Question about Maytag Atlantis MAV6000 Top Load Washer
Very loud noise when washer is in wash mode,
It sounds as if a gear is stripped.
  • sdarling83 Jan 29, 2009
    It agitates somewhat. If took a socket and turned the drum and it appears that something seems stripped in the transmission. It catches about half way through a turn of the wrench. I purchased this washer in 2003. How would i tell if the transmission is still under warranty?
  • Anonymous Feb 03, 2009
    During agitation, the washer has begun to make a very loud noise. I've found that it is not spinning out, but agitating during the spin cycle, too. I just made some inquiries on repair and was told that the transmission has a ten year warranty...BUT...$225. for installation plus $60 in seal/bearing kits. Look on the Maytag site for a repair business in your area.
  • 65 Answers
IT COULD BE SOMETHING IN THE TRANSMISSION. DOES IT AGITATE AS IT IS SUPPOSED TO? IF IT DOESNT, I WOULD SUSPECT THE TRANSMISSION, IF IT DOES, i WOULD START BY LOOKING AT THE PUMP. THERE IS A PIECE OF METAL THAT HOLDS THE BEARING CENTERED IN THE PULLEY OF THE PUMP. OVER TIME, THE METAL CAN COME OUT AND MAKE CONTACT WITH THE BOTTOME OF THE PUMPS MOUNTING PLATE CAUSING QUITE A NOISE. ALSO, DEPENDING ON WHEN YOU BOUGHT YOUR WASHER, THOSE MACHINES HAD A TEN YEAR PARTS WARRANTY ON THE TRANSMISSION.
Posted on Jan 29, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Why does my washer making a VERY loud noise while spinning. So loud you could hardly stay in same room. Ususally its pretty quiet. Then I heard something that sounded like a gear (?) being stripped or
2 possible things. the spinner drum bearings are giving up. This can show as a rusty water dribble under the machine.
The motor bearings are giving up.
Both of which require a good DIYer or an appliance engineer.
Aug 05, 2014 | Maytag Washing Machines
We have a Bosch WFK 2401 that is approximately 8 years old. I am not sure what cycle it was on when all of a sudden a loud noise started coming from the washer. Sounded like a gear stripping. A loud...
Check to see if inner drum is loose indicating bearing problem..Also check two springs on top of tub evident with lid off they can snap/ good luck
Sep 29, 2009 | Bosch WFK 2401
Loud whining noise when my washer is spinning
could be two things
1) thrust bearing
2) transmission
Jun 11, 2009 | Maytag MAV6200 Top Load Washer
NAV5800a top loader washer
The inside of your agitator became worn, and possible strip out the spline that allows the agitator to properly grip the shaft. The loud noise mustly occurs during the spin cycle. If you hear this loud noise your load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
Sep 02, 2008 | Amana NAV5800A Top Load Washer
Kenmore 90 Series Washer Noise--Won't spin
For Tegres
If the noise is only when there is water flowing, check tighten the screws that mount the water fill solenoid valves to the case. The solenoids operate on line current so they vibrate at 60/50Hz (local suppply frequency) if they are loose at all, the noise is loud the body acts as resonators
For SRONEAL, that symptom describes coupling failure exactly, have you removed the coupling to check, often times the motor side hub is stripped, but there is no visible external damage
Jul 23, 2008 | Kenmore 15864/15862 Top Load Washer
Washer won't drain, makes loud noise
This problem, or some variation thereof evidently is very common with these Whirlpool Washers!  I have same problem.  So far, best I have found is at  http://applianceguru.com/forum2/5958.html#
diagnosis by someone who knows.  What William Burk says there makes sense.  However, to get to the drive block there's quite a bit of disassembly required.  I am stopped because I cannot get the spanner nut off.  Hope this gives you some help toward finding a more comprehensive answer
Jul 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 80 series top loading washer won't agitate and is noisy
Sounds like u may have broken the coupler gear between the motor and transmission... the replaced the belt with these gears on this model... But should go fill & pumb water out and NOT spin Or agitate... IF these gears or broke or stripped... heavy loads like u  said would do this... recheck and see if wash will pumb water out But will NOT agitate or spin.. IF so the above is your problem  and is Not to hard to repair  or much money
Below is a pic with the motor remove the white piece in the middle is 1/2 of the gear system with a rubber piece in the middle (not there)  and another like gear on the motor
sounds like these gears may be broken or stripped on your washer
Oct 27, 2007 | Kenmore 24032\24036 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
140 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
