Question about Uniden BC246T Handheld Scanner
Ac addapter not working
I plug in the addapter and it does not work with out new batteries in the scanner
I had the same issue when I first got my scanner. There is a switch in the battery compartment that you need to set so it will charge the batteries. It is there so if you're using non rechargeable batteries you wont charge them in ruin your scanner when they leak/explode. Hope this works for you.
Posted on Feb 01, 2009
I need to buy a ac addapter for my portable speakers
Go to RadioShack with your adapter and get the exact replacemtn.
Jan 04, 2014 | Logitech mm32 Portable Speakers For iPod...
Phone says no link to base reconnect to mainbase ac addapter
The instructions worked after the additional KX-TGA402N handset was fully charged and I kept pressing the menu/ok button of the additional handset to advance from initial settings to the handset registration mode.
How do register an optional accessory handset to my existing main base...
Feb 08, 2013 | Panasonic KX-TGA402N 3 Pack KX TGA402N 3...
Addapter connected but not charging for sharp VL-Z500
If not charging,3 reasons may be-
1.Charger is defective.Check adapter
2.Batt is defective.Try with another one
3.Camera is electrically dedective.Can't complete charging.
Oct 20, 2012 | Sharp VL-Z500H Mini DV Digital Camcorder
Netbook wont boot up
The best way to resolve this is to remove the battery, plug it into the AC adapter, and attempt to turn it on. If it comes on, shut down, re-insert the battery and see if it will boot.
If it doesn't turn on when only on AC, then your addapter is bad and it has drained the battery to the point it will not turn on - You need a new adapter.
Please leave feedback if this was helpful.
Feb 18, 2012 | Computers & Internet
I have a hp modle G60-471NR and it wont power up tried hard start up didnt work ac addapter led is on when i press the power button the battery indicater led flashes three times please help me
It is possible that the connector inside the laptop is damaged. It would still show that power is getting to the unit, but not to the parts inside. I would think the internal connector needs replacing.
If this information was helpful, Please rate the solution high. thanks
Apr 21, 2011 | Computers & Internet
Computer doesn't turn on in battewrey mode or ac mode
please check the ac adapter with the mufti miter.
http://www.youtube.com/watch?v=m65yBJylgZ8
If your ac addapter is well then change the dc battery.
Goodby
Jan 10, 2011 | Computers & Internet
Laptop computer won't turn on...
this is ur battery problem so just get ur baterry cheked
Jun 25, 2009 | HP Compaq Evo n610c Notebook
Batteries AND ac adapter?
Make sure the ac adaptor ius the right polarity for the camera, negative outside plug and positive centre,also make sure the voltage output of the charger is correct 5 volts dc.You do not need batteries as well as the charger.
Sep 04, 2008 | Toshiba PDR-M60 Digital Camera
Clearing memory
WELL, After a year I alone, without any help from UNIDEN, FIGURED IT OUT.
1. TURN IT OFF, UNPLUG AC JACK IN THE BACK!
2. REMOVE Backup battery cover "underneath" scanner! TAKE ALL 3 BATTERIES OUT.
3. I PUSHED THE POWER BUTTON TO BLEED ANYTHING OFF IN THE CAPACITORS, IF IT HAS ANY INSIDE?
4. PUSH THE"2", "9", AND "HOLD BUTTONS DOWN, THEN PLUG THE A.C. BACK IN ON THE BACK OF THE SCANNER.
5.You WILL notice while you are doing STEP#4 THAT THE DISPLAY SAY'S "CLEAR". ALL FREQUENCIES WILL BE CLEARED IN THE MEMORY!! THEN TURN Scanner OFF reinstall the BATTERIES, TURN BACK ON AND START PROGRAMMING!! THIS WAS FOR A "BC340CRS" SCANNER
Mar 28, 2008 | Uniden BC340CRS Base Scanner
Uniden BC246T Handheld Scanner Logo
237 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
