Question about SuperMicro SuperServer 6022P-8R
Red led at SCSI drive# 2 and 5 and long beep
Replaced a new hard drive still does not fix the issue. what could have gond wrong?
$3$ WolF ILia $3$ :):):)
Posted on Jan 30, 2009
  • wolf680 Jan 30, 2009
    $3$ WoLF ILia $3$ :):):)
Need the pin settings for scsi led header for intel sever board s875wp1-e
SCSI Hard Drive Activity LED Connector
The SCSI hard drive activity LED connector is a 1 x 2-pin connector that allows an add-in SCSI controller to use the same LED as the on-board IDE controller. For proper operation, this connector should be wired to the LED output of the add-in SCSI controller. The LED indicates when data is being read from, or written to, both the add-in SCSI controller and the IDE controller.
Test the 2 pins using a multi-meter to determine which is + and which is -. Nowhere in the manual does it say which is which.
Mar 11, 2011 | Intel S875WP1-E Server Board Motherboard
Tip
Error Codes you need to know.
Standard Original IBM POST Error CodesCode Description
1 short beep System is OK 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Display adapter problem (EGA) 3 long beeps 3270 keyboard cardIBM POST Diagnostic Code DescriptionsCode Description 100 - 199 System Board 200 - 299 Memory 300 - 399 Keyboard 400 - 499 Monochrome Display 500 - 599 Colour/Graphics Display 600 - 699 Floppy-disk drive and/or Adapter 700 - 799 Math Coprocessor 900 - 999 Parallel Printer Port 1000 - 1099 Alternate Printer Adapter 1100 - 1299 Asynchronous Communication Device, Adapter, or Port 1300 - 1399 Game Port 1400 - 1499 Colour/Graphics Printer 1500 - 1599 Synchronous Communication Device, Adapter, or Port 1700 - 1799 Hard Drive and/or Adapter 1800 - 1899 Expansion Unit (XT) 2000 - 2199 Bisynchronous Communication Adapter 2400 - 2599 EGA system-board Video (MCA) 3000 - 3199 LAN Adapter 4800 - 4999 Internal Modem 7000 - 7099 Phoenix BIOS Chips 7300 - 7399 3.5" Disk Drive 8900 - 8999 MIDI Adapter 11200 - 11299 SCSI Adapter 21000 - 21099 SCSI Fixed Disk and Controller 21500 - 21599 SCSI CD-ROM System
on Mar 09, 2010 | Computers & Internet
What kind of hard drive do I need for an acer aspire 4315? From what I have found it needs to be 68 pin, is there anything else? I have replaced a few hard drives and this is an easy fix (much easier than...
A hard drive with 68 pins is a wide SCSI-3 hard drive device.
SCSI drives need a SCSI controller (eg in this case an Adaptec SCSI-3 controller) and the SCSI ID of each hard drive can be set from 0 to 7. The ID setting on the hard drive is jumpered by 3 x 2 pin configuration using a binary configuration to get the 8 SCSI ID combinations.
Depending upon the length of the cable and the number of connectors on the cable, it can support quite a number of SCSI hard drives, whereas an IDE cable only supports 2 drives per cable.
Dec 14, 2009 | Acer Computers & Internet
The red power switch keeps flashing,, no picetc
The Red light is due to the HDD (hard drive).
There is one of 2 problems:
1. The connection is loose or
2. The HDD is just bad.
This was an issue that has been discussed over in the Playstation forums and it seems that re-seating
(removing & reinstalling) the HDD has solved the problem for many but some people have just
received bad hard drives period.
If you reinstall the HDD & it still beeps 3 times & gives you the red light, then you will have to replace
your HDD.
http://www.ps3guide.info/fix-common-problems/ps3-3-beep-blinking-red-light-fix
Oct 02, 2009 | Sony Playstation 3 (PS3) Console
System will not turn on
hard drive error get a new hardrive -might work or call sony for a replacement ps3
Aug 16, 2009 | Sony Playstation 3 (PS3) Console
Second Led on HDD is flashing Red
you can run "chkdsk /r" coomand to recover your harddisk.
Also if you can delete partition and then create new partition thehn format it so all errors are fixed .
Jul 16, 2009 | HP Compaq ProLiant DL380 G3 Server
I think it's not the problem with your SCSI drive.
Long beep might be because of the RAM. Take a look inside and see if everything's alright with RAM. Carefully replace it to another slot if there are empty.
Download and use a program like MemTest to see if RAM is properly working.
If you have another computer which is compatible with your RAM, try it inserting then in to PC and see if everyhting's alright.
If nothing helps, then purchase a new RAM module
Jan 28, 2009 | SuperMicro SuperServer 6022P-8R
PS 3 power up problem - 3 quick beeps with red blinking LED...
Hi Mike,
If you open the unit, you can forget any chance of a warranty return.
Heres what i,d Do:- find a friend thats just recently bought a PS3.
Ask for his Warranty Card, return the Unit to Sony or the repair centre. your dealing with serious issues here mike.
these are too new, to go playing lets open the case up.
Unless your a real PCB electronics specialist ( which i,m certainly Not ) don,t waste your time.
3 beeps-red lights could be Overheating, hard disk errors, Bios fault if they have 1.
Mike @ Compurepair.
Feb 16, 2008 | Sony Playstation 3 (PS3) Console
Power edge 2600 sever shows problem
i replaced one of the hard drives in my poweredge. how do i get it to copy from the good hard drive?
Jan 28, 2008 | Dell PowerEdge 2600 Server
SuperMicro SuperServer 6022P-8R Logo
204 people viewed this question
Top SuperMicro Computers & Internet Experts
David
David
Victorman
Victorman
Joseph Hoffmann
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
