Question about Microwave Ovens
No heat. all seems to work ok otherwise.
I have changed the magnatron but to no avail.
Cheers Keith
  • William Miller
    William Miller May 11, 2010
    When you hit Start to
    cook, do the inside light and turntable come on?
    Any unusual noises? Is
    it louder or quieter than usual?
    We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
    What is the model number?
  • 52 Answers
Rather confused, how did you get to changing the magnetron and what tests did carry out.
if the proper test procedure had been carried out
you would know exactly what was wrong.
I presume you have changed the power circuit protection fuse?
Posted on Feb 21, 2009
Oven seems to work fine, but does not heat
The magnatron is not working. This is what creates the heat. You will need to replace it or get a new oven. Magnatrons run anywhere from around 30.00 to 100.00 dollers.
Mar 07, 2011 | Microwave Ovens
My mh2175xsb microwave quit working a few days ago, that is it pretends to be working. All functions appear normal, timers, lights, fans, and even cycles when on percentage heat, but it heats nothing. The...
Hello Keith Sprague,
Spelling is close and your guess is quite excellent...
Before you ENGAGE in a wholesale repair effort...
You should check your machine is not in DEMO mode...
Demo Mode
Activate to practice using the control without actually turning on
the magnetron. Touch and hold number pad "3" for 3 seconds. The
"DEMO" icon will appear in the display. Repeat to exit Demo Mode
From page 3 (of your operators manual)
Whirlpool MH2175XSB User Instructions Electrical Requirements
Hope this helps
Carnac the Magnificent
Jul 02, 2017 | Whirlpool MH2175XS Microwave Oven
My plate does not always spin, microwave seems to be working when plate spins otherwise it just make noise but doesn't heat up. When I move plate manually it sometimes help, so I replaced electric motor...
The heating issue is related to the high voltage fuse and the magnatron assembly as well as checking the high voltage cao and the protective diode if the unit has one. As for the spinning dish u neeed to make sure the voltage of the new motor is the same as the old one. otherwise u may have issues with the motor not being able to spin efficiently. Good luck.
Nov 15, 2009 | Microwave Ovens
It is not heating food.
I'd suspect the following to be at fault.
1. The Diode, easy to replace and easy to test. Not user servicable though.
2. The capacitator is no longer capable of storing a charge, easy to test, easy to replace. Warning: All capacitators must be properly discharged before working on them. Serious injury can result otherwise. This too is not user servicable.
3. The magnatron - same as the above, not user servicable but fairly easy to test and replaced. You can use a multi-tester, ohmmeter/voltmeter
I will say, the least likely is the magnatron and the most likely is the Diode. Capacitators and magnatrons do not die to easily.
Aug 25, 2009 | Microwave Ovens
GE spacemaker xl1800 and Pop tarts bad mix
it sound to me as if the high voltage diode is shorted. It could be inside the capacitor or out board the cap. The capactor could also be short but this is a rarity. Diodes are a cheep item . repace it and if it don't work its probably the magnatro. good luck.
May 13, 2008 | Microwave Ovens
Not heating
Either the magnatron or the high-voltage capacitor and diode. Replace the capacitor and diode then if still not working, replace the magnatron. Its only affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Feb 06, 2008 | GE JVM1440 Microwave Oven
Won't heat. Everything else works.
Magnatron is suspect. Need to put a voltmeter on it and see if the input (primary) side to the high-voltage transformer (big heavy iron thing in there) is getting 120Vac. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing the magnatron. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Dec 31, 2007 | Hotpoint RVM1435 Microwave Oven
Microwave won't heat.
Magnatron is suspect. Need to put a voltmeter and see if the input (primary) side to the high-voltage transformer (big heavy iron thing in there) is getting 120Vac. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing the magnatron. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Dec 30, 2007 | Maytag UMV1152BAS Microwave Oven
DeLonghi combined microwave/grill/oven.
Found this posted in GE instead of DeLonghi but the basics are the same.
You say it stopped working - you mean it runs but doesn't heat?
Nov 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
42 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
