Question about Sony NW-A1000 MP3 Player
Sound out of one earphone only even though the earphones are ok
Is the earphone port repairable and at what cost
  • 82 Answers
Socket might be faulty and not that easy as any other part to procure cause its board mounted one ask some one to open and set it right if its not brocken the contact legs
Posted on Jul 13, 2009
MacBook Pro mid 2011 AUX input dose not work with my headphones.. please help me.. :(
Its very rare a mac has sound problems. Some earphones consume batteries, does yours have batteries in it? and is it powered on while connecting? With the earphones connected, check system volume and increase the sound while playing music. If there is sound coming from the mac itself then there maybe an issue with the AUX connection. Possible dust blocking the port. Clean it and try again. If there is no sound coming from the mac itself while the earphones are connected, then the AUX port is connected to the earphones and is in good working condition. Increase the volume on both devices, the mac and the earphones, if it has this feature. If there is still no sound, there may be a problem with the earphones itself. Possibly bad wires already, connect the earphones to other devices and listen for sound. If still no sound, replace earphones.
Oct 17, 2013 | Apple MacBook Pro MB991LL/A 13.3-Inch...
Hi. Greetings. I have one of this set. One day while i'm playing songs on it, my siblings accidentally plugged another wire into the earphone port. When i unplugged it, there isn't anymore sound...
Put a plug in the earphone port and wiggle it . Could be the little gadget inside is stuck. I had a tv that did that and ended up disconnecting the ear plug port.
Sep 21, 2017 | Altec Lansing VS4121 Computer Speakers
I have used corded earphone while I was on travel. After unpluging the earphone, The phone does not work even with blue tooth. ( no dialing tone, no sound at all) I can used it only with corded...
hi sfkimura you need to take the battery out of the phone. Next plug the headset and into the port. Take the headset out and now put the battery back into the phone. the phone got set in headset mode. You can try doing a reset of the default settings. Don 't do a factory reset it will erase your phone back to nothing on the phone. Ok hope this help
Jan 19, 2011 | LG Dare VX9700 Cell Phone
My Philips GoGear Raga 2GB is not working properly. Its earfone jack socket is causing some problems, it doesnt give proper sound now!
The fault could be the earphone, check the earphone in a different device/player, if the fault still appears the the earphone is faulty, probably a broken wire in the cord.
If the earphone is OK then the earphone socket in the MP3 player is faulty. If may be too expensive to repair, unless you can DIY.
Sep 14, 2010 | Philips Audio Players & Recorders
When I plug the earphone jack into my MP4 player, I only get sound from one earpiece. I have tried several earphone sets to determine that it is not a problem with the earphones
Hi, this is a very common problem, after you have pulled the ear phones in and out a few times the solder on the earphone socket becomes brittle and breaks making you lose the connection with the circuit board, now as you have ruled out it being an earphone fault then the only possible problem could be the solder.
now sometimes if you wiggle the earphone at the part that goes into the mp3 you can sometimes get the sound working again, but this dont always work so dont rely on this,
now the problem you have is that the cost of getting this part fixed would cost a lot more than buying a new mp4 player.
the cheapest place to try and get this fixed is a tv repair shop, tell them exactly what the problem is so they dont have to test it and see how much they will charge you to resolder the earphone socket back in place properly.
that would be the cheapest option and could possibly get it working again if they will do the work for you
im sorry their is no easy fix but without getting the earphone socket re-soldered it will just never work
let me know if you need further assistance ok
Aug 18, 2010 | Naxa Electronics Audio Players & Recorders
No earphones sound OK, with earphones no sound
the connector may have come loose from the player board, you could try opening it and replacing/resoldering the port, but it would be best if you just sent it back for repair.
Nov 05, 2009 | Sumvision ICE800 Digital Media Player
Right earphone wont work.
It is very likely that the problem is in your MP3 player and not your ear phones. If it is still under guarentee, then take it back to where you bought it. If not it may be that the earphone jack plug is faulty? It is a trade off between the cost of repair against the cost of a new one. These things are often glued together so opening it could break it anyway - sorry
Jul 02, 2009 | Nextar MA933A MP3 Player
Samsung G600
you need to go to options while you are listening to music & then select "earphone on"
May 24, 2009 | Samsung SGH-E900 Cellular Phone
The earphone port has lost whatever holds the earphone in the mix max, can it be repaired?
yes it can be repaired your looking at $20 for new headphone jack installed should not cost anymore than that any electric repair place should install one for you even radio shack
Jul 17, 2008 | Disney Mix Max Digital Media Player
Sony NW-A1000 MP3 Player Logo
87 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
