Question about Microsoft Xbox 360 Controller
Xbox 360 controller
Ive just put rapid fire into my controller and it wont seem to work right when i press up on the left anolog stick it goes left PLZ HELP
  • Bazzeil May 11, 2010
    you using the controller on xbox or pc?
  • 3 Answers
If youve put rapid fire on ur controller and it goes left its because when u went in to wire the rapid fire u put the part that controls the left analog in one quarter of a full turn to the left from where its meant to be. so open up ur controller and flip it the right way.
Posted on Feb 10, 2009
Analog stick are doing the opposite of what they should
I had this problem also on my sons xbox.. You must go into profile and then edit the settings.. In the default game setting you select the actions tba and have movement set as the left thumb stick.. His was set to the right thumb stick.. All sorted now.
Jul 03, 2012 | Microsoft Xbox 360 Controller
My wired turbo wildfire controller 2 wont connect to my laptop
the wired controllers cant be modified in the turbofire software if thats what your asking..but they can be used for pc games with scpserver
Jan 01, 2012 | Datel Wildfire Wired Controller + Turbo...
I just got my wildfire controller and i have some problems with it. I followed all instructions in the manual but i only have 1 fire mode. I cant switch between them. Only the LED lights on the left...
Although Datel has been notorious for making garbage products, I'll say this. Usually it depends on the game that you're playing. For example most people buy turbos for Call of Duty games. Knowing this, Call of Duty as implemented a kind of coding in their games that limits some of the functionality of turbos to make it more fair to people without them. So it could be the game, or the controller could just be downright faulty, which wouldn't surprise me either.
Hope it helps! -Joe
Jun 07, 2011 | Datel Wildfire Wired Controller + Turbo...
Turbo Fire 2 controller for Xbox 360 right slick doesn't work
ok m8 visit my website xbox360repairspro.webs.com or try taking it apart and playing around with the connection to the new rapid fire button
May 28, 2011 | Datel Xbox 360 Turbo Fire 2 Wireless...
Right anolog stick control on call of duty 5 is messed up
sounds like its INVERTED....chk your control setting and set it the opposite of what it is and try that.
May 10, 2009 | Microsoft Xbox 360 Controller
The right anologe stick of my xbox 360 conttroler has stopped wor
Try turning off the system and unplugging the control. Wait 30 seconds, reattach the control and turn on the system and test if it's working.
If not, you probably need a new controller.
Feb 08, 2009 | Microsoft Xbox 360 Controller
My wireless xbox controller keeps blinking green but won't connect
Have you tried leaving your console OFF first, and then Holding down the CENTER [X} button to turn your console on?
Usually that always works, I usually disconnect the battery clip and reconnect it (to turn it off) when it keeps blinking and does not connect.
Then I hold down the center button on the controller and move the left analog stick around in circles while it's blinking, and it usually recognizes it a lot faster when I do this.
-If the above does not work, disconnect the battery clip on the controller again and put it back in,
-But first (before powering on the controller) press and hold the tiny -sync- button on your xbox (while it's on),
-and then turn on your controller, and hold down the sync button on your controller, and move the anolog stick around while it does this also.
If the above does not solve your problem, I'm sorry, but I tried.
Jan 17, 2009 | Microsoft Xbox 360 Controller
Right Joystick. . .
I had this same problem with my 360 controller (after modding it, but the solution should be the same..) If you pull up on any 360 joystick it will stick the same way.
The quickest fix would be to take some sandpaper on the inside of where the joystick touches the controller shell, sand it down just enough so the joystick is moving smoothly.
More professional ways would be to cut the little piece of metal that sticks out and goes into the joystick. Just a very small amount, too much will make it hard to press the right thumbstick button.
You could also try some old fashioned grease, just a little bit on the inside, nothing noticeable from the outside.
Also make sure the controller is put back together right, I've taken apart many 360 controllers and sometimes joysticks stick when there's a wire in the wrong place and the shell won't close all the way. (The rumble motors particularly).
Hope this helped!
Sep 16, 2007 | Microsoft Xbox 360 Controller
Microsoft Xbox 360 Controller Logo
181 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
