
