Question about Singer 5050 Mechanical Sewing Machine
5932 knotting every other inch
I am trying to sew on a model #5932 and the thread is knotting on the underside as I sew. This problem arbitrarily gets worse and better. The top of the stitch looks fine, but the underside looks like alternating normal stitching, huge tangle of thread, and then fine again. The loops of thread are huge on the underside when the machine is acting up, but switches back and forth between good stitches and bad with no stopping or changes in any settings on the machine. HELP!!!. I am using the straight stitch setting, the tension is on 4, stitch length is on 1, normal cotton thread, normal cotton fabric. I have to finish this quilt this week. Please Help me figure this out!
  • lexierdh Feb 10, 2009
    Same here! Will try suggestions, but what is the HOOK? I let years go by between projects and need clarification.
    New Friend:
  • 186 Answers
Try oiling the hook if you haven't recently.
Check you needle plate and hook for damage, they may need to be buffed or sanded smooth.
Check your upper tension discs for lint and double check your upper thread path (proper threading).
There are other things like hook timing, needle clearance or broken check spring that may be wrong but you need a technician for those things.
best of luck!
Posted on Jan 31, 2009
White 3100 just knots in stitching
when you say knotting, do you mean a snarl up of looped thread on the underside. If so check top thread tension
Dec 26, 2013 | White Sewing Sewing Machines
Bottom thread tangles and knots
usually a top-thread tension issue, try tightening up the top thread's tension, there is usually a disk or knob somewhere to adjust it.
Dec 10, 2013 | Sewing Machines
Thread is knotting up on the underside of the fabric - what do I adjust. I am using a Singer 438
Try pulling your top and bottom thread to the left side of the foot before you place the presser down and start sewing.
Sep 06, 2009 | Sewing Machines
Hi, my sewing machine is making a ball of thread under the material we'resewing i was told i might need to adjust the tension i don't have the manual booklet.
Try adjusting the numbered knob on your machine...this is your tension control. If you have knots on the underside of your fabric you want to turn this knob to a higher number until the knots dissapear.
Aug 24, 2009 | Kenmore 15516 Mechanical Sewing Machine
Thread wad on undersurface
machine not threaded properly? wadding thread underside means upper thread does not have tension.
Jun 30, 2009 | Brother SE-270D Computerized Sewing...
Bobbin continues to pose problem - knotting thread underside of fabric,
In 99% of all problems with "bird's nesting" or "knotting" it is an issue of the thread coming out of the take up lever (at threading guide #3) (from the spool; through the first thread guide at #1 down to #2 and up to # 3) when the thread comes out of the take up lever, the machine can not regulate the thread and it floods the machien with thread and wraps itself around the bobbin case. OR! Your tension is too loose. Raise it. Your machine should preform perfect at tension #4 unless you are using speciality threads or fabrics.
ALWAYS be in the habit of threading your machine with presser foot up so that while threading between paths 1 and 2 you are certain to have the thread pass throught the tension disks.
This will happen on a $50.00 machine or a $5,000 machine. The thread needs to be regulated.
USE GOOD THREAD!
Thanks,
Bonnie
Oct 25, 2008 | Kenmore Drop-In Bobbin 16231 Mechanical...
Singer 5525 sewing machine knots up thread on underside of fabric after three stitches
most commonly this is from incorrect threading top thread. Check manual for threading path or follow threading path usually marked by arrows on machine
Sep 10, 2008 | Singer 8280 Mechanical Sewing Machine
Thread knotting up when I sew
This machine has an automatic tension setting, but I will try what you are saying. Thanks
Jun 18, 2008 | Janome Sewing Machines
Singer 6268, needle timing advice
I have a Singer Sewing machine, Model #6268. The threads have knotted up on the underside of the material. When I finally was able to pull it all out, it caused the needle to hit on the bobbin plate (hope that is right). Now the needle is bending, not going through. How can I adjust it back as it supposed to be? I have had this happen before, but it cost way too much to get it repaired. And I still don't know why this happens (the threads getting tangled).
Thanks!
Mar 29, 2008 | Sewing Machines
Singer 5050 Mechanical Sewing Machine Logo
503 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
