Question about Dell Inspiron 7500 6x DVD and LS120 Floppy Drive - 2481U DVD Drive
Optical media not opening on laptop - Dell Inspiron 7500 6x DVD and LS120 Floppy Drive - 2481U DVD Drive
    Problem Solver:
  • 6 Answers
Reboot it, or try to redo computer
Posted on Jan 28, 2009
Optical drive D: repair in windows 8.1
Sounds like Autoplay is not configured. You can see how to change your Autoplay settings on Microsoft's web site here: http://windows.microsoft.com/en-us/windows/change-autoplay-settings#1TC=windows-7. Autoplay is a strange duck, doesn't always work regardless of settings. You can also open 'computer', which in Windows 81 shows as your User Name, not 'Computer' or 'My Computer' like older versions, then right-click Drive: D, and click 'Play with VLC Media Player', which is the best player I believe - I've used it for years.
Feb 11, 2014 | Toshiba Satellite S955-S5376 15.6-Inch...
Cant open cdrom
I'm pretty sure that model of laptop doesn't have a CD-ROM, or any optical media drive, could be your problem.
If you have an external one connected, there should be a button on the external device, alternatively open "My Computer" and right click on the optical drive and select "Eject" to eject the tray.
Hope this helps.
Dec 07, 2013 | ASUS Eee 4G Notebook
Replaced printer, same laptop with software. Inserted new DVD, but laptop does not give instructions for connecting printer.
It is possible that the auto-run feature has been disabled. Try opening the CD manually. If you have Windows, double-click on Computer (My Computer for older versions). Then double-click on the optical drive under Devices with Removable Media. Find the installer (exe for Windows, dmg for Mac) and double-click to launch it.
If the optical drive doesn't open, then you have a problem with the disc, the drive, the drivers for it or the registry properties for the drive.
If the disc install the Easyshare 5500, download the drivers for supported OS versions from here: http://support.en.kodak.com/app/answers/list/p/5,62,419/c/890/selected/true . Then double-click on the file to install. (If you plugged in the data cable (USB) to the computer before installing this software, uninstall the generic driver and then disconnect the data cable and reboot before installing the new software.)
Now to go back to the drive problem, if you were able to launch the file from the File Explorer (Windows), you may want to reenable auto-run. In Windows 7, click Start > Control Panel > Hardware and Sound > Autoplay. Set the line for Software and Games to Install or Run. You may want to check the box to Use AutoPlay on all media. If the optical disc could not be read, try cleaning the disc (if you see scratches) and try cleaning the optical disc lens. (Did you here the disc spin when loaded?) Check the Device Manager for a triangle with a red x or yellow exclamation point next to the optical drive. (Start > Control Panel > Hardware and Sound > Device Manager) Try to update the driver.
If there was no sound of the drive spinning, you may want to check if the power or data cable have become disconnected inside the laptop (either at the motherboard or the drive). See your laptop's documentation for opening it up or take it to be serviced at a local shop. You may need to replace the drive. An external optical drive can be used to replace the internal one and are fairly cheap. Most connect to one or two USB ports on the computer. The ones that take two USB ports do not need a power brick.
I hope this helps.
Apr 23, 2011 | Kodak EASYSHARE 5500 All-In-One InkJet...
Help my dvd drive is stuck and wont open
Desktop or Laptop computer wasn't stated.
With most desktop computer optical drive's there is a tiny hole located right under the optical drive tray.
(The tray the disk is inserted in)
A paper clip is straightened out, then inserted into the hole.
This is a manual override, and will open the tray.
There are some desktop computer optical drives, that the computer case has a door that flips down, then the optical drive tray comes out.
The door must be eased down far enough to see if the optical drive has the small hole.
With a laptop computer the optical drive is removed from the laptop.
Generally there is one small Philips head screw that is removed from the bottom side of the laptop, then the optical drive tray is opened with the paper clip, and the optical drive is then removed by using the tray as a handle.
The optical drive is then pulled straight out.
Once out the top cover is removed for access to the disk.
If this information is not what you seek, or you would like it explained, please post in a Comment, and we'll work together on finding a solution.
Regards,
joecoolvette
Apr 21, 2011 | HP Compaq Computer Speakers
I PUT A CD IN CLOSED THE TRAY...THEN WHEN I RE OPENED THE DRAW OPENED BUT WITHOUT THE CD
The CD may have been inserted loosely in the tray and shifted inside the notebook during transit or use.
You can often remove the drive by locating a screw on the bottom of the notebook about 4-5 inches along the interior and generally near the vertical center of the Optical Drive's dimensions. Once located, remove the screw and use a small flat screwdriver or nimble fingers to remove the drive. If you encounter even moderate resistance, stop attempting to remove it and ensure the proper control screw has been removed to allow you to slide out the drive.
A second option in this scenario is to remove the flat or contoured bezel covering the Optical Drive fascia. After doing so, locate a pin-sized hole (sometimes labeled EE or with an asterisk) along the face and push it in using a small flat or Torx-based screwdriver, a pen tip, or an unbent paper clip. This will emergency eject (EE)the optical drive tray, allowing careful access to the interior and the lost media likely still inside it.
If you are unable to locate the media after following these guidelines, it is likely the media was inserted in the small space between the notebook casing and the Optical Drive's exterior surface. Remove the drive completely and attempt to locate the media. If you cannot, you may be incorrectly assuming or recalling it's initial placement. Double-check your brain's memory. :)
If you are convinced your media is inside the notebook and these solutions fail to assist locating it, the notebook may need much more extended disassembly to resolve this problem.
Nov 21, 2010 | Computers & Internet
How do I remove a cd-rom from a hp dv5
1) Work on a table.
2) Remove ALL power to the laptop. AC adapter (Charger) and Battery.
3) Turn the laptop over Front facing you. There is one single Philips head screw to remove.
It's on the bottom of the laptop towards the Front, and is just past the Microphone, and Headphone jacks.
4) Screw removed use a paper clip to open the optical drive tray.
The paper clip is straightened out, then a third of it is bent into a handle to hang onto.
Looking at the optical drive with the laptop upside down, there is a small hole to the Left, on the optical drive tray. Insert the paper clip tool you just made into the hole.
This is a manual release to open the optical drive tray.
Hold onto the optical drive tray with your fingers, pull the optical drive out.
If you are going to replace the optical drive, be sure to remove the optical drive bracket from the back of the optical drive. (Two Philips screws) Install the bracket on the new optical drive.
Regards,
joecoolvette
Nov 15, 2010 | Computers & Internet
My dell xps m1530 will not and the eject will not function
The M1530 slot drive has no manual eject. If the drive is not ejecting the media, then a service call is required to replace the optical drive. (The old drive has to be removed from the chassis to get the media out of it)
Hopefully, the system is under warranty.
if not, information on removing the optical drive is here:
http://support.dell.com/support/edocs/systems/xpsM1530/en/SM/optical.htm#wp1038494
Mar 30, 2009 | Dell XPS M1530 Laptop
How to remove the optical drive from a Compaq Presario 3045US?
Open the RAM door and remove the two screws underneath. The optical drive will slide right out.
Jan 11, 2009 | Compaq Presario 3045US Notebook
Hoow to install a dv2000 hp pavilion dvd rw drive (internal)
Remove the Phillips PM2.5x7.0 screw (1) that secures the optical drive to the computer
Insert a thin tool, such as a paper clip, into the media tray release hole (2). (The optical drive media tray release from the optical drive)
Use the media tray frame to slide the optical drive (3) to the left.
Remove the optical drive.
ce642a5.jpg You can download the complete manual here:
http://h10032.www1.hp.com/ctg/Manual/c01035657.pdf
Jul 22, 2008 | Compaq Pavilion ZT3280US Notebook
Cd will not play
Please test your Optical Drive with any bootable Cd/DVD if it gets successfully booted from CD/DVD then your Optical drive do not have any problem.
but if it is not sensing the CD/DVD in boot sequence also then there might me problem with your optical Media Lense also.
You need to replace it
May 28, 2008 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
20 people viewed this question
Alun Cox
