Question about Toshiba Satellite M30-S350 Notebook
Toshiba Portege 2000 has a yellow power cord light flashing and will not power up.
Toshiba Portege 2000 PC Notebook asking password when power on how to solve
After you logon, you can remove the account password in Control Panel.
If you forgot Windows logon passowrd, you can create a Windows password reset disk to reset your lost or forgotten Windows password, i have created one with the tool Windows Password Breaker and reset my administrator password successfully.
Dec 12, 2010 | Toshiba Portege 2000 Notebook
My Portege M400 will not turn on with the battery installed. It will work if you remove the battery and use the power supply. The power light only blinks yellow while the battery is installed. I have tried...
You look very much the unlucky owner of a busted battery.
I'm afraid the battery will have to be replaced. Meanwhile, do not use it with the power supply; not only it will do no good, as you already determined, but it might damage the power supply itself.
Jan 03, 2010 | Toshiba Portege M400 PPM40U01000E Tablet...
My toshiba portege M400 laptop will not start up, when I turn power on the power light starts blinking yellow and does nothing
This happened to me. The computer will not work with the battery in it.
Solution: Take battery out and plug in without battery... It should work,
You will need to get a new battery
Sep 19, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
I got the right info about toshiba portege 4000 battery on http://www.adapterlist.com/toshiba/portege-4000.htm toshiba portege 4000 battery but i not sure whether it will fit my notebook or not.
TOSHIBA Portege 4000 Series replacement Notebook Batteries, buy Portege 4000 Series battery and other goods are brand new and one year warranty! ship to most countries http://www.power-tool-battery.com/notebook-battery/toshiba-portege%204000%20series-1001022.htm
Feb 18, 2009 | Toshiba Portege 4000 Notebook
Toshiba without battery
1. If the batteries are dead then there's no way that you can charge them again. You're better off purchasing a new one. You can purchase one online by visiting the ToshibaDirect website or by calling them on 1-800-316-09202.
2. Yes, you can use the power cords to run the computer. Just plug them in using the power cords even with the batteries removed and it should work fine.
3. Yes you can but you might experience some current fluctuations. This is negligible on a CMOS battery though.
Aug 14, 2008 | Toshiba Portege R100 Tablet PC
The power cable light on my Toshiba Portege 2010 flashes yellow/orange when the plug is inserted. Computer will not turn on (green light on power button doesn't even come up). Have tried: 1) starting up...
One thing could be that your A/C adapter has failed resulting in your battery not being charged. This would explain why you're experiencing the same symptoms w/ or w/out the A/C adapter.
Apr 04, 2008 | Toshiba Portege 2010 Notebook
Toshiba A25-S207
That flashing light indicates that the laptop is not getting power, check and test your power cord. That light should be light solid when plugged in. good Luck
Sep 18, 2007 | Toshiba Satellite A25-S207 Notebook
Toshiba Satellite M30-S350 Notebook Logo
66 people viewed this question
Top Toshiba Computers & Internet Experts
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
