I have 2007 honda shadow spirit 750 i took petcock off due to leaking now im stuck on where o ring goes in petcock
See the generic service manual at the honda motorcycle web site, http://hrca.honda.com/
SOURCE: I need to replace the o ring (petcock) on my 2004
Drain the tank. You should be able to remove the petcock by simply turning the nut holding it on or turning the whole petcock assembly. It may be stuck in place by the o-ring/fuel filter inserted into the tank. Be sure the filter is in place when you put the petcock back on or you will have problems with leaking gas out the carburetor overflows (from tank rust getting into the carburetors). Chances are the leaking gas is not form the tank sealing o-ring, but from the vacuum diaphragm assembly attached to the back of the petcock. Part # 5 on the microfiche.
http://www.bikebandit.com/houseofmotorcycles/2004-honda-vt750c-shadow-aero/o/m2881#sch407448
SOURCE: 2002 honda shadow 750 spirit
If you have fire, but are the sparkplugs getting wet when you are tunning it over???? Do you have a manual choke???? Is it working??? Is the air filter clean????
SOURCE: my wife has a 750 honda shadow spirit 2003 dc that
This sounds to me like a carb float being stuck open. Turn off the gas and drain the offending carb(s). Next, turn the gas back on and sharply tap the float bowl with the plastic handle of a screwdriver as the fuel bowl refills. The goal here is to vibrate the float to free it up. If doing this process a couple of times does not free the float I would remove the carb(s) and clean with a spray carb cleaner. Clean the air filter then re-mount carb(s). Next Remove the water trap bowl at the bottom of the petcock, (gas valve). Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ). Install an inline fuel filter.
THis should solve the problem.
Please rate this answer. Thanks smatthews!
SOURCE: will 2003 Honda shadow 750 spirit pipes fit a 2002
yes but you may have to get a small section of flat iron (any metal) and use it as a mobile mount for the rear of the pipes. the pipes will fit the block though.
SOURCE: 2003 honda shadow spirit vt750 carbs
It is different then most other carbs. DON"T DRILL ANY BRASS HEADS LOOKING FOR THE AIR FUEL MIXTURE. The air fuel mixture is the only adjustment you can make. It is located on the bottom side of the air intake, right behind the air filter box. It looks like a 1/4" flat metal plug. Do NOT drill this. There is no slot for a screw driver. There is a tool which is no more then a small piece of pipe that fits over this plug and you turn it in till seated, gently. Count the turns. Back out to 2 and a half turns, thats normal. Or if you no that you need more fuel injected, simply turn the screw OUT 1/4 or 1/2 turn and try it. GOOD LUCK (Its not hard)
There is no drilling to be done. Hope i didnt scew something up on mine......
