Question about Kenmore 47783 Electric Single Oven
Oven does not heat up beyond 240 degrees, which takes a long time
The top coil is the only one that is heating...the lower coil does not heat up at all.
Please help me know what to do to fix...the unit otherwise is working fine.
Thank you,
Chris
  • cbbratton Jan 28, 2009
    Thank you!...so as I was removing the lower coil to expose the element (?) a huge spark? shot out and scared the **** out of me. What was that? Are the elements what I see attached at the end of the coil - at least on one side the other side is burnt off?
  • 979 Answers
You have either a burned our lower element or a wire has burned off at the terminal for that element. The good news is that the lower element is cheaper.
Posted on Jan 28, 2009
  • Bill Dickerson
    Bill Dickerson Jan 29, 2009
    You have touched the end of the element to the metal frame. Turn off the breaker first, then remove the element and take it to a Lowe's or an appliance place to replace it. However, you may have only a wire burned off. If you do, then replace the end conecter with a stainless steel one and not an aluminum one. The aluminum one does not stand up to heat very well. If replacing the connecter is not the problem then you willneed to replace the element. You probably tripped a breaker when you pulled the element out to start with. Always turn off the breaker when working with electricity. I always do and i have been working around it for 30 years.
Top oven doesn't heat properly
What is the model number of the unit?
Dec 03, 2012 | Ovens
Whirlpool Gold Electric convection oven does not heat up.
Check for a broken wire or even broken element on top and bottom of unit. To do this, the unit must be unplugged or otherwise removed from power completely, then remove the screws that hold each heating element in place and gently pull out and inspect the wire connections. You should have just enough slack to check them. There should also be just enough slack to strip the wire clean to make the new connection to the heating element.
If the repair has been done before, you may need to fish a new lingth of high temp wire into the location.
Jul 13, 2012 | Whirlpool Ovens
Lower coil will not heat.
Hi
If the lower wont heat and the upper work fine then it is the coil itself that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jan 11, 2011 | GE Profile JTP18 Electric Single Oven
We have a GE gas oven/stove top and the stove top is lighting as well as the broiler but we can not get the oven to heat up. What do you suggest we try?
i just moved and our stove in the new place doesnt bake things right. it seems that the top coil doesnt come on. its very difficult to bake anything. seems to come up to temp for pre heating, but only the bottom coil comes on. If you put it on broil, then the top coil gets hot. that works fine. tired of burning pizzas and biscuits. can anyone help with a cheap fix? dont have alot of cash.
Nov 12, 2009 | GE Ovens
I ran a cleaning cycle on the lower oven. Now it won't heat
the answer is the thermal sensor, mine has gone bad everytime I clean the oven. Solution, run a fan on the oven while you are self cleaning, this keeps the outside heat away from the unit. Pain to replace the sensor, its in the middle back of the oven, have to pull the whole unit out.
Sep 24, 2009 | Whirlpool RBD306PD Electric Double Oven
Pulling lower coil and big spark came flying out of oven backwall
Have you had a chance to fix it yet ? The wire has probably come off or burned off keeping it from working. Feel the element to see if it has any rough spots in it. This will indicate it is burned up on the inside.
Jan 28, 2009 | Kenmore 47783 Electric Single Oven
Oven does not heat
i have had a similar problem before and was fixed by replacing a fuse check to see if you have 2 fuses if not then the next step is to measure the resistance across coil it wont be 0ohms cos if it is your back to a blown fuse instead you should have a resistance across it i suspect you will see a open circuit meaning u need to buy a new coil for your top oven
hope this helps
Nov 07, 2008 | Whirlpool Ovens
Bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Dec 25, 2007 | Dacor ECS230 Epicure Electric Double Oven
Kenmore 47783 Electric Single Oven Logo
195 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
