Question about Jensen CD4610 CD Player
Put in a CD and now it is smoking. 2007 Charleston Motorhome
Just put a CD in and the radio started smoking. We have turned off the switch for the motorhome to turn off power to radio. What should we do?
    President:
  • 1,990 Answers
This is Caused by a Bad Ground. Locate the Ground Wire for the Stereo and ReRoute the Ground to a Better spot on the Body.Please Rate my Response, I need all the Help That I can Get! Thanks!
Posted on Jan 28, 2009
Panasonic CQ-C8303U. Hooked up an amplifier and it works with the radio but when i put in a cd the amp doesn't work. the receiver just plays with normal sound.
Verify your wire connections are correct. Keep in mind that if your amp is hooked up to the radios power antenna wire this is the problem. When you insert a cd the radio is designed to lower the antenna. If your amp is hooked up to the antenna wire the radio is shutting off the amp when you put in a cd Panasonic does this on most of all their units. You may have to hook your amp up to a separate switch to turn the amp off and on or hook it to your ignitions acc wire, if you hook it up to your ignitions acc the amp will stay on as long as your key is on even if you turn off the radio.
Here's a link to download the manual for your radio just copy and paste it in to your web browser and download the PDF file. You will need the reader to view it. If you don't have the reader you can download it for free at www.adobe.com
http://www2.panasonic.com/consumer-electronics/support/Audio/Mobile-Electronics/CD/model.CQ-C8303U
Oct 09, 2010 | Panasonic CQ-C8303U CD Player
I just put in a radio in my 88' truck and i have to reprogram my stations every time i start my truck,why is it not holding memory?
Your red memory wire is not hooked up or you switched the red and yellow ignition wire around and your radio stays powered up when you turn off the ignition.
Oct 17, 2009 | Dual XDMR-7700 CD Player
Citroen Saxo CD Player will not play when engine running
The car stereo has 2 +12V inputs: the constant batt input and the key in one.
So actually the stereo is always connected to +12V, even in standby.
When you turn your key, the key in input also starts, thus starting your stereo instantly.
When you turn the ignition on, the key in input is switched off for a couple of seconds, so that all the power goes to starting your engine.
After that key in input should be back on - this is your problem here.
One possible solution would be to cut this wire out, and split the RED battery +12V cable so that it enters in the key in input as well. Check wiring diagrams!.
Test this with cables out (without reinstalling the whole thing back in) and if it works.......leave it and put everything back in.
Only downside is, you have to turn off the radio by hand when you exit your car - or you could lose all battery power !
Jan 16, 2009 | Car Audio & Video
Subs won't turn on
Hi Neo_69
i would love and try to help you. ok so your having a problem with your subwoofers when you put a cd in. well try to change the output of speakers to work when you put a cd in it should be on the car radio and also you can try reseting the car radio there should be a little button to reset it. If you need more help or this does really answer youe question let me know. Thanks
Dec 23, 2008 | Kenwood KDC-MP438U Car CD/ MP3 Player
Troubleshooting in car cd player
that is very strange but it could be that when you put the cd in the radio it maybe sending out a quick shot of amplified power I would try disconecting the subs put in a cd let it play a little then plug the subs in while the cd is playing and see if they work if this works you may to get a new radio or put in a switch to turn the subs off or some type of momentary circuit breaker I'm just trying to help I never saw anything like that before good luck........
Nov 06, 2008 | Sony Xplod CD Player w/MP3 Playback...
Losing station on cd radio
THAT TYPE OF CONFIGURATION MUST BE OBTAINED FROM THE USER MANUALS
Aug 06, 2008 | Clarion DB245 CD Player
Jvc cd/radio
bodysnatcher ..make sure your unit has a good earth..do not rely on an earth from aerial..some times when units are installed.and there is bad earth connection it will earth through the aerial only .after a while your aerial may start to loose a good connection and unit is trying to sus an earth somewhere
Feb 08, 2008 | Car Audio & Video
CD/Aux play
for the "AUX input" source put it in standby mode and hold menu... scroll down to "aux in" and turn it on by pushing right
Nov 10, 2007 | Kenwood Excelon KDC-X789 CD Player
No sound (Alpine CDA-9826)
Is this a new installation or did it just start happening without anyone changing any wiring? If it is a new installiation make sure you have the remote turn on connected to the remote turn on wire from the radio(blue and white) and not the power antenna wire (blue). The blue wire will turn off when you switch to cd while the blue and white will not.
Aug 12, 2007 | Alpine CDA-9826 CD Player
Jensen CD4610 CD Player Logo
60 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Iron
Iron
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
