SOURCE: burning wire smell
Hello jvtmad1,
All of the previous comments are relatively good ideas but let me offer some additional advice,
First off, You need to determine if the burning smell is coming from the Microwave itself or from the receptacle that provides power to it. Most wall receptacles are rated for 15 amps and should easily handle your microwave ovens power requirements. A simple check might be to run a hair dryer on the same receptacle without the microwave plugged into it. They draw comparable power so that should eliminate the recptacle as the culpret, On the assumption that the burnt wire smell is coming from the microwave itself, then your best bet is to return it to the store for a repair or replacement. Unless you are properly trained on how to sservice that, you probably shouldn't attempt it. As stated in previous comments, it should still be under warranty. If you have a bad filament transformer, magnetron or the wiring between them, that is not something you want to fiddle with yourself.
In summary, eliminate the receptacle on the wall as being the problem first.
If you find tha your receptacle is the problem, then you may be able to remove or disable power to it by switching off teh appropriate circuit breaker or fuse.. then take off the face plate and check the integrity of the wires going to that receptacle and making sure they are tightly secured to the terminals of the receptacle. I would assume that if that were the problem, you would notice a burnt smell as soon as you took off the face plate. Hope some of thes ideas help you resolve your problem...
Regards,
Rick
SOURCE: MAGNAVOX TV BURNING SMELL TV WENT POP AND WENT OFF
Well that pop had something to do with the power components inside the TV frying. I would have to say there is nothing you can do to repair it as its dangerous to work on such things.
I wouln't waste my time bringing it to a repair shop they will probably tell you to just buy a new one.
