Question about Whirlpool LEQ8000JQ Electric Dryer
A lot of moisture in the exhaust line of dryer...
Where is it coming from? I dumped it today and there was about a gallon of water in it. Clothes had been taking forever to dry and I wondered why....
Please help me understand...
  • 5,911 Answers
Your vent line is clogged somewhere. When a dryer exhausts air, it also exhausts moisture with it. If the dryer vent line is clogged anywhere, the moisture has no where to go but build up inside the vent line. An easy test to determine a clog is to remove the vent hose form the back of the dryer and attempt to dry a load as you normally do. The air escaping the back of the dryer should be forceful and warm. If so, you have a clog somewhere from where the dryer vent hose leaves the back of the dryer to where it exits your home. You need to inspect the vent about once per season to make sure it is not clogged with lint or rodents. Leaving a dryer in this condition will cause it to overheat to the point of failure. If the air is weak, you have a clog INSIDE the dryer. If you have questions, or need further assistance please let me know before you rate the solution. I hope this helps you.
Posted on Jan 28, 2009
  • 640 Answers
Thats easy the moisture from your clothes ,,and the outside air,,where ever you live its a lot of moisture in the air,,now the cold air from outside is coming back in dryer and the hot moist air is trying to get out,,bingo condensation,,in your dryer exhaust vent tube ,,hince all the water,,,,now to fix that ,,we need to dump all the water from vent exhaust tube ,,you may need a new one because it will mostly rot...and check the flap or put a window exhaust kit on the house or window,,to stop air flow from coming back in the dryer ,,and where done..onthejob
Lots of heat but don't dry
The usual reason for this is poor venting. If the dryer cannot exhaust the moisture-laden air that is created during the drying cycle, the moisture simply condenses back into the clothes. Ensure that the dryer is properly vented to the outside and that the lint filter(s) are clear of debris.
Dec 30, 2015 | Dryers
Why is there moisture in the exhaust piping?
The moisture from the clothes is heated up from the drying process and is exhausted through the vent pipe. When the warm air with that moisture cools in the vent pipe it condenses and forms water droplets again much like the water that forms on the outside of a glass with ice water in it.
May 27, 2015 | Dryers
INSIDE DRYER VENT FOR A MAYTAG ELECTRIC DRYER
I do not recommend venting a dryer inside. I suspect you are trying to save heat you have paid for. A dryer will add a lot of moisture to the area it is in as well as secondary lint that gets through the lint screen. This will cause condensation on any cool surface. In a basement this can lead to mold and mildew. But if you want you can make your own lint trap and if you need the humidity. Get a 5 gallon plastic bucket, some 4" aluminum vent pipe and 90 degree elbows. Direct the dryer exhaust into the bucket filled with some water. This will catch most of the secondary lint. Clean often and do not let the bucket run dry. There are some gallon buckets on the market that look a lot nicer but they restrict the airflow to much and this can cause problems with heating elements and thermal fuses. Never and I say Never vent a Gas Dryer inside.
Hopes this helps
Oct 19, 2014 | Maytag MDE16PD Electric Dryer
Whirlpool cabrio dryer has water in it. Lent filter is also wet. Last time used was over a week ago. Why? Have had dryer for over a year and never have i encountered this problem with this dryer or any...
this happen with the dryer A typical 12-pound load of laundry weighs about 20 pounds when it emerges from the washer, meaning that a dryer has to dispose of about a gallon of water with every load. Because of the moisture, exhausting the dryer to the outside is recommended since indoor exhausting can cause mildew and other problems.
Typical ventilation is recomend see the diagram .God bless you56ed11ca-7868-4b1a-955e-88eafd615327.gif
Jul 13, 2013 | Dryers
Dryer blows some warm air but cloths are not drying...lots of moisture inside the dryer...there seems to be limited air movement
If you are heating somewhat and have lots of moisture the issue is with the venting.
For one reason or another the unit is unable to exhaust the moisture from the clothes. Check the following.
- Make sure there is air coming into the room the dryer is in (not in a closet with the door closed etc)
- Check the vent pipe behind the dryer. You are looking for kinks or restrictions. You may have to take it off and clean it out.
- check the venting between the wall behind the dryer and the outside, if this is plugged you can try using a long brush and vacuum from both sides or even a leaf blower if you have one, blow from inside to out so you do not make too big of mess, if you cannot get it clean you may have to hire someone to come professionally clean it.
Apr 22, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Water and moisture build up
this sounds like the clothes are not spun out enough in the washer. there could also be a blockage in the ducting that would cause condensation bulit up but it sounds like you have a lot of this very unusual
Sep 05, 2009 | Frigidaire Electric Dryer
Dryer has water in exhaust pipe and not drying clothes
If you have water in the exhaust vent you have a clog somewhere in the line that needs to be cleared. When a dryer exhausts, moisture is included in the air that exits the dryer. This moisture will condensate and collect in the exhaust vent if it has no where to go. If too much moisture builds up this can back up into your dryer's heating circuits. In addition, a clogged dryer actually overheats and dries less efficiently. If the heating circuits continually overheat this can result in component failures and is a potential fire hazard. Inspect your dryer exhaust vent ducting thoroughly from where it leaves the back of the dryer, to where it exits your home. Make sure there are no bends, sags, kinks or clogs in the line. In addition, it is recommended that you use the semi-rigid metal type vent ducting. It resists kinking, is heat resistant and prevents rodent intrusion. If you have questions let me know. I hope this helps you.
PS If your heating circuits are no longer working, you may have a problem with the heating circuits now. The thermal cut-out (TCO) commonly fails. If this is the case, please let me know and I can advise you further.
Jul 02, 2009 | Dryers
My clothes are very damp after 2 hours of drying
check for lint buildup in the blower fan assembly.
check for blockage in the exhaust tube
check the exhaust flap on the side of the house to make sure it is opening properly
as far as the water in the line .....it may be moisture from the outside leaking in or a lint blockage soaked with moisture (although that is rare)
Mar 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Hi, Water is coming out of the bottom of our new ge profile 7.0 cubic foot dryer. Is my wife over loading the new ge 3.5 cubic feet profile washer, then in turn over loading the dryer? I have four 90...
water out of any dryer now or old is problem. a definite venting issue. dryers doing what it should, pulling moisture from your clothes, that moisture should vent outside your home. however you have a SEVERELY clogged vent and the moisture is getting trapped and condensing on the cooler metal . replace your venting. at very least disassemble and clean. don't forget about exhaust hood where it leaves house
Mar 08, 2008 | Dryers
Clothes are not getting dried.
Check your dryer ducting.  If you have not cleaned your dryer ducting recently, it may be time to do so.  In order for a dryer to work correctly, it needs proper air flow.  A lot of people don't realize that just seeing the heating element glowing and the air blower fan running isn't enough to get your clothes dry.  If the dryer does not have a proper exhaust the air has no where to go.  All that air that is normally exhausted out of the dryer vent carries all the moisture from your clothes with it.  If the exhaust is clogged, all that moisture stays in the dryer and the dryer works harder to try to heat.  Your clothes stay wet and, eventually, your thermal cut-out and/or heating element will blow.  You could also have a clog somewhere inside the air baffle in the dryer.  This is where the exhaust fan is.  Lint can get trapped in this area clog up your dryer.  Here's a simple test you can perform:
1. Remove the exhaust ducting from the back of the dryer and dry one load in this manner, letting the dryer exhaust freely into your laundry room or garage.  Feel the air leaving the exhaust port on the back of the dryer.  The air should eventually heat up and be rather forceful.  If your clothes dry faster, then you know you have a clog somewhere in the ducting.  You will need to trace it all the way to where it leaves your home at the exhaust vent outside.  If it is run in a crawl space, make sure it is suspened from the rafters and not on the ground.  Leaving it on the ground makes it susceptable to rodents wanting to chew through to get inside your dryer.  Dryers provide a great source of warmth and bedding material (lint) and mice love them.  Also ensure thre are no sags in the line that will create areas for lint to collect.  If you find that your clothes are drying better, take care of the problem immediately.  Running a dryer for extended periods of time exhausting in your home can add unwanted humidity, dust and potential mildew.
2.  If your dryer still is not drying sufficiently, or you have very weak air flow coming out of the rear exhaust port.  You will need to remove the air baffle housing and check for clogs.  I experienced a home where a dryer would not heat, but the ducting was clear all the way to the exterior vent.  The heating element was also heating properly.  When I removed the ducting, however, there was barely any air coming out of the dryer.  When I inspected the air baffle housing I found a mouse nest as big as a shoe box and compacted to the point that I had to disassemble the unit to get it out.  You will find that MOST insufficient drying problems are directly related to the cleanliness of your dryer interior and your dryer ducting.  Not to mention, the potential for house fires if you do not maintain a dryer properly.  I have also found situations where lint became so backed up in a dryer that there was evidence of multiple fires inside the dryer.  Take the time to double check your dryer venting and replace those old plastic worn out vent hoses with new semi-rigid metal hoses.  They resist crimping and crushing and will not clog as easily.
NOTE: It is normal for the heating element to cycle on and off.  This is actually a symptom of a "healthy drying cycle".
I hope this information is helpful to you.  If you find no obvious signs of clogs or obstructions, let me know.  You may have something else causing your problem.
Oct 31, 2007 | Dryers
Whirlpool LEQ8000JQ Electric Dryer Logo
192 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
