Question about RCA D52W19 52" Rear Projection Television
Rca D52W19 tv will not turn on the power light will blink 4 times then go off but tv it's self will not turn on please help me
  • RCA Master
  • 8,617 Answers
I would try replacing CP150 , CP114 and also CP120 as those three capacitors have been known too fail which will prevent the set from powering up.
Posted on Jan 29, 2009
Power issues. plug the tv and the power light keeps blinking. no reset button found. please help.
The blinking is the the the error code that will tell you what is wrong with your TV. You will need to count out the number of blinks. Then repost a new Question with the number of blinks! I hope this will help you get on the right track to fixing your TV!
Jan 06, 2011 | RCA D52W19 52" Rear Projection Television
D52w19 rca hdtv.will not tourn on. when u push the
Hi Friend,
Please folliow the below steps one by one
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
If still you are having the same problem then please check the resolution configured in the Screen,try to reduce the Colour and the brightness of the TV
Even after that you are facing the same issue please check with the Display Card in the TV,
If you have any Clarification please feel free to contact us
Regards,
Ayyasam
Apr 03, 2010 | RCA D52W19 52" Rear Projection Television
Tv green light flashes on and off 3 times. Never comes on.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
check the components as given above and if necessary replace the components to solve the issue.
This will help. Thanks .please do rate the solution positively .thank you for using fixya.
Mar 17, 2010 | RCA D52W19 52" Rear Projection Television
I have a RCA D52W19 when tv turn on the power light blink 3 times but nothing hapen
Cp150, CP120 and CP114 repair kit form www.tvrepairworld.com should solve that issue. The kit comes with the instructions on CD.
Nov 19, 2009 | RCA D52W19 52" Rear Projection Television
Model d52w19 rca projection tv,will not turn on.the green power light blinks three times,but nothing happens.
Thats the eroor for the flyback and CP150 needing replacement you can get the flyback # 259296 and the CP150 at the following link and they give free step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Mar 06, 2009 | RCA D52W19 52" Rear Projection Television
Rca D52W19 will not come on
CK capacitors cp114,cp120 cp150 they are on the Deflection Board.
Jan 28, 2009 | RCA D52W19 52" Rear Projection Television
52 in rca tv
does the light blink 3 times when you press power? Let me know exactly what happens when you press the power button. Please respond to this same post when replying.
Aug 07, 2008 | RCA D52W19 52" Rear Projection Television
Rca model d52w19
blinking light indcate a processor shutdown.. the processor has detected a problem in safety circuits and shut down the set. common problem are flyback and horizotal ouptut transistor. the processor has a error log file. technicians can plug a specail computer and read those to determine problem
Oct 28, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
118 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
