Question about Kenmore Elite 45986 Front Load Washer
Dishwater doesn't work
My dishwater doesn't go through the whole cycle. When I press wash, after a while it doesn't switch to drying, then cleaning, then sanitizing. It stays on washing.
  • 15,935 Answers
It appears your timer/controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
What steps will improve dishwater performance?
You can remove hard water deposits/scale by running one cycle of your dishwasher (empty) with distilled white vinegar. Add 2 cups of vinegar to the bottom and turn the machine on to an energy saving or low wash. Stop the machine mid-wash, so the vinegar can set on the bottom and work. check links below , press the helpful button.
https://www.bobvila.com/articles/how-to-clean-a-dishwasher/#.VqeDiporJxA
Cleaning the Inside of Dishwasher with Vinegar and Baking Soda
How to remove and clean your dishwasher spray arms
Jan 26, 2016 | Dishwashers
What doesn't my dishwater finish its cycle?
What is the make and model number
Jun 09, 2013 | Dishwashers
How can you tell if the dishwater is getting sufficient water to clean? My soap dispensers are really a mess, lots of dried on soap, and my silverware that are underneath the dispenser often have soap...
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 26, 2011 | Whirlpool GU2400XTPS Built-in Dishwasher
Problem is put the dishwater on ,doesnt seem to be enough water on the cycle ,dishwater goes through the whole cycle even drys, but has some water lying at the bottom at the end .Some said it might be a...
Check that your supply faucet is open, Check if there is a screen in the supply line, these can become blocked due to scale deposits from the mains. If there is no screen check that the inlet solenoid valve has not got blocked. If none of the above help, check that there is power getting to the solenoid valve when the machine is supposed to be on the fill cycle. If no power is betting to the valve, the timer might ba faulty. (You can try hand filling the machine and see if it goes through a cycle, at least up to the rinse stage, this will tell you if the timer control is working).
If you feel that there is water not being pumped out, remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Feb 18, 2011 | Indesit Dishwashers
Following the wash cycle with my Miele G464SC
sounds like you mean when the unit is running you are getting water dripping from the bottom of the door panel. if you remove the door panel at the bottom where the door hinges you will find an overflow tray which runs the width of the door. This is probably blocked with food deposits.
If not you may be using too much detergent. try running with no detergent and see if there are any leaks.if you open the door mid cycle the water level shouldn't be any higher than the bottom spray arm. hope this helps
Jan 02, 2010 | Miele 24 in. G646SC Plus Free-Standing...
After the wash cycle the unit will not empty, according to the feedback on this page they sujest a dishwater cleaner, can you tell me what type and where to obtain it.
I don't know that a dishwater cleaner will solve your problem. More than likely the pump is no onger functioning which is located on the bottom of the unit. When the dishwasher goes into the discharge cycle does it make a humming sound or does it do nothing. All pumps make sound when discharging the water from the basin. If there is no sound present then the pump is not functioning........if the pump is making a humming sound then it is locked up. Let me know please thanks.
Deathstalker
Sep 01, 2009 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Inch of water left in bottom of dishwater after done running
check for blockage starting at air gap and disposer.trace back and clean
Dec 31, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Kenmore elite dishwasher
I had the same problem when I bought it and it just happened again; the problem is solved by ressting the control panel: Hi Temp ---> Heated Dry two or three times. It kind of goes into a testing cycle and the clean blinking light goes off.
Dec 08, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore Elite 45986 Front Load Washer Logo
14 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
