Back to:
Tags:
Panasonic Panafax UF-885 Plain Paper Laser Fax
How to clear the memory (by 3 users)
posted by generalbai on Jul 25, 2007
The fax machine we have is showing up 100% in memory, at least, I think that is memory. The memory light is on, so we can't fax anymore. How do I clear the memory?
Comment by generalbai, posted on Jul 26, 2007
it is not ###, but ***. I figured it out after a few tries.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by dic graphics, posted on Dec 06, 2007
after press *** and 1:yes to delete all file, it shows "can not edit file" and the memory still shows 100%.
Comment by learp, posted on Nov 09, 2007
The memory light is n. How do I print out what is in memory?
Best Solution
FixYa! (100)
All Office
Rank:Guru Guru
Rating: 85%, 101 votes
Press FUNCTION key then 9 key. The display will ask you to ENTER FILE NO. OR ^. You want to enter ### as the file number and press SET to delete all files. (You cannot delete the file while it is being sent). The display will then show DELETE ALL FILES? 1:YES 2:NO. Press 1 to delete all files.
Rating Locked! (?) generalbai has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on how to clear the memory:
I don't want to Accept this solution
Solution #2
posted on Apr 11, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
On Model 855:
Press Function Key then 9, then 3.
Enter *** as the file number and press Set to delete all files
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Can you Help with these Fax Machines problems?
Fax Machines
i started to copy and half way though the machine...
Fax Machines
It asked me questons for resetting and I pushed the wrong...
Fax Machines
HP Officejet Pro L7680 All in One. Problem: Sometimes...
Fax Machines
The blade on the GBC Shredmaster 1256S does not work.
Fax Machines
type film for fax machine KX-FPG371? Theone suggested does...
Loading problems.
Repair Service
Find Fax Machine Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
