Question about GPS
I have an A2265FF all in one navigation unit in my ford focus, the SD card had route 66 installed on the card which I updated and since then I have lost the files for loading the navigation, I have purchased route 66 and tom tom SD cards but I keep getting the same error, when I insert the card and tap on the navigation button it says "can't load navigation storage card\NaviOne\NaviOne.exe" Can you help me please.
  • 6 more comments
  • alan475 Apr 22, 2009
    I AM A BIT IGNORANT WITH THE SOLUTION TO MY PROBLEM IN HOW TO IMPLIMENT IT IS IT POSSIBLE FOR YOU TO SEND ME THE MISSING FILES OR RENAMED FILES FOR ME TO ADD TO MY SD CARD MANY THANKS ALAN
    i am still getting error message can't launch navigor\storage card\NaviOne\NaviOne.exe please check sd card
    thank you but that wont work the problem arose when i formatted the SD card wihout doing a back up silly me. i have tried contacting the manufacturers in china and have even returned the original SD card to have the files re installed but i cannot get any response from e mails or mailings so i am at a loss
    i dont mind paying for a solution to my problem but not for a stab in the dark
  • alan475 Apr 23, 2009
    THANKS FOR THAT I FORGOT I HAD POSTED ON THERE IF IT IS FRUITFUL I WILL GIVE YOU POSITIVE RESPONSE AND ACCEPT REPLY
  • alan475 Apr 24, 2009
    i AM SORRY YOU FEEL THIS WAY AND THANK YOU FOR YOUR HELP BUT THERE IS NOTHING WRONG WITH THE UNIT OR ITS CONTENTS THE PROBLEM IS WITH THE SD CARD IN THAT I FORMATTED THE CARD WITHOUT SAVING IT AND LOST THE SET UP FILES FOR THE UNIT TO RECOGNISE THE SD CARD I HAVE CONTACTED SHENZEN ON NUMEROUS OCCASIONS AND THEY DO NOT REPLY, I EVEN SENT THE SD CARD BACK TO THEM TO HAVE THE FILES REINSTATED BUT ALL TO NO AVAIL I HAVE EVEN PURCHASED NEW SD CARDS WITH ROUTE 66 BTOM TOM MIO MAP ETC ALL TO RUN ON WIN CE BUT NOTHING WORKS, THANKS FOR ALL YOUR HELP AND WHEN THE SITUATION IS RESOLVED WHICH I HOPE IS SOON I WILL RATE AND PAY .
    i HAD TRIED ALL THESE BEFORE I POSTED ON HERE BUT NOTHING SEEMS TO WORK MANY THANKS
    YES BUT IT HASNT SOLVED MY PROBLEM I HAVE GIVEN UP AND CHANGING MY UNIT
Meu GPS n
Posted on Aug 29, 2010
    Novelist:
  • 166 Answers
I can understand your problem, this problem arises with new SD card.
So, please copy Navione folder to memory card root directory, enter the directory, use Notepad to open Loader.ini to edit, enter your correct path, for example: \ Storage Card \ NaviOne \ NaviOne.exe save you, run to enter Loader.exe navigation procedures.
I'm sure it will work out for you. The error message shows similar indication. So, do it and load your route installed. It will work out surely.
With Regards,
Shyny
Posted on Apr 24, 2009
  • 1 more comment
  • Shyny Saxena
    Shyny Saxena Apr 24, 2009
    Hey, also you needs those missing files (like Navione.exe) ???
    I can provide you links for downloading Navione.exe, so that you can make your SD card & 66 route work again... don't worry.
  • Shyny Saxena
    Here is the link for your Navione.exe :http://download-monster.com/download-p67...
    After downloading this please put it in correct directory as i stated earlier. It will make your navigation of 66 route come true again...
    With Regards,
    Shyny
  • Shyny Saxena
    It means you already have NAVIONE.EXE at correct path as i described above. If it is on the correct path then there can be no reason for such ERROR. In those chinese manuals its also indicated that such error comes only when NAVIONE.EXE is not located at folder location ie. "\ Storage Card \ NaviOne".
    I am sure you are missing this EXE and not copying this on exact location.
    Otherwise there can be no problem in such tomtom SD cards. Many users had same problem and it got resolved by this only.
    With Regards,
    Shyny
Go to this thread and a guy on there has the software:
http://www.hpcfactor.com/forums/forums/thread-view.asp?tid=13703&posts=2
Posted on Apr 23, 2009
  • Anonymous Apr 23, 2009
    Did that help?
  • 3,866 Answers
Format the memory card, but first back up the file you need saved, format using your pc then freashly formatted put it in your GPS device for it to take the format, then pull it back out and put the file back on using the copy and paste, if that dont work the file is corupted and needs to be re downloaded where you got it from.
Posted on Apr 22, 2009
  • 2 more comments
  • Grand Canyon Tech
    Grand Canyon Tech Apr 22, 2009
    Well we do not have the file to send to you here and plus we cannot go beyond are scope. the question was a $4.00 question and if you think I earned it by my answers could you then go ahead and rate it, otherwise where both at a loss and we gurus are kinda doing this for free. thanks
  • Grand Canyon Tech
    Grand Canyon Tech Apr 23, 2009
    Try to find a firmware upgrade for the unit as well as my other comments below, Wow I think we deserve the $4 small buck for helping you don't you? I tryed and I got a no help rating from you did you even try the solutions?
  • Grand Canyon Tech
    Grand Canyon Tech Apr 24, 2009
    I worked on this case before and I though I went out of my way to help you and investigate, i called the manufacture for you and they told me to let you know to try a diffrent SD CARD and to copy the file over using your PC, Can you try this to save fuss if it dont work they told me they will ship you out a new unit and that they stand behind there product.
    If you find this new information useful please use fixya and accept the solution. Thanks
    I went out my way for you.
  • Grand Canyon Tech
    I spoke with Ford Dealership on this one the the above is what they told me they stand behind there products, if a firmware fouled it up they will replace it no questions asked.. I know you want a quick FIXYA but if we cannot provide that for this type of situation it does not mean we did not HELPYA and steer you in the right directions so the manufacture can FIXYA. so if you still wnat to hold out and think I am going to stab you in the back in the dark for money sir I do not do that you can keep you cash but to give me a rating Thanks but no thanks is not coll eather, Thanks Regards rulds2008
    Brigadier General:
  • 3,917 Answers
The specific type of error is not common and seen very very rare. But yes due to certain installaiton issues we do see several error types. Please click on the bellow link to see some solved errors which ocur with route 66.
http://www.route66.nl/support/index.php?cid=OM&opt=bugs&prod=3&cat=8
I have managed to trawl through the various internet sites and found one that suggested that the shell.ini should have the following:- \sdmmc\r66\route66n7.exe
I have changed the ini to this and also renamed my directory to r66 and changed the .exe file to lower case to read exactly as in the ini file and finally it worked! Still have no idea why it wouldn't read beforehand as I thought it looked ok.
My GPS is working fine.
Thanks
Have a nice day.
HOW DO I GET A MANUAL FOR RAC 515F SAT NAV
ROUTE 66 - RAC satellite navigation devices
tw2.ro.66.com/rac/index.php?cid=UK
RAC Sat Nav 515F ... If your RAC Sat Nav develops a fault in the first instance contact the RAC Sat Nav ... If you have any questions about using your RAC Sat Nav please call on 01302 ... ROUTE 66 Navigate 7 - User manual - SW (499KB). ROUTE 66 RAC satellite navigation devices
It offers a PDF to download or read online.
Dec 10, 2014 | GPS
Tip
I BOUGHT MYSELF A FORTIS GPS NAVIGATOR AND IT CAME WITH THE ROUTE 66 SOFTWARE...
1- Turn off unit.  2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
on Mar 01, 2008 | Garmin StreetPilot C330 GPS Receiver
Route 66 Arabic Gulf Navigate 7, how to update the map.
Consult the supplier of the GPS. Some offer free updates; others charge ridiculous prices.
Aug 26, 2017 | Route 66 MAXI Car GPS Receiver
Go Cruise S350 from ''Tempo'' in Sydney will not connect to route 66 and cannot be upgraded. Looks like driver problems ,I am using Win XP/2 Any ideas??
I bought a Go Cruise S350 from ebay first locked up when I did the install following prompts (GPS told me I had lost 2 ? resource files) told seller he swapped for another and it did the same both had Route 66 on them neither would finish the update installs and that was the end of it trying to connect. So I dragged out my other GPS (Orange Cool G350M I bought in Paraguay Jan 2010) It uses IGO8 as its mapping system (but only had Brazil and Argentinian maps which was ok when there) Both use Windows CE as there platforms so did some googling and found this site
http://www.austech.info/igo/33277-ultimate-new-igo8-thread-hollowman-feb-2010-a.html worth it to register and read that page and look at other threads.
I now have the IGO8 on the Go Cruise S350 instead of Route 66
Also have Brazil and Argentina plus Australia on BOTH units now.
Use a card reader for the sd card and back up whatever is on the unit before you add IGO8.
Good luck and worth the effort.
Jan 19, 2010 | GPS
Lost Memory Card for Route66 Sat Nav
Get the SD card for any comuter store, and after you have to install the nav software on it, which for some information regarding the unit I will sell it to you for a rezonable price
Aug 19, 2009 | Route 66 Mobile 7 GPS Receiver
GPS 439 IGO route 66 -Car GPS can not find navigation not working
my navigon gps series 2100 has a problem with calculating the route and showing the turn - by - turn list.
Jun 18, 2009 | GPS
R66_ AUSTRALIA .gOES STRAIGHT TOM MAIN MENU will not navigate
My best suggestion is to contact the manufacturer so that you can get the proper software for your gps system.
Jan 28, 2009 | Route 66 MINI Handheld GPS Receiver
Route 66 stuck on the welcome screen (Route 66)
Get the update for Mini/Maxi route 66 from 183 Mb. Install this with card reader on the the SD card.
Then ,having the same problem, Route 66 will start up as usual.
Jan 11, 2009 | Route 66 MINI Handheld GPS Receiver
Gps navigation screen is paralyzed--all other screens are working
hi did you install the software straight to your route 66 maxi using route 66 sync software ? if you did try downloading it to your computer then transfer it on to the memory card using a card reader
Jan 07, 2009 | Route 66 MAXI Car GPS Receiver
Gps model number FS070001795 route 66
hi have you tried installing the gps firmware update, if not here is the link
http://www.66.com/support/index.php?cid=UK&opt=updates_detail&prod=4
Jan 06, 2009 | Route 66 MAXI Car GPS Receiver
GPS Logo
2,851 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
