Question about Panasonic KX-FPG175 Plain Paper Thermal transfer Fax
Language change on handset and base station
Somehow my unit got changed to French and I need instructions on how to reset them to English
  • 1 more comment
  • Anonymous Jul 28, 2007
    I had the original manual and as the answer was not in the user manual the reset did not change the language I had to buy the service manual to fix my problem
  • Anonymous Nov 11, 2007
    PANASONIC KX-90-CL-W I HAVE A PROBLEM IN LANGUAGE I WANT TO CHANGE IT IN ENGLISH
  • mmaahs Mar 26, 2009
    my faxes are being printed in french and i need them printed in english
    President:
  • 1,114 Answers
You can get the manual on the link below but I see no option for setting the language! However there is a reset command on page 75, perhaps that may help? http://service.us.panasonic.com/OPERMANPDF/KXFPG175.PDF
Posted on Jul 26, 2007
SOURCE:
How do I reset all my face book pages to English.Somehow I must have changed it to French
Go to the menu and pick Account Settings" then pick Language. The first item in language is what you want to change.
Sep 10, 2017 | Book Computers & Internet
I cannot register the handsets to the new base station I had an 8100-2 base that quit working. I bought a new 8100-1 base. Can I change the MAC ID on the phones so they will accept the new base station?
If you cannot register the handset then here are some possible causes and solutions for them.
Cause 1:The handset and the base station were not prepared for registration.
Solution: Unplug and then plug in the power adapter.
Cause2:The handset or the base station has not been entered into registration mode.
Solution: See User Manual for correct registration of base station and handset.
Cause3:The base station is registered full.
Solution: Press [Page Key] on the base station to page the registered handsets, then perform the deregistration operation. Finally, register the handset you want to use.
Here is few more of additional info. if you want:
Register the Handset to the Base Step 1:
Place the accessory handset in the base station of the system. For some simple systems this may be all you need to do to register the new handset. If so, the LCD screen will read "Registration Complete."
Step 2:
Press the "menu" button on the base station, scroll down to "register handset" and press "ok."
Step 3:
Press and hold either "#" or "OK" (depending on the brand) on your handset until your hear the indicator tone. At this time the LCD should confirm the handset is registered.
Reset Handsets with the Base Step 1:
Clear the registration information from the base if you want to register your handset to a new base.
Step 2:
Hold [] and [#] down on the base for a minimum of 5 seconds or until the "System Reset" menu appears.
Step 3:
Choose the "deregister" option from the menu and scroll down to the handset you wish to remove.
Step 4:
Press "OK" to de-register the correct handset. Press "yes" when you are asked if you are sure, and wait for the confirmation tone.
Reset Handsets without the Base Step 1:
Hold [] and [#] down on the phone for a minimum of 5 seconds until the "System Reset" menu appears.
Step 2:
Choose the "base unavailable" menu, select "yes" and press the "OK" button.
Goodluck,
Please don't forget to rate the solution.
Mar 21, 2008 | Vtech IP 811 Cordless Phone
Manual download for siemens gigaset as290
You probably won't need a manual if you change the phones language to English.
To do this press Menu then the number keys 4 - 2 - 1 in succession.
Then scroll through the languages available until you find English then press the OK key.
If it a brand new AS290 you first have to Register each handset by placing each of them in turn for 10 minutes in the Base Station.
Simple eh :-)
Jun 12, 2012 | Lands Phones
I am vacationing in the USA from Switzerland. I just purchased a Nokia E71 cell phone and it is configured in English. How to change the language to French language?
Press the "Menu" button and locate the "Settings" (should look like a spanner), press "Ok" or "Select", once it's opened, locate the "phone settings" (it looks like a phone receiver or like a mobile handset) using the up and down key, open it and then the again select the first from the list (that should be theLanguage settings), once it's opened, you'll see the english language written in english as "English", select it [or you can just select "Automatic" if it's default language was "English"]. Now, the language of your mobile will change back to English.
If you need further help, let me know with more details.
Good luck.
Thanks for using FixYa.
Sep 01, 2010 | Nokia E71 Smartphone
Model 21028GE3-A multihand phone
To change the language used by the answering machine, look behind the base. There are four buttons in back, one says Language. Press it until you hear the language that you want.
Sep 06, 2008 | GE 21028GE3 Cordless Phone
CHANGE LANGUAGE
Press and hold the skip key on the answerig machine for two seconds. You will then hear english selected. It took me 30 mintes, but I finally found my instructions manual in english! lol
Dec 10, 2007 | GE 25951EE2 Phone
Language
go to settings /phone settings/language and change it to french
Sep 23, 2007 | Uniden TCX905 Cordless Expansion Handset
I cannot change the language setting
To return the base announce language to english press and hold the skip button for two seconds. To change the display language in the handset press the flash button, then use the CID button to sellect english, then cycle thru the rest of the menu by pushing the flash button until done. Hope this helps!
Apr 21, 2007 | GE 27995GE2 Cordless Phone
Open Questions:
See all Panasonic KX-FPG175 Plain Paper Thermal transfer Questions
Panasonic KX-FPG175 Plain Paper Thermal transfer Fax Logo
357 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
