Question about Sony WEGA KDE-42XBR950 42 in. HDTV Plasma Television
Is there a wall mount for a sony kdf-e42a10 lcd tv
Any help would be great
  • 668 Answers
SOURCE: Sony LCD Project KDF E42A10. Blue area about 6
It sounds like you have problem with the Optical Block. It is not a cheap fix. You may want to call Sony at 1-800-222-SONY and see if they would help with the repair. They can also refer you to a local repair facility to do the work.
I hope this help,
Skyassoc
Posted on Jun 26, 2009
  • 668 Answers
SOURCE: Sony Bravia 40" LCD TV Stand
There is a slotted area on the bottom of the unit and the bracket on the stand slides over top of it. There should have been four screws that came with the packaging that fit in the four locations in the lower center of the cabinet back that secures the unit to the Stand.
I hope this helps,
Skyassoc
Posted on Aug 25, 2009
Axle80
  • 73 Answers
SOURCE: Sony KDF-E42A10 rear projection TV. Won't turn on.
Start by changing the lamp. If you got 5 years out of the old one, count your blessings, most folks only get three. The lamp is designed to be replaced by the consumer. Ebay will carry a replacement for you or you can get it directly from rivervalleyelectronics.net. They've got good prices. The lamp door is on the back. Its really easy, give it a shot.
Posted on Sep 17, 2009
  • 51 Answers
SOURCE: My screen has dark spots in the upper corners that
Could be Optical Unit (Probably)
Posted on Dec 03, 2009
SOURCE: how do i reset the lamp life for sony KDF-E42A10 ?
1) In standby mode, press the buttons on the Remote Commander sequentially, in rapid succession:
[Display] , Channel [5] , Sound Volume [+] , Power [ON]
2)To enter BE-micro service mode menu, press JUMP 2 times.
3) To display the lamp time, press Channel[4]
The screen displays:
“ Total lamp time is 14 hours”
4) To display the lamp time clear, press Channel[5]
7 times and Channel[1].
To reset the lamp time press Channel[3] > [MUTE] > [ENTER].
WRITE (Character color is red) is momentarily displayed and the lamp time is reset to “0”.
This worsk for other Somy retroprojection TVs as well, eg. KDF-E50A10 , KDF-E50A11 etc.
If you goto eserviceinfo.com you'll get the whole service manual
HTH!
zioanza
Posted on Dec 17, 2009
Sony KDF-E42A10 KDF-E50A10 LCD TV Service Manual
If you wish to get more details about these, check this link. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 02, 2013 | Sony KDF-E42A10 42 in. LCD Television
Do I need a qualified technician to fix a fan problem on KDF-e42a10 and is it worth fixing or should i just get new tv
fan is simple to replace take bottom panel off back of tv then u will see fan just remove 4 mounting screws and flag clips and replace in reverse order.
May 15, 2011 | Sony KDF-E42A10 42 in. LCD Television
Sony KDF E42A10 picture loses quality.
It sounds Lamp is weak and causing darker picture.
How old is this TV and did you replaced Lamp recently?
If lamp has not been replaced in past 2-3 years then its time for new lamp, XL-2400 available in Sony Accessories Store and lamp replacement procedure is written in user manual.
Thanks.
Nov 05, 2009 | Sony KDF-E42A10 42 in. LCD Television
The TV resets itself every 30 seconds , I have turned it off I have also unplugged it and plugged it directly into the wall as well as change out surge protectors. the TV will be fine for a day or two then...
If it is Sony KDF-E42A10 TV then it needs new lamp.
How old is this TV and have you replaced lamp recently?
Lamp replacement procedure is written in user manual.
Let me know to provide you more info.
Thanks.
Oct 01, 2009 | Sony KDF-E42A10 42 in. LCD Television
Sep 07, 2009 | Sony KDF-E42A10 42 in. LCD Television
Black Screen with sound
Take a look at your lamp in your tv. Your owners manual will tell you how to change it.
May 23, 2009 | Sony KDF-E42A10 42 in. LCD Television
Our Sony KDF-E42A10 42 inch LCD TV has yellow hue
Contact Sony. You need optical block replaced. Class action .Sony may cover this.
Apr 07, 2009 | Sony KDF-E42A10 42 in. LCD Television
I have a Sony KDF-E42A10 42" LCD TV that has probably 100 vert
Its a b-block assy that causes the vertical lines b- block is out
Mar 31, 2009 | Sony KDF-E42A10 42 in. LCD Television
Sony LCD KDF-E42A10 Television
Please count flashes on Sony KDF-E42A10 tv and let me know.
Its error signal and shows problem with particular area in your tv.
Sep 29, 2008 | Sony KDF-E42A10 42 in. LCD Television
Sony WEGA KDE-42XBR950 42 in. HDTV Plasma Television Logo
56 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
