Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Mitsubishi 65513 TV, dm board
Please send me a PDF on how to fix my 65513 tv. It appears that the blinking green light problom is in the dm board , but I know .
Looking forward to your reply.
thank you Cary
  • 2,071 Answers
I dont have a pdf but I have something that can help your problem.
Just click below for the solution related to your problem of DM board.
http://www.fixya.com/support/t1012464-fixed_blinking_light_but_still_no
Hope it may help you;
Regards;
VOTIT
Posted on Jan 29, 2009
Blinking Green Light of Death
Done! Please remember to rate this answer!
Jan 26, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Blinking green light on Mitsubishi 65513
Instructions sent. Please remember to rate this answer!
Jan 09, 2009 | Mitsubishi WS-65513 65" Rear Projection...
WS-65513 Blinking Green Light
I have a Mitsubishi MITWS-65813.
The green led light constantly blinks. I tried the reset button and green light is still blinking. I unplug the tv, waited a few days, then plugged the tv back in, the green light still blinks. I have a lot of experience with soldering. Do you have any suggestions or can send repair directions/protocol for the DM board.
via email? Thank you in advance for your help. Your help is much appreciated!
Sep 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
You can get the V23 DM repair kit at the following link which has the replacement capacitors and the instalation instructions on Cd which has pictures of the repair. Its listed under the repair kit category.
http://servicemanuals.vstore.ca/
Aug 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 Flashing green light
Good Day, charliek1;
This a very common problem with model. Don't listen to other comments unless the use the correct replacement parts.
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V).
The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board.
Good Luck, big IRISH.
Jul 10, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 green blinking light
Good Day, nixonam;
Jul 08, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi TV WS-65713
Please send me the instructions on how to remove and repair the dm board in my mitsubishi ws-65513 tv. The green light keeps blinking. thanks
samzlades@yahoo.com
May 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Please study the procedure at the following address.....
www.chrisandnat.com/projects/blinkingtv/blink.htm .....
use 1000mf 25v or 35v 105 degree capacitors to replace
original four 1000mf 16v..............if new ones are a little
too high,just lay them over on board........
Look it over..........let me know......................T.
Jan 07, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 Blinking Light Problem:
the 1000 mfd 16vdc filters on the dm pcb are probably bad..there are 4 of them..it will require soldering
Nov 25, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi ws-65513
Have you looked at the DM board fix yet that's available here. http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair Check it out. If the inside of your TV set does not look like this, you will need to get the service manual to disassemble the set and get to the DM board, but use the rest of the guide to repair the board. If you are successful, you will save almost a 1000 bucks! Good Luck
Jul 14, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
77 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
