Question about Panasonic PT-43LC14 43" Rear Projection HDTV
Big black bar accross the tv screen
Whenever a commercial commercial comes on the bar disappears and returns back when cable is on. Does not do it while watching videos.
My close caption was on so it was trying to read a script that wasn't there. thanks
Posted on Jan 29, 2009
Sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Dec 02, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia KDL-52XBR6 screen adjustment
That sounds very normal to me. When your watching a HD channel, and a commercial comes on and the screen gets smaller with as you say the black bars, just means that the commercial is not broadcasting in HD. You can change it by pushing the button on your TV remote that says picture, but you are streaching the screen and are going to loose the quality of the picture. You may also want to spend a few hours, going into you TV settings and just start playing with the settings. Just remember where they were before you change something. You can also purchase a guide to LCD settings to point you in the right direction. If you have your TV set to vivid or one of the preset picure modes, it is costing you more power and you are not getting the best picture that the TV can produce. Play around with the custom setting or buy one of those calibration CD's off the internet.
Nov 09, 2009 | Sony BRAVIA KDL-52XBR6 LCD TV
Mitsubishi 1995 cs31205 32 inch tv
Good Day;
Sounds like you have the TV in the "close caption " mode (text), turn off. 2. Check batteries and the mode the remote is in; eg TV, VCR, Cable & ect. Good Luck, big IRISH.
Oct 05, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Big black box in the middle of the screen
The black box is there because your closed captioning is on and set to text mode. Some channels send the signal even when there is no actual text to display. You can get rid of it by either turning off closed captioning or changing it to CC1 or CC2 mode instead of text. If you can't find those settings, then restore factory settings as directed in your user manual.
Jun 04, 2008 | JVC AV-32230 32" TV
Black screen come
This is due to a "Text" setting in closed caption.
Apr 14, 2008 | Sharp 32U-S60 32" TV
Sharp Aquos LC-46D64U Large black rectangle in lower half of screen
It sounds like the closed caption text mode has been turned on. Use you CC button on the remote and make sure the closed caption mode is in the off position.
Jan 23, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Line accross top of the screen with flashing black and white boxes
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
Jan 02, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Black bar down screen left side 12 inches in from left
this is either a circuit board problem or the panel could have a bad tab
Dec 07, 2007 | Samsung SPP4231 42 in. EDTV-Ready Plasma...
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
26 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
