Question about Legacy LSWR844 8.4 in. Car Monitor
The picture on screen is upside down
The picture on the monitor is upside down and I can't find anything in the set up or menu to correct the problem.
    President:
  • 3,130 Answers
Did this all of a suddenly switch from being correct and then going upside down? I have heard of vibrations in the vehicle that these are mounted in to cause a break in the flex cable between the unit and the TFT screen. It is also a case where this unit could have been mounted upside down or right side up, there is a switch to control the vertical selection in the hinge mechanism. this need s to be checked out. Good Luck
Posted on Jul 28, 2007
  • 139 Answers
Jay there should be a External Switch on the Screen,Try looking ttech
Posted on Jul 25, 2007
Hisense tv picture is upside down, it was working fine
If the picture on the TV is upside down, press the Menu button, then check the following:
? If the Menu is displayed correctly the problem would be a setting within the external source or a signal issue. Please contact the manufacturer of the external device for further assistance.
? If the Menu is also displayed upside down, then the TV will require service..
Nov 08, 2016 | Hisense Televison & Video
The world is upside down, the king has lost his crown, don't laugh please, my monitor screen suddenly got upside down.
Rotating the screen image is a feature of the graphics card and is normally caused by accidentally pressing a combination of keys. To correct it, hold down Ctrl and Alt and press one of the four arrow keys (up, down, left or right) until you have it the correct way up.
As your screen is completely upside down, hold down Ctrl and Alt and press the Up arrow key.
Alternatively, you probably have a Rotation setting in the display properties of the graphics card. You should be able to reach your graphic card settings, but reading and setting them properly may be difficult since everything you see on the screen is upside down until it's fixed.
If all else fails, try restoring the system to an earlier date when the display was right. This will reset the driver to its proper orientation.
Nov 27, 2014 | Samsung SyncMaster 913N 19" LCD Monitor
Upside down tv screen
Do the picture to broadcasts appear correctly? Provide more details please.
Gopakumar Gopalan Google
Apr 07, 2014 | Proton MM2701VT 27" TV
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Screen on 7550 is upside down
there is a Windows XP setting to invert the picture (I guess it is if you hang the CRT upside down from the ceiling). I don't remember the key presses needed, but check under Properties for the CRT
Aug 19, 2008 | HP Compaq FS 7550 17" CRT Monitor
Inverted Screen (Upside Down)
SOME UNITS USUALLY DO HAVE A MENU FUNCTION TO FLIP THE SCREEN , HOWEVER IF THE UNIT HAS BEEN WORKING THIS WAY FOR A WHILE THEN IT MAY BE A SIGN THE UNIT IS REACHING ITS LIFE EXPECTANCY, IF REMOVING THE POWER DOESN'T WORK IT'S INTERNAL.
Aug 02, 2008 | Eiger Vision AV-710H Car Monitor
Flipped\upside down screen on my compaq
http://forums.techguy.org/tech-tips-tricks/336002-windows-xp-flipping-screen-upside.html
Windows XP: Flipping the screen upside down and back again
Once, at University, someone had flipped the screens of all the public computers (running on Windows XP) of the English Department upside down. The wallpaper, desktop icons, fonts, mouse-cursor and even the start-up screen...everything was displayed or moved upside down. People could not check out their e-mails or surf or do anything.
To reverse the upside down screen mode, press ctrl, alt and the up arrow (arrows console) at the same time; the screen will probably go blank. Turn off the monitor, turn it on again and the display will be normal again. If you possess a sense of humour or are antisocial, press ctrl, alt and the down arrow simultaneously, turn off the monitor, turn it on again and everyone (excluding the culprit) will be desperate --> upside down! Works for Windows XP Home and Prof.
Mar 31, 2008 | Computers & Internet
Bought used monitor, the picture is upside down
The solution for this problem is dependent on which graphics card you are using..Let me know which graphics card you have..
Oct 27, 2007 | Panasonic CT-2784VY 27" TV
One of my screens shows the video upside down
It could be that the monitor was installed upside-down; other than that, check the settings on whatever device your feeding video to the screen with- a PC, a DVD player? It might have rotation settings.
May 01, 2007 | Starvision SP-7VGA11 Pixelon 7" Monitor...
Polaroid PDM-0725
To change the screen upside right again just hold down the mode button until the screen changes upside right again , pressing the mode button changes the aspect ratio of the screen.
Oct 09, 2006 | Polaroid PDM-0725 Portable DVD Player
Legacy LSWR844 8.4 in. Car Monitor Logo
388 people viewed this question
Top Legacy Car Audio & Video Experts
Tygh Duval
Tygh Duval
Putter71
Level 1 Expert
Robert Little
Level 1 Expert
Are you a Legacy Car Audio and Video Expert? Answer questions, earn points and help others
