Question about Ducane 436 inch 2 - 2 burner Grill
Ducane high efficiency propane furnace, pressure switch problem
My ducane furnace wont satisfy the thermostat. when I turn up the heat the burner runs for about a minute, blows out, all the while the fan motor continues to run. when i pull the switch board cover, it blinks 3 times. says that the pressure switch is the problem. I have put 4 pressure switches on this furnace in 3 years. is this just a cheaply made part? or is there other problems causing the 3 blinks(faulty pressure switch)?
  • 1 more comment
  • chwilson558 Jan 28, 2009
    I am somewhat familiar with my furnace, but where is the evaporator?
    I have found dirt in the past in the 2" rubber coupling that connects to the PVC line. cleaning this out worked for a short time. this is a vacation home.we leave the heat on 45 all winter, but when i turn up the stat, it comes right on. then the issue i listed before happens.
    Ah, the evaporator is the A coil!
    we had filter cloth at one point in the registers for dust , i removed them and the furnace seemed to work fine for about 2 months. I figured the cloth was creating to much static pressure in the duct system. All the sudden the 3 blink problem started to occur again.
    With this cold weather, if the condensate line gets some ice in it, could it make the pressure switch seem as if its the problem?
    could this be creating the effect of a dirty evaporater? ice closing up the condensate line?
    If in fact its a dirty evaporater, do i need to take the furnace off the A Coil(down flow unit) and clean it?
    I agree with everything you are saying except, i have a good bit of water coming out of the condensate line(not like when the A/C is running) but a good bit of water comes through my condensate line in the winter. Remember, this is a high efficientcy furnace.it has a sealed trap. a 5/8" line comes off the induser and 2 small lines coming off the pressure switch that drop into the sealed trap. when i walk outside, there is a steady drip running out of the condensate line.again, not like in the summer, but water is steadily coming out.
A short cycle heat cycle indicat a pressure switch replacement was needed. This did not fix the problem. the problem was in PCV line since the end was filled with slugs and cause the line to backup with water. When this happen the system would stop asking for gas. the water would leak out and it would restart. The problem was fixed by cleaning value at end of PCV. This released the water, two quart of water, that was back up causing problem. Curious if a filter change indicator was providing a clue that was missed?
Posted on Feb 24, 2009
The high limit switch on the exhaust fan is bad. Ducane has a replacement part but your contractor has to call them to get it. I am a contractor and found the problem first as ducane techs told me.
Posted on Feb 26, 2011
    President:
  • 1,214 Answers
Check that there is not a small piece of trash getting into the tube for the pressure switch.
Also check that the evaporator us not plugged full of dirt and dust from an improperly installed or poorly maintenanced filter.
This will cause burner short cycling and inability to warm the space.
Reply what you find and I'll give further instruction.
Posted on Jan 28, 2009
  • 1 more comment
  • Mark Egan Jan 28, 2009
    Look for where the 2 copper pipes come into the side of the unit. That is the evaporator. The plastic line that I think you are speaking of is the condensate line, where water drains during A/C operation. That's the bottom of the evap.
    Hard to get to, no matter where it is. But, it's a mighty good filter when the filter isn't properly installed or leaks.
    You have described the classic symptoms of a dirty evaporator, or collapsed, closed off ductwork. Maybe a fan running too slow, but rarely that.
    There won't be much if any water in the condensate line in the winter. The cold dry air absorbs most of it, ( and when you heat the air, it absorbs it even faster).
    So no, water won't be freezing in the condensate line right now, and the condensate line is so far away from the pressure switch I think your talking about, it shouldn't have any impact anyway. The pressure switch only proves to the control board the inducer fan is running before it turns the gas valve on.
    So yes, "A" coil it is (another term for evaporator).. And downflows are usually easier to clean. You should be able to get get the front panel off the A coil case, and reach inside to pull out what is now a blanket of dried dirt/duct/lint/hair. If the coil is a slab, there will only be one surface to clean. If it's an A coil, there will be two.
    You'll be surprised next summer how much better your A/C is going to work, especially if no one has jacked around with the refirgerant charge.
    I wouldn't worry too much about cleaning the coil, though. It will clean itself next summer when the A/C is used. At least don't worry about it if you can pull the blanket of stuff off, and don't see embedded dirt clogging the coil. Be sure and have all you noce white things away from the supply air grills when you start the uniti back up, becuase there is going to be some dust blowing when you first start the fan up. And to minimize cleaning later on, flipt the Fan switch on the thermostat to ON, for a short time (thats the same fan speed as the A?C uses.).
    Oops, my bad. You've got one of those really efficient 90+ furnaces.
    Still, same result though. It's not ever cold enough in there to freezer water to plug anything up unless you loose power for 2-3 days at below freezing temperatures.
My good man furnace model gmh80903bnca will not get to temp fan shuts off and burners keep burning then kicks off on high limit then starts process over but never gets to temp set at 655
If you have a switch that can manually turn on the fan, try it to verify the fan works. This is what I think is happening. The normal operation should be thermostat calls for heat, inducer fan comes on, pressure switch closes, igniter glows, main burner ignites and then in 30 or so seconds the fan comes on and stays on until the thermostat is satisfied. Once the thermostat is satisfied the burner shuts off and the fan runs for approx 120 seconds then shuts off. I think the control board that automatically turns your fan on is faulty. On most modern furnaces if the auto fan control fails and the furnace gets to hot and limits, when the limit opens and shuts off the burner it also energizes the fan motor to cool the heat exchanger.
Jan 13, 2018 | Heating & Cooling
Ducane furnace ,heat won't shut off. Keeps on heating . Have to turn it completely off to stop it.
There is a limit switch which should cut off at high temp check that or the gas valve is stuck on . Thermostat should shut down heater at heat setting .
Nov 04, 2016 | Heating & Cooling
Is 32c a normal temp for an exhaust on a force air high efficiency house furnace? This is the air temp that goes outside after heating the plenum. Is there a lot of heat going up the "chimney"??
Any furnace providing heat where it should and has little to no heat from its exhaust is doing a GREAT job ;-)
Our high efficiency gas furnace was installed with a PVC pipe as a 'chimney' which bothered me to no end until I found the surface temp of that plastic pipe only barely warm to the touch- that is a home run!
Jan 09, 2015 | Emerson Lennox Ducane Armstrong Furnace...
Heater heats but shuts off
Try the fan in the ON position on the thermostat, do you mean the fire shuts off or the blower?
a395e602-38d7-412e-a553-23ee69e9350b.png89346502-1e77-4384-8244-ea6d6788bd04.png09d1472e-35ed-4d26-be81-011af0d56f26.png
Jan 15, 2013 | Emerson Lennox Ducane Armstrong Furnace...
Brand New Ducane Furnace with Multiple Error Codes
Check your drain line. It appears that water is not draining and backing up into the furnace. Is there a drain trap? If not or if there is no vent on the drain line there can be a vacuum created when the furnace is running and it actually pulls water back into the furnace and when the inducer shuts off it releases the vacuum allowing the water to drain.
Dec 17, 2012 | Honeywell Furnace Air Pressure Switch...
Ducane furnace
Pressure switch is bocked inside try a small drill bit to clean down the connection tubes and blow it out after , check hoses are not blocked or split ,
Feb 12, 2012 | Ducane Grilling
I have a ducane grill and it will not get hot. I
The most common cause of reduced flames is a pressure problem. Could be the gas regulator for the grill. When the burners are on try giving the gas regulator a tap with something hard and see if they change size. If they do then the rqulator could be sticking. And there is a very small hole on the regulator called a vent. If this hole gets plugged with dirt or grease you can get a low pressure problem. Look very carefully on the regulator housing for this small hole and verify that it is clear. Try using a small metal wire(like a tie strap for sandwich bags) to make sure it is clear. Also verify that the tank(if propane) is not overfilled. An overfilled propane tank will cause a pressure problem. You can turn the relief screw on the propane tank until no more liquid comes out to see if this fixes your problem.
Jan 14, 2010 | Ducane 30400040 Stainless Steel Grill
I have a Ducane fits all 92 my lanlord installed,about 3 months ago.The thermostat is a new digital. The temp is set on 68,and if i go to 72 for example,the furnace starts and runs fine for about 3 to 5...
Sounds like you are not proving flame to me. Could be a variety of things. I think it may be the board...but that is a guess from past history with Ducane
Jan 15, 2009 | Heating & Cooling
Ducane 436 inch 2 - 2 burner Grill Logo
2,357 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
