Question about HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 error code
I get an error code - 0x8807e68 I have tried reseting printer, checking ink cartridges, etc...??
SOURCE: HP PSC 2355 Won't accept refilled ink cartridges
If problem is what I think it is (that is if you cleaned whole thing and it is connected proprely), you have only one option. To buy at least three cartridges...problem is due a small trick made by HP. Printer remembers at least two cartridge serial numbers, and then wont accept refilled ones. But if you first stick one, then the other, and on the end the third one(only this one should be really full) it should reset printer and it should foul it to accept it. But on some printers it needs up to five cartridges! What a waste of money :( Anyway, hope this helps...
Posted on Sep 28, 2007
JULIANFIX
  • 975 Answers
SOURCE: psc 2355
check if there is a back door where you can access from there the rollers and check for any paper stuck , turn on printer and go to DEFAULT setting on the menu . hope it works
Posted on Apr 19, 2008
adonscott
  • 106 Answers
SOURCE: error response on hp psc 2355 AllinOne printer,scanner, copier
Issue The product displays an 0x ... error code when printing (for example Error: 0xf0af8004 ). These error codes indicate that the product has an internal condition. Solution Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
If these steps did not resolve the issue, please let me know.
Thank you so much. I Remain
adonscott
HP TECH
Posted on Jul 04, 2008
SOURCE: HP printer PSC 1410 ALL in one printer showing "Check print cartridge" error
please let me know what is rail and carriage bushings ?
Posted on Jul 09, 2008
SOURCE: remove an check cartridge problem in HP 2410xi printer
bought new
Posted on Apr 09, 2009
Can I use an HP75 tri-color printer cartridge in my HP PSC 2355 All in one printer even though it usually takes the HP95?
HP 75 tricolor cartridge is not designed for PSC 2355.If you try to install it,you'll get a message incompatible ink cartridge or cartridge problem.using a different cartridge may also damage the chip embedded in the printer.do not use hp 75 as a replacement for hp 95.
Jun 19, 2011 | HP PSC 2355 All-In-One InkJet Printer
How to fix memory trashed error hp 2355 all in one
Memory for fax?
or
R u try to reset your printer?
Pls pint point your purpose and diagnose......
This printer has been out quit long time ago, which means u do not need to reset for using refilled cartridge or some other use.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
Apr 19, 2011 | HP PSC 2355 All-In-One InkJet Printer
What does 'Print Cartridge in right stall not supported' mean?
It means you have a faulty or incorrect cartridge installed on the right side position. It could also mean the contacts are dirty or misaligned. Remove the cartridge, clean with rubbing alcohol and reinstall.
This is not a unknown error particularly if you are using cartridges other than the HP brand. Other people will tell you it is fine to use off brand cartridges or refilled cartridges. For myself, I have never had luck doing that - on the other hand, I have never been disappointed using the more expensive cartridges recommended by the manufacturer across several brands including Epson, Canon, Compaq and HP.
Try cleaning the contacts and ink jets. You may have to replace the cartridge. If that is the case, I would return the faulty cartridge and get a store credit.
Just a few thoughts for you to consider. Thank you for using FixYa.com today.
Mar 03, 2011 | HP PSC 2355 All-In-One InkJet Printer
What ink cartridge does the hp 2355 all in one inkjet printer use
The PSC 2355 uses a standard Black 94 and a Tri-color 95 cartridge.
It also can use a Tricolor-97 and a Photo 99 cartridge.
Here is the HP price list:
http://www.shopping.hp.com/webapp/shopping/supplies_model.do?product_code=Q5789A&aoid=5504&lang=en&cc=us
Also, here is a link to the main support page for the printer where you can obtain much more info.
HP PSC 2355 Support
Thanks for using Fixya.
Feb 16, 2011 | HP PSC 2355 All-In-One InkJet Printer
Have HP PSC 2355 and receive error 0xb900005 what does this mean?
It means there is an interal error and the printer has to be reset.
The best solution is to unistall the printer and then reinstall.
1.Unplug the printer from the computer not the cord just the cable.
2. Do the unistalling process. Whhen done do the following to the printer before connectiong back the printer.
Take out the cartridge then wait for the message Insert ink to display and unplug the cord. Wait 60 seconds.
Plug in the cord and when the printer restarted insert the cartridge.
Close the cover. If promted to print a calibration page report printed it.
Reconnect the cable.
Your printer should be running good now.
Jul 16, 2010 | HP PSC 2355 All-In-One InkJet Printer
Wont use 343 ink
Purchase "genuine" HP ink-cartridges.
May 26, 2010 | HP PSC 2355 All-In-One InkJet Printer
I am getting an error message ox841fc379 when I turn on the printer. Please advise
Your HP PSC 2355 may need to be reset:
1) Disconnect the USB cable from your computer
2) Remove the ink cartridges
3) Unplug the power cord. Wait for at least 1 minute. Plug the unit back in (press the power button if necessary)
4) Wait for the "Insert Cartridges" message. Reinstall the cartridges
5) Close the product doors
6) If you receive a recalibration message, allow the printer to complete this task
7) Reconnect the USB cable
8) Try your print job again
If problems still exist, your product may need servicing by an authorised HP technician.
Dec 20, 2009 | HP PSC 2355 All-In-One InkJet Printer
I bought hp 98 ink catridge from Walmart for my hp psc 2355 printer. when i installed it the printer gave me incompatible error. I went back to walmart to return it and they said the hp does not allow...
Try to sell the ink cartridge through 'www.CraigsList.com' or 'www.eBay.com', or find a "FreeCycle" mailing-list, and give it away.
Or, buy an HP printer that *DOES* take the "98" cartridge. :-)
Nov 09, 2009 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 incorrect print cartridges error message
not quiet a solution dugguly but i've just had the same problem in reverse, i moved to the us with same printer, ink ran dry, it won't take hp94. after 3 phone calls and 4 emails with hp i learned that all hp printers sold after 2004 are regionalised, therefore a us printer will NOT WORK with UK bough cartridges and vice-a-versa. the only way round this is to call the HP support and ask to be taken through the step by step guide to reseting the region of your printer to the UK regional setting OR and this is my option, get friends/family in the US to ship US cartridges to you in the UK. Too bad as Tesco do a good line in gneric cartridges - Good luck - mattw
Oct 07, 2009 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
1,163 people viewed this question
Ben Johnson
