Question about HP LaserJet 4345mfp Printer
Pale print on PDF files
I have a print quality problem (pale print consistent all over page) when printing PDF files on the HP 4345MFP, the same PDF document prints beautifully on HP 4000, HP 1300, HP 1320. All other documents print well on the suspect HP 4345MFP. The firmware has been updated to 20070613 version.
  • 98 Answers
It sounds like a driver problem. Try replacing the driver for this printer on the printers folder, using the HP LaserJet Series II. With this driver, try again the PDF file and see if it prints correctly.
Posted on Jul 27, 2007
SOURCE:
Copying is very light while scan print fine
Unfortunately that is typical. You can set the copies to be darker, but often that just introduces gray areas that should be white.
Better to just scan and then print the pdf.
Jul 04, 2016 | Office Equipment & Supplies
Print pdf files
Try replacing the yellow toner.
Feb 06, 2014 | HP LaserJet CP1215 Color Printer
HP designjet 800 prints black as pale blue
color black ink is empty..or do the printer head cleaning procedure to the printer maintenance.
Feb 03, 2012 | HP DesignJet 800 Printer
Hi folks! I have a hp7160 that had a paper jam, which I cleared. The next time I printed, the text was very pale, and streaked. But when I print a test page the text that's supposed to be bold comes...
Welcome to FixYa!
You might want to check your printer settings.
  1. In the program being used for printing, click File , and then click Print . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the printer.
To see additional options, click the Advanced tab, and then click Advanced Features . The Advanced Features window opens. Consider changing the following option:Ink volume : Adjust the amount of ink that prints on a page. For darker images (more ink), drag the slider to the right.
I hope this will help.
Keep me posted and thank you for using FixYa!
Jas247
Mar 10, 2011 | HP Photosmart D7160 InkJet Printer
Poor print quality
go to printer properties and select the advanced tab check the image quality
May 07, 2010 | HP PSC 1410v All-in-One Printer
Laser printer samsung clx260 prints pale black
please check cartridge and your printer settings.
Dec 06, 2009 | HP LaserJet 4100 Printer
The ink level indicator is more than 1/2 full yet the print quality is pale. I cleaned printer heads several times, alligned etc., but still pale print quality. I changed ink cartridges, printed about 40...
try to change the properties of the printer. Usually it has a configuration to increase the printing quality.
And also, look for the configuration for ink drying wait time. Change it to long.
If you dont have any problems with your cartridge. then i think you should need some adjustments from your configuration.
well, i hope this works.. :)
Thank you.
Aug 08, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
My printer prints pale inks on the margins
If it is Laser Printer then you need to replace the DRUM in Cartridge or need to replace the cartridge. Incase if it is InkJet printer you need head cleaning. Else replace the cartridges.
Thanks & Regards
Nandu :)
Mar 16, 2009 | HP LaserJet 1018 Printer
Printing pale
Make sure your printer is not set up as "draft" (see printing settings/properties). In addition try forcing the print quality to "best".
Oct 23, 2007 | Epson Stylus CX6000 All-In-One InkJet...
HP LaserJet 4345mfp Printer Logo
570 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
