Question about Lands Phones
Nortel T7316E, How to make headset work ?
I have one Nortel T7316E phone in my office, I plug in a Plantronics Polaris headset to its headset jacket on the back of the phone. when I press the headset button, a message '' needs handsfree'' appears. The headsets function does not work.
How to enable the headset function to make the headset work ?
Thanks.
    Problem Solver:
  • 9 Answers
Look in the System coordinator guide 5.0 for HandFree
Select type of handfree
You must set the Handsfree at: auto
Its in the deep programming
Your going to need Business Series Terminals programming overlay to put over the phone.
  1. Press Function **266344
  2. Than enter system coordinator pass word
  3. Press SHOW once and enter your phone extension number
  4. Press SHOW twice
  5. Press NEXT tree times
  6. Change the parameter at HANDFREE with MOD
  7. Set it at AUTO
I beleved this will FIX it OK!
Posted on Feb 17, 2009
How do I change name showing on call display?
Do not believe that you can that comes from the phone company .
Sep 22, 2015 | Nortel Norstar T7316E Display Phone
Tip
What to check if Plantronics cordless mic does not work but earpiece works fine
If the party you call cannot hear you, check two things:
1- while on phone with the party, change the configuration dial on the headset base to 1. (We have Nortel phones and it must be on 1 for headset and mic to work with Nortel phone sets.)
2- Push IN on the headset volume control. Pushing IN activates or deactivates to MUTE feature on the headset.
Hope this tip helps you.
on Feb 22, 2016 | Plantronics CS55 Wireless Headset
Binatone Acura 3000 Corded Phone with Answer Machine
Sadly you are trying to do something that the phone is not capable of doing .
Sep 12, 2017 | Plantronics Audio Players & Recorders
Restrict calls
Is this on NOrtel or IP Office? Which NOrtel system?
Apr 26, 2013 | NorStar T7316E Corded Phone
How do i turn agc off nortell T7316E
I believe this is a feature of the headset. There is a setting for volume on a BCM but it applies to all sets not individual sets.
Jan 18, 2013 | NorStar T7316E Corded Phone
I have Nortel T7316E phones and Plantronics HW251N headsets. Is there a way to increase the volume for the mic so that the caller can hear us better?
The A10 direct connect cord used on the Nortel T7316E primarily will increase the speaker volume. If the problem is that your microphone is too low, you will need to use an amplifier, the M22. Remember that the amplifier needs to be connected through the HANDSET jack not the headset jack. Here is the link for the Plantronics M22.
Good luck from Headsets Direct!
Aug 05, 2011 | NorStar T7316E Corded Phone
Hi, At the office we have a Mitel IP phone we have just bought a headset model JAC0021201- B. We cant get it to work. Please can you advise how we set this up. Regards Trevor
I'm not finding manufacturer detail on this headset, only sales via Amazon, and it's dicey info at that.
So,I'm not certain this headset is compatible.  The only Mitel approved headsets are the Plantronics Polaris models.  These headsets fit into the headset port.  Such headsets require a headset button to be programmed and enabled on the phone to work.  When the phone rings, you will have to press the ringing button, to hang up, you will have to press the cancel button.
Other headset models may work, but require them to be plugged into the handset port and the existing handset will have to be plugged into it's unit.  Such units will require lifting the handset to answer the call and hang it up when completed.  Some such units have an optional lift kit.
I personally use a Plantronics Polaris "in the ear" model.  Plantronics web site has a config guide that will help you select a headset.
http://www.plantronics.com/us/configurator/default.jsp?use=Deskphone
good luck,
Mark
Mar 16, 2011 | Mitel 5220 IP Phone
How to move extension numbers from office to office using nortel t7316e
There is a feature built-in to the norstar system called "Set Relocation". When this feature is turned on, you can move a working extension to an unused/activated jack and the extension, features and mailbox will stay with the phone.
Have your system administrator turn the feature on, then move up to 2 phones at a time. The phone will go through 2 bootup sessions - be patient and don't unplug the phone.
Good Luck!
Aug 10, 2010 | Nortel T7316E 2-Line Corded Phone
I have a used Nortel Networks T7316E and for some reason when I plug it in to the phone line at home I get no dial tone and the light at the top and the three buttons on the bottom (headset)(Mute) etc......
The Nortel 7316 set is propriatary which requires the nortel system in qrder to work., The pulsing lights are the set reacting to the standard line voltage.In order for it to work in your house you'll have to install the nortel phone cabinetand then attach the set(s) to it.
Jan 19, 2010 | Lands Phones
PLANTRONICS Headphone won't work with IP 501 sip, polycome phone
Dont plugged into the headset jack. Like Nortel, connect headset line with phone base unit in receiver jack and plugged your phone receiver wire into headset or plantronic base unit. This will work. I am sorry, my english is not too good but hope you understand it now. But the pully is not working properly with IP501..I mean it is not good to pickup IP501 receiver and put it back right place.
Dec 17, 2008 | Polycom SOUNDPOINT IP 501 SIP
Lands Phones Logo
3,461 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
