Question about Metrologic Instruments MS2122 StratosE Fixed Mount
StratosE ms2122, it scans it beeps but nothing appears.
I bought new StratosE MS2122, with USB Connection, it scans it beeps but i get nothing on the screen.
  • 661 Answers
Most barcode systems will scan and beep when presented with a valid barcode (if the barcode conforms with a valid format). This just means it is powered up (it does not require any input from the computer to do this) I believe you have a driver issue, which controls how the scanner communicates with your computer. please check that you have up to date drivers and software from the manufacturer's website and that you can find the device listed (by name) in your Device listing Gareth
Posted on Jul 26, 2007
Symbol Model LS 9208, Bar code Scanner loaded factory setting, its scans(beeps) but does not display /show in the notepad.
If the scanner is connected through USB connection, the barcode should appear in the Notepad. If you use the Serial connection RS232, the Barcode data are showed than in Hyperterminal or other application, which is interpreting data from Serial Port.
Please scan the barcode from Product Guide according to your connection. And check the scanned data in an application - Notepad for Keyboard Wedge or USB, Hyperterminal for RS232.
Aug 21, 2010 | Symbol LS9208 Hands Free Barcode Scanner
No image appears in preview or after scan using Epson Perfection 1670
I had exactly the same problem after moving my scanner to a new location, even though it was locked... it happened blank scanns, so I was about to go get my self a new scanner.
What I did was to get a cotton pad, put alot of alcohol on it and clean both sides of the connection usb cable in/out and then let it dry. Also I unistall all the epson scanner applications and reinstall with the new driver epson 12699.
It worked perfect, try it you have nothing to loose.
Jul 11, 2010 | Epson Perfection 1670 Flatbed Scanner
Five beep post code
The beeps indicate that error is usually caused by hardware incompatibility or failure. More specifically check the following list:
You installed new hardware that is conflicting with old hardware.
There was a reecent electrical storm that caused a surge that damaged parts of the computer.
Try the following:
Remove new hardware.
Remove any disks or USB devices.
Remove any disks, CD's, DVD's that are in the computer and if any USB devices (ipods, drives, phones, etc) are connected disconnect all of them as well. Reboot the computer and see if anything changes.
Disconnect external devices.
If nothing appears to work then try removing the ram and installing a new module.
Jan 28, 2010 | Abit NF-M2S Motherboard
Can't get Mindstorms USB connection to work.
try:
  1. changing cables
  2. switching usb ports
  3. using bluetooth
  4. changing the batteries
  5. if all above fails call lego custumer support at 1-800-838-9647
Dec 26, 2009 | Lego Media Lego Mindstorms
Symbol Scanner LS4071-I1us
transltor and data comparison failed?
Jul 27, 2009 | Symbol LS 4071 Handheld
Symbol ls 4000i not scanning
The first beep is a Good decode beep, the four beeps later are telling that the connection to your PC is not working properly.
Jun 07, 2009 | Symbol LS 4000i Handheld
I have an Asus A8N-VM and all of my usb ports quit working over this last weekend. It kept losing the connection and regaining it all day Saturday then it just quit working. Luckily my tower has PS2 ports...
this problem for that i know is caused from this :
one your controller that controlling your usb ports is finished, and with this is coming more problems not oly usb ports,
second you prompted to install something but you didn't. go to control panel system, devices and one time you are there click on your computer name in begining of the list. after that click in action and then scan for new devices, if nothing is found in the list go to universal serial bus controllers and see if is finded there no name usb or unknown usb device. if this isnt helpin you fixing problem try to install again your system but without destroing that you have to not loosing to much time, in setup window dialogue select repair but the secon that appear not first one.
Apr 07, 2009 | ASUS A8N-VM Motherboard
Metrologic USB Voyager scanner
refer the manual and scan the default barcode and scan the usb interface barcode properly.
Feb 01, 2008 | Metrologic Instruments 9520 Voyager
Metrologic Instruments MS2122 StratosE Fixed Mount Logo
141 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
jackcity
jackcity
Level 1 Expert
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
