Question about Sharp Multi-System Mini Component System Shelf System
Unit will not turn off when OFF button is pushed.
I have an old Sharp CD-C460 which will not turn off when I push the Off button but keeps flashing Normal, Bypass and Phanton. I have to unplug the unit to turn it off. What can I do to fix the problem?
I followed the instruction on how to reset the computer components, but the unit keep flashing Normal, Bypass and Phantom. The clock was flashing, so I resent the clock, and the flashing back and forth stopped. I just tried it again to be sure it was still working properly and it is!
Posted on Jan 29, 2009
Necesito manual de sharp cd-c460
Try Googling (sharp)(cd-c460)(manual) without parens.
Sep 21, 2017 | Sharp Computers & Internet
Cd will not spin
Sound like the optical pickup (laser) needs to be replaced.
Mar 10, 2013 | Sharp CD-C460 Shelf System
MY Sharp LC46D62U wont turn on
Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
Jan 07, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Tv wont turn on used it for two months and one day it turns on then the power led light flashes and the opc led light ...
This tv still under warrenty?Yes take ur warrenty repair.This problems very common on Sharp LCD tvs.I have one too.This tv have a Tuner signal board problems.But this tv still use able.Just push power button again after the POWER and OPC flashes.POWER and OPC some will flashes again and wait just push the power button again and wait.Sometimes have to push power buttons and wait power button push out of three or four times power button push POWER and OPC flashes.Than tv will work again.
Jan 06, 2011 | Sharp LC-52D64U 52 in. LCD HDTV
Aquos model LC46D64U...approx 2 years old..Won't power up and get the power light flashing 3 times then the OPC light once..which is repeated...Any ideas...I believe this is quite common with Sharp TV's
I have a Sharp LCD 46 in.tv do this often.Yes,it is.This problems,the tv Tuner signal board have problem,but the tv is still useable.The POWER and OPC light indications flashes.Just push the power switch again,wait see tv turn,not POWER and OPC flashes again,push the power switch agian and wait.Have to do this like 3 or 4 times sometimes,than the tv backlight will come on,tv will work.Don't know but,if u require to pushing power button more 10 or 12 times,the tv Tuner signal board don't take an turn on the tv backlight get the tv to work.The Tuner signal board is dead,time to replaced the tv Tuner signal board.
Oct 18, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have a sharp 37" lcd tv,model # lc37sb24u. no pix or sound, power lite comes on about 10 seconds then power and opc lites alternate on and off. thanks RON
This problems very common in Sharp LCD tvs.The Tuner signal board have problems,every times the power LED,OPC LED lites up,just push the power button on again,wait see if the LCD backlight lite up and works,not the Power lite and the OPC lite LEDS flashes again.You,just have to push the power button again,sometimes u have to push the power button at least 6 or 7 times to get the Power LED stable,and then LCD backlight,come on than the tv work.Not sure,but if the Power and OPC lites keep flashing,after u pushes the power button at lest 10 or 12 times,and the LCD backlight dosen't come on and the tv don't work.I think,it time to change the Tuner board is completely dead.I have a Sharp LCD tv, I do this everytimes pushing the power button at least 3 or 4 than the power LED stable,and the LCD backlight come on than the tv work.Not a plaw in the power supply like those capacitors in many LCD models tvs,but some included Sharp Tvs is the Tuner signal board is not very good in design,use the tv awhile the Tuner signal board have problems recieving the power to it Tuner board components.
Apr 15, 2010 | Sharp LC37SB24U 37 in. LCD TV
Is a flashing power light on a sharp model # LC-19SB24U tv a repairable problem? tv will not power up.
push vol-, input, and power, at same time. keep push until tv start. Then you will see k123 at your screen. Now push vol-, and chan- at same time. You will enter service mode. Look for "error no reset" change the value to 0.
Nov 17, 2009 | Sharp Televison & Video
Sharp XL-HP505 CD players won't open.
I don't know what the code is but have you pushed the reset button. If you do push it you will have to reprogram the unit. Otherwise it will have to go in for service
Hope this helps
Kurt
Mar 18, 2009 | Sharp XL-HP505 CD Shelf System
Clock
The manual was even wrong on this one. What you have to do is:
1. turn the key to the run position
2. push and hold the volume knob in until the unit turns off.
3. push it in again and hold it, the unit will turn back on and if you keep holding the button in the hour will start to flash
4. use the up/down, left/right buttons to set the time
5. push the button one more time and its all set
Feb 15, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Have no sound on front and rear speakers...
looking at the front of the unit take the left side pannel and replace the fuses. ive had to do that with mine several times because of the same problem
Sep 10, 2006 | Sharp CD-C460 Shelf System
Sharp Multi-System Mini Component System Shelf System Logo
195 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
